Reply 12340 of 31262, by retardware
imi wrote:
it's as if they used a universal switch size for PCs or something 🤣 direct screw-in replacement.
Yes, these red IBM style switches were commonly the same on the original and (almost) all clones and are interchangeable.
Reply 12341 of 31262, by oeuvre
whipped out this pinout, maybe it's useful for others? Might work for similar era Optiplex models like the GX1 or GX100
Reply 12342 of 31262, by imi
so... I was sorting through some cpus and was wondering about this... "pentium"? wait... weren't the black s370 cpus only celerons?
The attachment slot370_01.jpg is no longer available
umm... wait what 😕
The attachment slot370_02.jpg is no longer available
wha... I checked pictures online, that hole is definitely not there by default... like... who does that 😐
The attachment slot370_03.jpg is no longer available
the cpu pins seem fine 😕 so either someone purposefully poked a hole into the socket to make the cpu "fit" or that plastic is really weak and got punctured by the pin... I wonder if anyone tried actually using it like this... and what happened.
Reply 12343 of 31262, by bjwil1991
Installed the Lite-On DVD burner I repaired in my Socket 370 system and it took a while to get it detected. After switching the jumper to slave and the LG CD burner to master, the drive works without any issues. Tested it with some DVDs I made and they work without issues. I still need to fix the other DVD drives that cannot read either anything or DVDs, except for CDs for that matter (lenses are dirty).
Reply 12344 of 31262, by appiah4
oeuvre wrote:
https://i.imgur.com/1WGESHal.png […]
Useful to me, thanks.
Reply 12345 of 31262, by dorkbert
I repaired a trace destroyed by bleeding battery on a Soyo 4SAW2, then solder on a coin battery holder in place.
Reply 12346 of 31262, by bakemono
At least the CPU and slotket didn't go up in flames. Interesting mod though 🤣...
GBAJAM 2024 submission on itch: https://90soft90.itch.io/wreckage
Reply 12347 of 31262, by derSammler
Built this for use in my Amiga 2000 with a 286 bridge board.
The attachment IMG_20190719_135545575.jpg is no longer available
Reply 12348 of 31262, by asurin
Fixed my 386 after I broke the system.ini file while trying to get a mouse to work in windows 3.1/Dos 6.22.
Working on getting a cd drive working rather than deal with that mouse for a while.
Reply 12349 of 31262, by oeuvre
Glad someone found it useful.
Reply 12350 of 31262, by BSA Starfire
Got my 486 rig back on it's feet, the original 260 MB maxtor had crashed(head had come off) and one of the 4MB RAM sims was bad, all happy now with a replacement of both.
The attachment DSC_0081.JPG is no longer available
The attachment DSC_0082.JPG is no longer available
This is not a bad little machine despite not having any cache installed, it has UMC chipset, Cirrus 5430 and Intel 486 DX/2 66 WB CPU, obviously not the fastest 486 out there but good enough even for windows 95.
glad to have her up and running again.Speed test gives 236979.
Reply 12351 of 31262, by bjwil1991
Is that a Sony CD drive or an early Panasonic? Good looking system. My $17 Packard Bell went through upgrades or feature installations: sound cards, CD-ROM drive, dual floppy drive, tape drive that connects to the floppy controller, HDD upgrade from the old, still functional 428.1MB Seagate HDD to 4GB CF card, memory upgrade from 8MB to 32MB (2x 16MB and the 4MB onboard is disabled), video RAM upgrade to 2MB (Cirrus Logic 5428), L2 cache from 0K-512K, CPU upgrade from SX2-50 to DX5-133 16K L1 WB, BIOS upgrade, and additional board features: 3.3V CPU support and a battery slot to insert a CR1220 battery.
Going to hook up the 10GB Western Digital to the secondary channel and force a drive letter change to E for storing my data on there as a backup system and do a file copy from my main laptop to copy those files and folders in case the HDD starts to go.
Here's a photo of the beast:
Reply 12352 of 31262, by Mister Xiado
Windows 95 system icons are done. The readme contains instructions for setting the icons. I may make a host of random drive icons (Zip, tape, MO, whatever) just to fill up a second set.
In action:
Reply 12353 of 31262, by gdjacobs
bjwil1991 wrote:
Is that a Sony CD drive or an early Panasonic? Good looking system. My $17 Packard Bell went through upgrades or feature install […]
I love that combo drive.
Reply 12354 of 31262, by bjwil1991
Steve Ballmer's voice: How much did I pay for this? $500, $1,000, even more? NO! Got it for free 3 years ago.
Could use a good head cleaning on both the 3.5" and 5.25" as they can read almost every diskette, except Disk 2 of Civilization gets stuck on 1 file and the other files get copied onto my hard drive without issues and Mickey's Fun Time Print Kit also gives me a message about a bad sector, but the diskette works in my other computers with a 3.5" diskette drive. I could get another one for my Pentium 1 and K6-2/300 builds.
Speaking of retro activity, I modified my Super GameBoy to have it where the speed matches the GameBoy DMG-01, Pocket, and Color speeds. Before, the sound/music was at a higher octane than the GameBoy systems and the games were a bit too speedy.
The device I bought is quertymodo's Super GameBoy Clock Mod v2.2 on Tindie and soon, a Game Link Port mod will be installed.
I thought my soldering job was bad, but, it turned out to be fully functional and a good/sufficient amount of solder was in place and after installing the cartridge into my SNES and Donkey Kong 1994, I was happy the way it turned out. Another good thing about the mod, if I find a Hori SNES Super GameBoy controller, I can increase or decrease the speed easily.
Link to the video: https://www.youtube.com/watch?v=HV-uK4S6XQI
Video is up now. I also opened my SNES (needs a new top shell now as 3 of the screws are stuck in there as the plastic broke off somehow) to remove the pieces of plastic that were stuck inside the system and did a thorough inspection of the logic board and no bad caps, traces, and everything still looks pretty good.
Reply 12355 of 31262, by Mister Xiado
Figures, as soon as I make a set of icons specifically for Windows 95, I figure out how to force it to display icons in higher bit depths.
Reply 12356 of 31262, by bjwil1991
I'm planning on using that on my Windows 95 machine. Will it work with 98/98SE?
Reply 12357 of 31262, by Mister Xiado
Works from Windows 3 all the way through Windows 10. Also, Win98 doesn't make it quite so difficult to change your desktop icons, as you can do it from the display menu rather than having to manually type up a bunch of registry data. To change your drive icons, you still have to. That is, if you want icons specific to drive letters, without having to doof around with autorun.ini and the like. Instructions are in the readme. For the record, to enable high color icons in Windows 95:
Open regedit, go to HKEY_CURRENT_USER\Control Panel\Desktop\WindowMetrics Add the string "Shell Icon BPP", and set its value to […]
Open regedit, go to
Add the string "Shell Icon BPP", and set its value to 16.
Log off, and back on, and all icons with color depths greater than 16 colors, will now display in higher color depths.
Reply 12358 of 31262, by oeuvre
I prefer the 16 color icons in Windows 95. But I'm also a madman so...
Reply 12359 of 31262, by keenmaster486
As one of the only two remaining computers in the house with a CD drive, my upgraded and customized IBM Thinkpad 600E saw some good use yesterday evening as my GF and I listened to an audiobook =) Battery (the one I rebuilt) lasted through both CDs! This is why I repair old computers - so they can fulfill their purpose again.
World's foremost 486 enjoyer.
