First post, by AlessandroB
Use as a retropc a single board computer supersocket7 with a Pentium233MMX. Unfortunately the socket is not ZIFF (but the CPU is replaceable) and if I wanted to change the CPU I don't know how to fix the heat sink of the new CPU (a K6 for example) because in the socket there is no way to hang it. How can I do? Thank you.
