alvaro84 wrote:So the board has 8+1 cache IC sockets? That's good, common wisdom says that the cache is less strained in dual bank operation than when there's only one bank (4 chips) on board - and I lately experienced the same while experimenting with various 486 boards.
Not op but my board does have 8+1 cache now, 256kB of it and all 15ns chips, but I have not seen any speedup with 386 vs 128kB. Might turn out it's not bank-interleaved cache and actually adding more chips makes the timing problem worse due to more parasitic capacitance and slower signal slew rates. Could be BIOS issue, mine is 11/11/92 and I think I have found a 08/08/93 image that's from the same model but haven't tried it yet.
The 495SLC chipset is not very good either way as it turns out. RAM read latency is just horrible, I'm barely doing 10MB/s on a 40MHz CPU. Cache read is about 23MB/s (I can do 27 but it's not stable at 2-1-1-1, same problem as op's). I have cache-less SX systems that do way better, at some 18MB/s! Curiously writes seem to be good, doing about 30MB/s. It's a good thing I got this mobo very cheap because it was damaged from the battery spill and I had to spend quite a few hours fixing it (and that's after as much time spent cleaning it). Originally I even planned just removing some parts from it but it does work now, so...
Anyway this mobo has VLB slots and works way better with 486 CPUs, mostly because you have to use 3-2-2-2 timing anyway with a 33MHz+ 486 and the internal L1 cache masks a lot of the board L2 and RAM latency. Burst reads also improve RAM latency, as well as (I think) different banking in 486 mode. In general it's a decent board for early 5V 486 processors, but medicore 386DX 40MHz one. If it was cache-less it would be a disaster in 386 mode. Another board I have, a UNICHIP 367C, does way better with 386DX and it only has 128kB of cache in 4+1 configuration and no room for more. Sadly it lacks VLB so some games (like Doom) will be tad faster on the OPTi anyway due to Cirrus Logic 5224 in VLB slot vs Trident 8900D (which is BTW a very capable ISA card).
I've run some benchmarks on several 386/486SLC/486DLC equipped mobos, I might compile it someday.
