Reply 11340 of 31478, by henryVK
Ordered all the stuff that I need in order to replace the LCD on my luggable 5x86:
  • 10.4" NEC NL6448AC33-18 LCD display
  • LCD driver board
  • Molex-to-5.5mm 12V DC adapter
  • VGA 15-pin flat cable
  • VGA 90° adapter
Too bad most of this stuff is coming from China, so it'll be a while before anything arrives. I have no experience with Far East hardware more sophisticated than heads for my razor, so it'll be interesting what the quality is like.
Reply 11341 of 31478, by ynari
Screwed the case shut on my pentium II system, after verifying that CD audio was working fine. Intend to install NT4, then it will be *complete*. Played a little GTA London 1969 (3dfx, with CD music), and will be slowly working through Redguard.
Reply 11342 of 31478, by brostenen
Recapped a C64 and put it up for sale on a local trading site.
Reply 11343 of 31478, by Cyrix200+
Started a 386 build in a case I recently traded. All good so far!
Motherboard is a PC Chips M-326 I bought years ago
CPU is an AMD Am386 DX 33MHz I bought last week
Memory is something I grabbed from the bin. Turned out to be 4x 1MB. This is apparently also all the 30 pin ram I have 🙁 I thought I had more...
Lost some time with a defective (must DDx) VGA card and this board hangs in POST if there is no interface card installed (or is this common in 386 systems?)
POST cards are a blessing!
1982 to 2001
Reply 11344 of 31478, by assasincz
This morning, I worked on my new old acquisions from this week,
Cleaned and PTFE lubricated Cherry G84-4100 keyboard (and found that not only it was made in my home country, Czech Republic, but assembled by some guy named "Šindel", as hand-signed on a sticker under a spacebar)
Then cleaned and lubricated an Alps/IBM FDD and BenQ CD-Rom (I struggle making it read disks though)
All of that while the faceplates of the FFD and CD-rom as well as of my old AT case are being retrobrighted in peroxide bath under UV lamp.
The attachment 54214946_2297964397147250_1869777406307336192_n.jpg is no longer available
Reply 11345 of 31478, by oeuvre
found this ad for partition magic 4 from 1998
and enjoy this
Reply 11346 of 31478, by blurks
Searching for older graphics cards can be a tedious task, especially considering most of them seem to hide in a huge pile of modern PCI-Express garbage. To make life a bit easier I decided to work with a blacklist system and rule out specific terms I don't consider being worthy to even look at so this is my current setup for searching GPU's up until around ... 2004?
-pcie -pci-e -pci-express -pciexpress -1030 -1050 -1060 -1070 -1080 -8800 -210 -260 -270 -290 -390 -430 -460 -480 -570 -580 -630 -710 -730 -750 -960 -970 -980 -gts -his -msi -eah -xfx -amd -vega -tesla -sapphire -titan -radeon -rtx -gtx -strix -firepro -hd -quadro -grid -zotac -club
Search results are already way better but with the usual space to improve. Need to incorporate the entire GF7 series and upwards as this modern GPU-generation shit still spams my results more than I want to.
Reply 11347 of 31478, by McBierle
Still working on trying to get the data of an old ST-251-1 MFM hdd.
At least i finally had time to get working on my Soyo SY-025J2 motherboard. Some time ago i soldered the missing voltage regulator so i could use 3V cpus. Plugged in my DX2-80 but found it trippling the clock. Stason only has Sy-25j/k/l jumper settings and mine is a bit different.
Found that this dx2 uses another pin for clkmul than most other cpus, so i did the job using this magic blue cable to get gnd... 😀
The attachment WP_20190317_005.jpg is no longer available
Reply 11348 of 31478, by OldCat
henryVK wrote:
Ordered all the stuff that I need in order to replace the LCD on my luggable 5x86: […]
  • LCD driver board
  • VGA 90° adapter
Out of curiosity, which luggable would that be? I seem to have missed it.
Reply 11349 of 31478, by Mister Xiado
Replaced the left mouse button microswitches in all of my Microsoft Optical Wheelmouse mice. No more bounce-clicking or dead button issues.
Reply 11350 of 31478, by Jed118
I finally got to enjoy the desk I built for my 386s with some Monkey Island (a game I never played) - It took some effort to get the game on the SX; first I tried putting the CF card in, BIOS would not take to it correctly, but DOS would see it, however I could not copy files from it. I seem to recall that CF cards, in my experience, do not play well with WD Caviar drives, seemingly all the way back to an 85 MB drive... I took the CF card to my 233 MMX and copied the Monkey Island files to the internal IOMEGA ZIP, then had the fun time of getting the driver onto the 386 from a CDROM. I used my 486 to copy the DOS drivers (guest.exe) to a diskette, then fetched the external ZIP drive, and... ran out of space to install the drivers on the 85 Mb drive on the destination computer! Hah, so I had to make 4.5Mb available on the drive.
