Reply 340 of 543, by Rio444
Yes, I tested the mod with 286.
It works.
Reply 341 of 543, by maxtherabbit
It work.
thank you for the response, does the version of PS2SUPPC.COM you posted in this thread also run on the 286?
Reply 342 of 543, by Rio444
Yes, it does.
Both versions was compiled to use only 286 instructions without 386 ones.
Reply 343 of 543, by maxtherabbit
I drew up an interposer PCB in Kicad to make this a little cleaner. If you have the existing keyboard controller socketed, and NOT under the ISA slots, it should work great as a totally plug and play mod. Here are some renderings - I'm going to do a final review of the design then send it off to fab this week.
If this setup is too tall for your application, you could build it by soldering the keyboard controller IC directly to the PCB, using different pin headers, and trimming everything short after it's soldered. That would get the overall added height to around 3mm or less.
Credit to Rio444 for the schematic upon which this was based. Once I get it tested, it will go up on OSHPark if others are interested.
Reply 344 of 543, by maxtherabbit
the PCB works - here's the OSH park link if anyone would like one:
https://oshpark.com/shared_projects/1rUdxa5p
the pinout for the PS/2 header is the one on the right in this photo (because that matched the 3 dongles I had laying around)
I believe this is the Acer/Asus spec
Thanks again to Rio444 for the schematic and PS2SUPPC software, this mod works perfectly on my 12MHz 286 (the keyb controller that came with the mobo didn't work, but I swapped it for a spare AMI 'F' chip and it works a treat
Reply 345 of 543, by maxtherabbit
Something interesting I noticed - not sure if it was swapping keyboard controllers or the mod itself, but my key lock doesn't lock the keyboard anymore on the 286
I know the lock worked before because I tested it, and now when you lock it nothing happens. Not complaining, since the lock is practically useless, but I thought it was interesting to note.
I went ahead and buzzed out the connection from the physical lock switch to pin 34 on the keyboard controller (Keyboard-Inhibit) and verified that the pin is properly being pulled low when the lock is locked, but the keyboard controller just is not acknowledging the inhibit pin as being asserted.
Could someone else who has an AMI MEGA-KB-F-WP being used in PS/2 mode test locking the keyboard please?
Reply 346 of 543, by keropi
I came to the conclusion that kbc are different or they need different passives/specs to support them.
I have boards that just won't boot with the VIA kbc - no mods installed just kbc replacement.
Try another one if you can and see what happens.
Reply 347 of 543, by maxtherabbit
in this case I don't believe it is a passive or routing issue - the donor board that I pulled the MEGA-KB-F-WB from also has the pins for the keylock header wired one directly to ground and the other directly to pin 34 on the KBC socket
my guess is that changing to PS/2 mode makes the controller either disregard the keyboard-inhibit signal or, perhaps even more strangely, look for it to be asserted on a different pin
Reply 348 of 543, by maxtherabbit
so both of the AMI 'F' KBC I have (one marked MEGA-KB-F-WB and one marked KB-BIOS-VER-F) will respect the keyboard inhibit line when plugged directly into the motherboard socket, but when run through the interposer PCB they just ignore it
I verified that the interposer is passing pin 34 straight through without shorting it to anything else, so the only other remaining explanation is that when the KBC detects PS/2 keyboard mode, it decides to ignore keyboard-inhibit being asserted on pin 34 (or maybe requires a register bit set to support it)
odd, but hey I got an optical mouse on a 286 so who cares
Reply 349 of 543, by feipoa
I have noticed that some boards with PS/2 support have things like turbo switch input pins and or polarity set differently. There is also a KBC type setting in the BIOS, but I don't know much about this.
Maxtherabbit, do you have a BOM with part numbers? I might try to assemble one of your units. When I assembled Rio444's unit, I was unable to get it to function for some reason. I used desoldered SMD transistors, perhaps one was bad...
