ZIDA 4DPS – the story of repairing
First post, by winuser_pl
I've bought the Socket 3 motherboard. It is ZIDA 4DPS model. The seller told me that he didn't checked the condition of the board but I suppose he knew that someone has already tried to fix it up.
Here is the photo of the board when I bought it:
I got this for 40 zł which is an equivalent of 11 $. As you can see there are many problems.
Here is the list of problems:
1. unpopulated L2 cache – I've already bought the chips.
2. Melted jumpers
3. missing TIP32C transistor and capacitor
4. leaked battery – someone has already removed it
5. missing two ceramic capacitors and burnt traces
6. Unpopulated tag RAM – already bought – waiting for delivery
I've already taken care of some of that problems like:
Melted jumpers – the plastic jumpers has been removed. A new jumpers will be put.
TIP32C transistor replaced, capacitor populated.
There is a problem with battery. As far as I understand the motherboard wil try to charge the battery so I should use diode.
The second problem is I don't if I can use 3V CR2032 battery?
And the final problem: there is missing a trace – see the picture. I don't know where is the start of that trace - probably one of the ceramic capacitors.
What do you guys think, will it be possible to fix it up?
PC1: Highscreen => FIC PA-2005, 64 MB EDO RAM, Pentium MMX 200, S3 Virge + Voodoo 2 8 MB
PC2: AOpen => GA-586SG, 512 MB SDRAM, AMD K6-2 400 MHz, Geforce 2 MX 400
Reply 1 of 33, by Kubik
A piece of wire should do it. I would recommend to check the datasheet of the chip, it might give you a clue what to connect here.
Is that the board from Aukro?
Reply 2 of 33, by winuser_pl
It has been bought on allegro.pl
Does anybody have such datasheet here?
Reply 4 of 33, by winuser_pl
No, did not tried yet. Will it work even without tag ram?
Reply 6 of 33, by Kubik
It will not work without tag RAM but it will work without all cache.
Reply 7 of 33, by winuser_pl
Ok, then I have to wait for it. Tag ram should be received this week. 😀
TAG RAM chip is MT5C2568-20 MICRON 9245 DIP28 which is 32K x 8 SRAM SRAM MEMORY ARRAY.
L2 cache is 4 x UM61512AK-15 (64K X 8 BIT HIGH Speed CMOS SRAM).
I plan to upgrade L2 to 512 KB if the board will work with 256KB.
Reply 8 of 33, by keropi
how come it will not work without the tag ram?
cacheless motherboards don't have tag rams, I can remove all cache+tag on my 486 boards, adjust jumper settings for 0kb cache and they work
is this a special case?
Reply 9 of 33, by winuser_pl
I received this TAG RAM chip. Will check if the motherboard will work with and without TAG RAM and let you know guys 😀
Reply 10 of 33, by winuser_pl
I tried to boot this motherboard but with no luck 🙁 The CPU is going hot but nothing more happens. Even the transistor radiator near CPU is cold (I've put a new transistor).
It wont boot with TAG RAM and without it.
There are couple things to think about:
* the motherboard has no battery - can I use CR2032?
* it is missing L2 cache - there is no jumper setting in the manual for no L2 cache so I had to configure it for 256KB
* maybe BIOS is dead? It is EPROM memory (here it is https://www.alldatasheet.com/view.jsp?Searchw … d=27C010A-12&mo ) - maybe I need to reprogram it?
I'm thinking also about buying the ISA BIOS POST CODE diagnostic card. Something like that -> https://pl.aliexpress.com/item/1-Pc-PCI-i-ISA … 2833265903.html Maybe it will help me with diagnose the boot problem.
Reply 12 of 33, by winuser_pl
Ok, will give a chance tomorrow.
Reply 13 of 33, by winuser_pl
I just discovered that the chipset legs are burnt and probably needs to resolder it. The chipset is probably dead. The whole motherboard is dead as ****.
The battery did not helped - still not booting. 😀 Someone who sold me this as "not verified condition" had a very good time 😀
EDIT: Does anybody know where I can get brand new SIS 85C496 chipset 😀 ? 🤣
Reply 14 of 33, by TheMobRules
UTSOURCE is a good option:
https://www.utsource.net/itm/p/6632666.html
Reply 15 of 33, by Kubik
There's certain moment when reviving something stops being worth your time. Unless you have good reason to spend more time and money on this, I think you've reached the moment 😀
There still are 486 PCI board available. I must know it, I purchased one on eBay last week.
That diagnostic card is a must for everyone who even considers purchasing an old mainboard!
Reply 16 of 33, by winuser_pl
Yeah thats true but show me such board! There are plenty of socket 3 mobos but they are sold at very high price > 100 $ incl shipping to europe it will be 130$
Reply 17 of 33, by Kubik
I bought one locally in Germany together with three VLBUS ones for like 40 EUR... just be patient.
Reply 18 of 33, by winuser_pl
I've spoken through email to the company that specializes in soldering PQFP chips and I'm waiting for the price. But probably it will be better to buy a working motherboard. It will be cheaper and I got 100% sure that it is working.
I'm not sure if replacing the chip will cause that the motherboard will work.
Reply 19 of 33, by treeman
its hard to see on the picture but the 496 chipset looks like has some bridges on top of R61 but can't see any burns, send us a close up pciture
