First post, by retropol
hi,
can you help me what are better for my setup?
what is your suggestion...
252.04 KiB
270.1 KiB
249.49 KiB
287.88 KiB
252.77 KiB
Reply 5 of 7, by treeman
try a different cpu if you have one, or at least remove and reinstall. I have had alot of cache and some ram errors on a faulty cpu socket before, reseating cpus would give different results which helped diagnose a socket problem
Reply 7 of 7, by chinny22
the last number on the chips are the speed.
So you have a mix of 60 and 70ns Ram, faster is better so 60 are the more desirable.
The Topless (hehe) simply has a sticker telling you its 60ns
So use that first, but if that doesn't give you enough (say 4MB, I wouldn't have a problem adding a 70ns simm