Reply 350 of 543, by maxtherabbit
Q1-Q3 MMBT3904LT3G
R1,R3,R5,R6 ERA-6AED472V
R2,R4 ERA-6AED202V
C1,C2 CL21B221KBANNNC
KBC Socket DILB40P-223TLF
Pin Headers to MB 350-80-120-00-001101
All passives are 0805, any 4.7k/2.2k resistors and 220pf caps will work.
For the KBC Socket any DIP-40 socket will do, and all the other pin headers are standard 2.54mm Berg
Reply 351 of 543, by feipoa
Thanks.
How proficient are you with KiCAD? Would you be interested in drawing up this little project? Custom interposer module for TI486SXL2-66 PGA168 to PGA132 - HELP! Someone else started on it then vanished.
Reply 352 of 543, by maxtherabbit
feipoa wrote:
Thanks.
did you ever get the schematic file from him? routing out the board is the easy part
Reply 353 of 543, by feipoa
You'd probably have to read the thread. Its been so long and my life rather chaotic that I'm starting to forget things. That guy had the false impression that he could make a multi-purpose 486-to-386 interposer module in this manner, and I think he lost interest after realising this type of passive interposer will only work with the SXL series of CPUs. It is a fairly straight forward translation, with much of the questions all worked out in the thread. I sort of recall him having some incorrect routings with a few pins, but (memory?)... I also recall there being some aspect too complex for him - perhaps related to 3+ layers and vias (memory?).
Unfortunately, it is wishful thinking to think that I will ever be able to enjoy the time to learn KiCAD with three screeming and foul tempered children around me constantly.
In vintage computing and collecting, a common theme or goal is to completely max out a given platform. Hot items are the 386's and 486's. Without entirely turning a 386 into a full fledged 486, the ultimate [stable] upgrade is the TI486SXL2-66 run at 80 MHz (2x40). The only device produced in this form factor was by Evergreen and is exceedingly rare. Hence the interest in this custom interposer.
Reply 354 of 543, by maxtherabbit
anyone have any experience with a NEC D80C42C250 keyboard controller? can't seem to find a datasheet for it
it came preinstalled in my Everex Tempo 386sx, I tried swapping it with an AMI Megakey and while the keyboard input works the BIOS gives KBC error and the machine is stuck in non-turbo mode
(the only way to toggle turbo on this machine is a keyboard shortcut ctrl+alt+minus or ctrl+alt+plus)
I assume the NEC KBC has some custom code in its ROM to handle the turbo toggle, question is can this KBC support PS/2 mode? (I kinda doubt it)
Reply 355 of 543, by Tiido
The turbo function will be controlled by one of the GPIO pins on the controller and you should be able to find it with a multimeter easily. Measure all pins and toggle turbo, eventually you'll find a pin that changes state with the turbo. Isolate it and wire it to traditional pushbutton, swap in a new KBC and that problem has a solution.
Reply 356 of 543, by maxtherabbit
that may well let me force turbo on, but at least something else is an issue since the BIOS was reporting a KBC error
Reply 357 of 543, by feipoa
I thought I'd provide a brief update. If you recall, for AWARD 4.50 and newer BIOSes, we can use MODBIN to add BIOS support for PS/2 mice. But for AMI BIOSes, we don't have the MODBIN equivalent program AMIBCP, which is very version dependent.
Vogons user jakethompson1 figured out a way to disable the checksum on these AMI motherboards via a BIOS hack and to also enable PS/2 mouse support [in the BIOS]. As such, I no longer need to use Rio444's TSR, PS2SUPPC.COM, to enable PS/2 mouse support in DOS. I also no longer need the a NTDETECT.COM file for PS/2 mosue support in NT4 and NT3.51 on AMI boards which have a hacked on PS/2 mouse via the keyboard controller.
He is also able to unhide AMI BIOS features which includes more than what is available in AMISETUP.
Reply 358 of 543, by maxtherabbit
feipoa wrote on 2020-08-31, 10:33:
that sounds awesome, can we get the details on how to implement it ourselves please?
Reply 359 of 543, by feipoa
Best for user jakethompson1 to discuss that. I don't know how seamless it is to transfer the findings to other BIOSes. I think he had to review the BIOS in assembly code.
