Reply 30140 of 58840, by appiah4
meljor wrote:
Looks like an Asus v6600 sdram to me? The DDR version is the v6800 DDR. Sdram version is SGram and it actually says so on the board.(sorry)
Um.. Are you sure? Because I also have this, and it's DDR although in SGRAM packaging:
Reply 30142 of 58840, by appiah4
Oh well, that's OK, adds variety to my collection. 😎
Reply 30143 of 58840, by imi
I also have the v6600 with SGRAM, according to reviews online it was out before there were any DDR cards.
Reply 30144 of 58840, by Intel486dx33
DaveJustDave wrote:
Intel486dx33 wrote:
USB hard-drive dock so I can image my old IDE hard-drives.
Works with PC and Macs.
I got the same one... the problem is the spacing between the IDE and power connector.. this dock lets you adjust spacing but a) i've found drives that still don't fit and b) when it DOES fit, it still is a bit of a pain to get the drive pushed in all the way
Ahhh ! Your right. My IBM IDE hard drives won't fit and I am pretty sure tall IDE drives will not fit either.
I am going to have to get something more compatible with large drives.
Reply 30145 of 58840, by Skanque
appiah4 wrote:
Um.. Are you sure? Because I also have this, and it's DDR although in SGRAM packaging: […]
The card in question, mine is also states SGRAM on the moduels, but it's DDR
Reply 30146 of 58840, by MKT_Gundam
I just traded a dead mobo for this audigy 2 at recycler center
I already have one but is the gold plated conector
So is this a OEM version?
Retro rig 1: Asus CUV4X, VIA c3 800, Voodoo Banshee (Diamond fusion) and SB32 ct3670.
Retro rig 2: Intel DX2 66, SB16 Ct1740 and Cirrus Logic VLB.
Reply 30147 of 58840, by retronerd
Hi folks!
Per my earlier post in this thread (last post on page 1507) - would someone mind PM'ing Artex for me and ask him to send me a message with his email address? He did reach out to me but I'm unable to reply because my account is too new. Much appreciated!
Reply 30148 of 58840, by imi
a little bit of this and a little bit of that
Via Epia ESP 5000 with VT8231
Aztech I38-MMSN810... was looking for this one for a while now ^^
nice old QuickShot joystick
and two 96MB flash modules 😀
The attachment hardware30_01.jpg is no longer available
Reply 30149 of 58840, by appiah4
I needed some variety in my ISA VGA collection so I grabbed this when I saw it for five bucks.
Apparently it's one of the fastest ISA cards for DOS, interestingly. I will probably replace my 386SX's Trident 9000B with this.
Reply 30150 of 58840, by cyclone3d
Apparently it's one of the fastest ISA cards for DOS, interestingly. I will probably replace my 386SX's Trident 9000i with this.
Did you mean to post a pic?
Yamaha XG repository
YMF7x4 Guide
Aopen AW744L II SB-LINK
Reply 30151 of 58840, by appiah4
Actually yeah, I did; don't know why it didn't work though. Seller's pic; I'll take a better one once I get it and clean it up.
Reply 30152 of 58840, by blurks
Is it confirmed, that Cirrus Logic rebranded the AVGA2 as the 5402? While the comparison indicates good performance for the AVGA2 I was always under the impression that the last two digits were the designators for the chipset generation and therefore give a clue about the performance. Given the rather mediocre performance of the later 542x chipset series it is surprising that the naming convention is so inconsistent.
Reply 30153 of 58840, by BetaC
So I effectively paid $10 to dumpster dive at a local computer recycler, and managed to pick up two nice, working cards.
The attachment IMG_20190906_155002.jpg is no longer available
An Aureal Vortex 2 sound card. RIP My Vortex 1 card, you will forever be a very good backup.
The attachment IMG_20190906_154948.jpg is no longer available
And a Diamond Stealth 64 DRAM PCI. And before you mention it, I did bend the pin back in to place.
Reply 30154 of 58840, by pan069
Found this Media Vision Pro Audio Spectrum 16 LMSI.
Reply 30155 of 58840, by respect2759
Got an Olivetti 601 Solar calculator today 😎
Photos from web, looks exactly like this, great condition
Soyo 019R1 AM386DX 40MHz, 8Mb ram, 512Kb Trident 9000 Graphics
S26361-D756-X Intel i486DX 33MHz, 4Mb ram, 512Kb - 1Mb graphics on board
Reply 30156 of 58840, by imi
guess I'll need one of these 😁
Reply 30157 of 58840, by derSammler
If you need an LMSI interface card, you could buy this: https://www.ebay.de/itm/143367181774
While it does not mention compatibility with your drive, I got my CM50 working with the CM153 interface card as well as with the SB16 LMSI. The only important thing is to use the driver for the interface card, not for the CD-ROM drive, as the latter will expect a certain interface card and not the one you are actually using.
Reply 30158 of 58840, by Munx
This glorious case for 15Euro. If you think the rust is bad on the outside is bad, its waaay worse on the inside, so sadly this went to recycling today.
The attachment P_20190907_155943.jpg is no longer available
I wouldn't have picked it up if it was completely trashed, though. Inside - a surprisingly clean 486 motherboard with an IBM Blue Lightling DX2-66. My First Cyrix! Also a Tseng ET4000EX Graphics card, 178MB WD caviar hard drive and 1x speed Mitsumi CD drive.
The attachment P_20190907_115918.jpg is no longer available
And from a different find - ESS Audiodrive ES688 with an S-062 chip - 1:1 OPL3 clone!
The attachment P_20190907_174719.jpg is no longer available
My builds!
The Underdog - The budget K6
