Reply 29760 of 53124, by Vegge
Package opening time 😀
Interesting packaging
1.01 MiB
Seller even built a woodframe to support it.
1.14 MiB
ESD bags, a welcome sight.
1.11 MiB
First motherboard, Tyan Thunder 2500. Dual slot 1 with support for 8gb sdram 😳 . It came with dual P3 733 and four sticks of 128mb RAM.
1.27 MiB
Second motherboard, Supermicro P3TDE6. Dual socket 370 with Tualatin support.
1.38 MiB
Both motherboards have AGP Pro and both 3.3V and 5V PCI-X slots. I need to get some chassis, beefy ATX PSUs and some more ECC REG sdram. 😎
Should be fun playing with.
Reply 29762 of 53124, by bjwil1991
Dude, I'm jealous. The seller did a fantastic job protecting the boards and CPUs.
Reply 29763 of 53124, by imi
nice packing job and nice boards ^^
I received my first desktop case system today... the seller tried really hard to pack it well, lots of padding all around... unfortunately components in the case weren't screwed down (checked the original pictures, and yup no screws) so stuff got rattled around a bit... A for effort though 🤣
didn't spot any damage at first glance though so all is well.
most packages I get are just parts thrown in a box usually.
Reply 29764 of 53124, by Vynix
If I'm not mistaken, the Supermicro board has built-in ultra-wide SCSI, more precisely, ULTRA160 SCSI, not too shabby if you like tinkering with SCSI (well just set the IDs and termination correctly and the rest will go buttery smooth, I guess)
Amazingly, Supermicro seems to still have the drivers on their server (should I download them to get them backed up on Vogonsdrivers?) : https://www.supermicro.com/products/motherboa … SL/P3TDE6-G.cfm
Reply 29766 of 53124, by Daniël Oosterhuis
Got a time appropriate waterblock for a planned Athlon XP build. It's a Nexustek H2O-2000, one inlet/two outlet waterblock for Socket A, 478, and 939. It has additional mounting hardware for the latter two, but with Socket A only needs to be screwed on. It does have some crud in the block, but that might be copper oxidation which isn't a huge problem. Either way, I'm going to look into what I can use to flush and clean the block with, then do a leak test on it, letting it run on a closed loop with a pump and reservoir (combo) above some sort of tub.
The block comes with a Y-splitter that you're supposed to put the two tubes coming out of the outlets on, but I plan on doing it a bit different. I want to liquid cool both the chipset and graphics card along with the CPU, so what I'll do is have one outlet run a tube to the chipset block, the other oulet a tube to the graphics card block, then have the two outlets of those meet at a Y-fitting at the reservoir or pump.
The Nexustek block cost me €7,50, so not too terrible if it ends up leaking, then it'll just be a neat showpiece 😵 🤣
Image removed for copyright reasons.
Reply 29767 of 53124, by vetz
jaZz_KCS wrote:
I did it again! (Dumbness strikes again!) […]
Instead of replying to a post by Tiido, I have accidentially reported it!
This is the third time this happened to me, I really should take more caution.
To the Staff: Please ignore/delete my recent report filing of Tiido's reply. It was a mistake.
No worries, you're not the first to make that mistake. It happens quite regurlarly
Reply 29768 of 53124, by Intel486dx33
Vegge wrote:
Package opening time :) Interesting packaging [/attachment] Second motherboard, Supermicro P3TDE6. Dual socket 370 with Tualatin […]
[/attachment]
That thing is a beast. Ultimate P3 motherboard for sure.
Reply 29769 of 53124, by jaZz_KCS
[/attachment]
I can see a valid usage scenario for one of these. Think audio production. Even back then, a few VSTs here and there filled up what otherwise would have been standard for a casual user (1-2GB) easily.
Reply 29770 of 53124, by MKT_Gundam
I got this Asus MEW-AM
Stil very dirty
Sadly this mobo dont support Tualatin or 1ghz P3 coppermines.
The MEW (non AM) has isa slot
Retro rig 1: Asus CUV4X, VIA c3 800, Voodoo Banshee (Diamond fusion) and SB32 ct3670.
Retro rig 2: Intel DX2 66, SB16 Ct1740 and Cirrus Logic VLB.
Reply 29771 of 53124, by JonathonWyble
Vegge wrote:
Package opening time :) Interesting packaging […]
Man, that's a lot of miscellaneous stuff you got there! The seller of that stuff did a pretty great job with keeping those supplies protected in their boxes.
Well, I'm sure most sellers protect the stuff they sell quite fairly as well, but sometimes they might not know what they're doing when they package the things they want to sell 😐
1998 Pentium II build
Reply 29772 of 53124, by creepingnet
OldCat wrote:
creepingnet wrote:
Just bought this last week and a new motherboard for it yesterday. PSU jack on 3 layer motherboard was having issues, and need […]
Just bought this last week and a new motherboard for it yesterday. PSU jack on 3 layer motherboard was having issues, and needs a hinge fix......epoxy time.
