512mb CF card cylinder values ?
Reply 40 of 44, by user33331
CD-drive gives an error similar like: "unable to load driver", "no driver found".
What is the driver for ESS 1869F IDE CD-driver ? ( Oakcdrom is probably a different sound card ? )
F-Prot 3.16F(2006) found no viruses on 3.5" diskettes:
+ Had to put 2005 year to BIOS otherwise said "outdated virus database unable to start".
+ Don't know why the sudden corruption and all data loss ?
WD SSD-C51MI-3800 512mb SiliconDrive CF-card 2013:
- Fixed & Removable disk mode. ( ="Automatically changes and identifies when connected". )
- Multiword DMA enabled. ( What does this mean ? Could this cause corrupted data ? )
Reply 41 of 44, by Jo22
I'm sorry, I don't understand. I'm confused.
Maybe your cards has a special IDE port that needs an enabler utility, okay. I accept that fact, but..
https://www.philscomputerlab.com/ess-audiodrive-es1868.html says this type of soundcard has a bog-standard IDE/ATAPI interface.
The datasheets for your model says the same. LINK
Oakcdrom.sys does usually work with any IDE/ATAPI compatible interface and any IDE/ATAPI compatible CD-ROM drive.
That's why Microsoft made it the default IDE/ATAPI CD-ROM driver of the Windows 98 Setup CD.
    32.89 KiB
Reply 42 of 44, by user33331
Where is a reliable place to download OAKCDROM.SYS ?
( Or is it a default program too in Dos6.22 and/or Win3.1 ? )
CONFIG.SYS
DEVICE=C:\ES1868.COM /A:170 /I:9 ( ENABLE IDE-PORT )
DEVICE=C:\DOS\OAKCDROM.SYS /D:MSCD001 ( CD-ROM DRIVER )
AUTOEXEC.BAT
C:\DOS\MSCDEX.EXE /D:MSCD001 /V /L:D ( START D:\ DRIVE )
/V = Verbose mode.
/L:D = Set drive to "D".
+ If I have 2 pcs CD-Rom drives how to input both D:\, E:\, Master and Slave ?
1st CD-drive master D:\.
2nd CD-drive slave E:\.
DEVICE=C:\DOS\oakcdrom.sys /D:mscd001
DEVICE=C:\DOS\oakcdrom.sys /E:mscd002
C:\DOS\MSCDEX.EXE /D:mscd001 /L:D
C:\DOS\MSCDEX.EXE /E:mscd002 /L:E
Thanks
Reply 43 of 44, by Rawit
Can you try DEVICE= C:\AUDIODRV\ES1868.COM /A:170 /I:F instead? I'm assuming that you are assigning IRQ 9 to the IDE port and it might not be available. Quick Google show me that an additional CD-ROM driver like OAKCDROM isn't needed.
YouTube
Reply 44 of 44, by Jo22
Please define "reliable place". 😉 You're asking for ~25 year old software.
OAK and Microsoft surely do nolonger host this software on their offical servers or BBSes.
Partially, yes. MSCDEX, the MS CD-ROM Extension, was included with them.
But not the CD-ROM driver in most cases. In these days, before IDE/ATAPI became standard,
it was common practice for each CD-ROM drive manufacturer to provide its own.
I believe, the most secure source nowadays is the original Windows 98SE CD-ROM with the hologram that you have got in your cup-board.
Or more precisely, the 3.5" 1,44MB MS-DOS Start-Up disk which Windows Setup creates.
(The CD-ROM used El-Burito err "El-Torito" format and contained a fake 1.44MB image one of the tracks.)
That being said, Windows XP also had the ability to create an Win Me Start-Up disk, with MS-DOS 8.0, I believe.
It did use a RAM disk, though, so it's perhaps not so easy to extract (on a modern PC).
Unless you boot it on your old PC and manually copy the oakcdrom.sys to c:.
Unsecure sources:
http://pcem-emulator.co.uk/phpBB3/viewtopic.php?t=3083
https://www.hiren.info/downloads/dos-files
DOS CDROM drivers
http://www.vcfed.org/forum/showthread.php?171 … 1-CD-ROM-driver
Re: How do I set up a CDrom in MSDOS 6.22?
Anyway, good luck! 😁
