First post, by Demonslayer2103
hello i just have a quick Question about using a pci USB 2.0 card with internal usb 2.0 type a Jack on the pci card itself. i tried to buy a adapter to convert the pin connector for my front usb jacks that came with the case to a usb 2.0 type a plug for the pci usb 2.0 card but the device i tried to plug in did not show up in windows i tried a usb flash drive that was it from what i remember and the os i was using is windows 98 se and i had the USB flash driver installed my i have a usb 2.0 hub i installed that a got from ebay and that works fine in that usb slot on the pci card. if you need the model of the pci usb card or and other info let me know. thanks for the help and reading this 😀
Reply 1 of 17, by Intel486dx33
You need to check the USB cable pin correlation. Some motherboard are different.
Check your manual and google it.
I had this same problem before.
I just had to switch the wires around on the cable and it worked.
    5.2 KiB
    26.82 KiB
Reply 2 of 17, by Demonslayer2103
Intel486dx33 wrote:
You need to check the USB cable pin correlation. Some motherboard are different. Check your manual and google it. I had this sam […]
im talking about using a my front panel usb on a pci card since my motherboard doesn't have onboard usb header for the front panel to work
Reply 3 of 17, by Intel486dx33
Try the USB update for Win98.
This worked for me.
Google Search for "NUSB.exe"
http://www.technical-assistance.co.uk/kb/usbmsd98.php
Reply 4 of 17, by cde
I would recommend taking a type A male cable, cut it and solder the connections to male 2.54mm headers. Make sure D+ and D- stay the same length.
Although I did not try this hack yet, I did a similar one to get the front panel AC'97 connected to two audio cards (one ES1868F and one Audigy 2 ZS).
Reply 5 of 17, by Onyx Jaguar
I remember having this issue as well. I'll give the USB update a shot, as my PCI card has the headers but I haven't been able to get either the front or back ports to recognize devices despite showing up in Windows 98.
Also, are there any PCI FIrewire/USB 2.0 combo cards that have inputs for front panel connectors?
Reply 6 of 17, by Demonslayer2103
this is what i used to to convert the connector is this what you mean
https://www.ebay.com/itm/332407752005
Reply 7 of 17, by Demonslayer2103
are you able to give me the model of your usb pci card i really just want one with the headers instead of having to convert the front panel
Reply 8 of 17, by Onyx Jaguar
I cant confirm that it works, but the card I have is a Startech PCIU587. The header is on the bottom of the card, while another USB is on the side (which I've seen on a number of USB cards).
Reply 10 of 17, by Demonslayer2103
Here is a driver for that chip on your usb card it might help here is a link
http://download.viatech.com/DownloadDriverSvl?driver_id=2105
I got the driver from the post I read from here:
Which USB 2.0 cards for old motherboards
Have a read it might help you out
Reply 11 of 17, by PC Hoarder Patrol
Onyx Jaguar wrote:
...are there any PCI FIrewire/USB 2.0 combo cards that have inputs for front panel connectors?
Something like this https://www.ebay.co.uk/itm/USB-2-0-Firewire-C … b-/380294254955
Guess you could either use their hub or plug your front panel connectors onto the cards own pin header block.
As far as the OPs usb problems, I've used those types of adapters numerous times without issue - am wondering if the front panel connectors are properly matched to the pinouts on the adapter,
Reply 12 of 17, by cde
Correct I was thinking exactly of that! Had no idea this existed, now I probably will buy a couple 😀
Reply 13 of 17, by cde
My KT7A has a USB 1.1 header on the motherboard that has a different pinout than the classic USB 2.0 header that came to replace it.
Basically GND and Vcc are switched, and also the key is swapped one place (fortunately).
So what I did was to turn the connector 180 degrees and shifting it by one. This connects Vcc with Vcc and GND with GND.
However D+ and D- are now inverted. Nonetheless this hack appears to work (USB devices get recognized). Perhaps some kind of automatic D+/D- swapping exists, like what you seen in modern gigabit ethernet with straight and crossover cables?
Reply 14 of 17, by dr_st
Heh; this kind of crap was why some cases had USB front panel headers with all the pins separated into individual wires.
Interesting to know.
Reply 15 of 17, by Onyx Jaguar
Something like this https://www.ebay.co.uk/itm/USB-2-0-Firewire-C … b-/380294254955 […]
Yep, that definitely looks like it, I'll have to track down the part number. Excellent
Reply 16 of 17, by Onyx Jaguar
Here is a driver for that chip on your usb card it might help here is a link […]
I'll go ahead and give that a go as well, see if I can get the USB up and running
Reply 17 of 17, by Matth79
If the port works directly, then it's the cable conversion that's the issue, looks like the cable does a "normal" of +5, data pair, 0V and probably screen ground - the 5th pin if used tends to be either screen ground or overcurrent.
One A to header connector will only liven one of the front ports