I was instantly thrown back to my pre-teens, program-shuffling and data managing a 42 Mb drive. Same problem, quarter-century later. As it stands, with two save files, I have 56kb free on the hard disk. Monkey Island sounds bloody amazing through the Radlib on my 5.1 setup (granted all mono) with the sub.
I went to take a picture of the setup with my camera just now and I dropped it. Fucked it right up. So, low res smartphone pic of setup:
Good weekend, folks.
What's for sale? my eBay!
Reply 11351 of 31478, by Jed118
McBierle wrote:
Still working on trying to get the data of an old ST-251-1 MFM hdd. […]
That's some good modding. I am no stranger to "omitted" upgrades on a low-spec'd board 😉
At least Stason had something for your board - I am still unable to find anything for my 3486 EISA board.
Reply 11352 of 31478, by twilliamc
The attachment 20190312_185030.jpg is no longer available
More diagnostic on the Vendex Turbo-888-XT. I might be in over my head on this one and this thread is probably not the place for all the questions I have posed. In a previous thread I was informed the dimming of the CRT during floppy (attempt to) seek was likely due to a failing PSU.
Edit: I am dumb. My spare PSU has the same pinout and works.
Is there a good way to diagnose a Floppy controller? I had corrosion on the pins which I cleaned up. As far as I can tell, the cable and header pins on the board are all clean now. The drive works in another PC and the dip switches appear correct, but the head never even budges when the LED is on. Also, the second drive will not light up after the first (do XT/XT clones even attempt to read the second drive after the first?)
Unnamed: 486DX4 @ 120MHz, 16MB, 2GB, 2MB VGA, SBPro 2.0, DOS/W3.11, W95
PC-65:P3 @ 800MHz x2, 512MB, 128GB SSD, Voodoo3, SB Live!, Win98SE
Reply 11353 of 31478, by henryVK
It's muh plucky little clone portable 😀
xOjAFW3.jpg?2
It doesn't really have a name yet.
Are there any naming conventions when it comes to "real" computers? Fictional computers seem to be overwhelmingly male or neutral, thought there are some "girls" like HAL's twin SAL from the space oddysee books.
Reply 11354 of 31478, by SpectriaForce
blurks wrote:
Searching for older graphics cards can be a tedious task, especially considering most of them seem to hide in a huge pile of mod […]
With that query you will eventually miss out on some interesting AGP (and maybe a few PCI) graphics cards. On what website do you use this?
Btw, it sucks that ebay search doesn’t understand the difference between PCI and PCIe when I enter PCI.
Reply 11355 of 31478, by FuzzyLogic
I was bored yesterday so I took motherboard photos to make desktop backgrounds. Next time I need to clean the dust off better and get some focus stacking software.
The attachment aopen_2560.jpg is no longer available
Reply 11356 of 31478, by Katmai500
I cleaned up a sweet IBM Model M that I recently found in my in-laws' basement. I'm super happy with how well this keyboard cleaned up. I've never owned a Model M before! 😁
Please pardon the placement of the Windex bottle. I didn't use it on the keyboard. I used warm soapy water, microfiber towels, q-tips, and a magic eraser. I didn't let any water get on the steel back plate.
Before shots:
The attachment IMG_1604.JPG is no longer available
The attachment IMG_1606.JPG is no longer available
The attachment IMG_1607.JPG is no longer available
The attachment IMG_1605.JPG is no longer available
The attachment IMG_1615.JPG is no longer available
Reply 11357 of 31478, by Katmai500
Cleaning shots:
The attachment IMG_1612.JPG is no longer available
The attachment IMG_1620.JPG is no longer available
The attachment IMG_1624.JPG is no longer available
The attachment IMG_1635.JPG is no longer available
The attachment IMG_1629.JPG is no longer available
Reply 11358 of 31478, by Katmai500
All cleaned up!
The attachment IMG_1647.JPG is no longer available
The attachment IMG_1648.JPG is no longer available
The attachment IMG_1646.JPG is no longer available
The attachment IMG_1651.JPG is no longer available
The attachment IMG_1654.JPG is no longer available
Reply 11359 of 31478, by blurks
Query doesn't suppress PCI/AGP graphics card that are of interest to me.