1994 NEC Versa 40EC
- i486 DX-2/40
- 8MB of RAM (4 onboard, 4 on exp. card)
- WD 512k SVGA on 7.5" color LCD ( working)
Nice! I love these old(ish) DOS laptops, have a bunch meself, including slightly newer NEC Versa 4050C.
What is the LCD on yours, though? Is it TFT or DSTN?
Thx. Getting back in the game myself on these. I specifically picked the NEC versa model because back when I was looking for my first laptops back in 2003 these were everywhere and cost quite a bit (meaning plentiful parts and better longevity without the IBM Thinkpad prices we have these days). I'd always see these going back then for $40.00-80.00 on eBay in good working condition back then and there were always 5 new auctions.
The plan is for it to be my portable DOS/win31 system. I've got eyes on a monochrome NVR branded 33MHz version atm as well.
The screen was another reason I picked it, it appears to be Active Matrix TFT.like my AT&T Safari 3151 was....one of the crispest color 640x480 LCDs I ever saw. I think that old Safari was made by NCR and had an NEC LCD in it like the Versa 40EC, and NEC also made a Safari model as well for NCR it seems (the NCR 3180 33sl looks just like the Versa 40/50/P series but with a slightly different top cover, bright gray and surf green accents, and a monochrome removable screen...and no trackball).
~The Creeping Network~
Reply 29773 of 53124, by Vegge
Yeah about that Tyan Thunder board, apparently I maneged to aim a little off when taking the picture. The board also has an ISA slot.
I might have 1GB ECC REG sticks incoming. Then I just need a case for the beasts.
Reply 29774 of 53124, by tabm0de
keropi wrote:
Tiido wrote:
And all of those links have shipping cost that lingers around 30usd+, and once they arrive here I'll have to pay 20...30usd in import taxes, so it makes them completely uneconomical, to a point it is much cheaper for me to make my own. I imagine shipping won't be much different for other EU countries and import taxes probably are similar if not worse also...
We have the same problem here as well - shipping+tax just make it not worth. Tiido's solution is a most welcome one for EU people.
Where is he selling his stuff at? 😀
naa, nothing yet...
Reply 29775 of 53124, by cyclone3d
Interesting. What shipping service are they using?
The cheapest would be USPS first class for something like that which is a flat rate of $24 for international shipping up to 2lb. All other carriers we have available charge 2-3x as much.
So yeah, it does raise the price quite a bit.
Import taxes are really that much? That really sucks. Glad we don't have import taxes at all in the USA.
Yamaha XG repository
YMF7x4 Guide
Aopen AW744L II SB-LINK
Reply 29776 of 53124, by dionb
cyclone3d wrote:
Interesting. What shipping service are they using? […]
Half the problem isn't even the taxes themselves, but the handling costs. Not sure if the cost structure is the same in Tiido's EE, but here in NL, there are no tariffs under shipped value of EUR 22, but as soon as you hit that EUR 22 figure (but under EUR 150), you pay a flat rate EUR 13 in costs, plus 21% VAT. So if you order something worth EUR 23, you pay EUR 13 + (EUR 23*0.21) 4.83 = EUR 16.83. That sort of makes buying anything valuable outside of the EU unattractive, although how unattractive depends on the price - that EUR 13 is the killer on this sort of stuff.
That said, I bought 4x 4MB 30p SIMMs in the US not too long ago for EUR 19 and EUR 13 shipping. As it's under EUR 22 that was all I paid, EUR 32. That wasn't too bad, and I doubt if I could build such SIMMs cheaper.
Reply 29777 of 53124, by GigAHerZ
@dionb, yes, here in EE, the 22 and 150 eur limits are the same. (The flat tax of 13 eur must be NL specific) But that 22 eur is including shipping and the vat tax goes onto the full price, not on the item price. After 150 eur, the tariff tax goes onto the item price only.
(These rules should be the same in all EU countries. Only difference is the VAT tax percentage itself. Even tariffs are same, i believe)
Reply 29778 of 53124, by andreja6
A few days ago I got a 486 PC from the local flea market for a whole 3 dollars. Didn't have time to post it until now
114.12 KiB
How I got it
After 3 or 4 hours of cleaning with 96% alcohol and using fingers to get the gunk out, this is what it looks like now
95.58 KiB
After cleaning
74.92 KiB
Cleen
This is the CPU (it has a heatsink)
115.14 KiB
Am5x86 133
If you want more information let me know
Reply 29779 of 53124, by HanJammer
This shuttle motherboard...
