Windows 98SE not 4X AGP, but 2X AGP
First post, by egbertjan
If I install a higher driver from Nvidia for my Geforce 4 ti 4600 on my Windows 98SE PC than version 45.23 then the PC switches back to 2xAGP. I have this driver version 4.38 from Via on it for the AGP port. Others via drivers unfortunately do not help to turn it into 4x agp again.
This is My Windows 98SE PC
Pentium 3 1400 mhz |
Video card: Geforce 4 ti 4600 128mb
Memory: 512 MB Memory
Motherboard: Shuttle AV18E2
SCSI adapter: Adaptec 29160N
HDD: ST373455LC
Sound card: Creative soundblaster live 1024
Who knows what I can do about this?
I need newer drivers from Nvidia for The Sims 2 and 3d mark 2003 to work properly.
See the ATTACHMENTS with driver versions 56.64 and 45.23
    147.68 KiB
    69.98 KiB
    105.66 KiB
    70.6 KiB
Reply 1 of 23, by Bige4u
Have a look here, there was a discussion on what VIA driver was best to use according to version of chipset... VIA 4-in-1 driver experiences
I once put together a test WIN98se system using an Aopen AX64 slot 1 motherboard that uses the same chipset(apollo pro 133a) your motherboard has and i used v4.43 along with an Aopen gf2 mx400 64mb 2x/4x agp videocard, and it showed up as agp4x without any issue.
Installing and then uninstalling the VIA chipset over and over while in windows has always been dicey, unfortunately. its best to wipe the hdd and start fresh when experimenting with different version drivers, i know its time consuming, but its alot better than dealing with the headaches you are going through right now, give it a whirl, you've got nothing to lose, but lunch.
GL
Pentium3 1400s/ Asus Tusl2-c / Kingston 512mb pc133 cl2 / WD 20gb 7200rpm / GeForce3 Ti-500 64mb / Sound Blaster Live! 5.1 SB0100 / 16x dvdrom / 3.5 Floppy / Enermax 420w / Win98se
Reply 3 of 23, by egbertjan
I have tried different Via drivers, but nothing helped. I have the idea that the Nvidia drivers do something that makes them fall back on agp 2x
Reply 5 of 23, by liqmat
Incredible timing. I have run across this recently as well with a very interesting Chinese Socket 370 board that I posted about awhile back. It's basically a Gigabyte GA-6VTXE-A knock-off and even accepts a forced BIOS update of that Gigabyte board via UNIFlash v1.4. I've tried all the VIA chipset versions so I will definitely try that NVidia driver version you mention and see if 4x enables. I have read, though, 4x only gives a very small bump in overall performance, but I'm willing to give it a go with my Gainward 5950 Ultra.
Reply 7 of 23, by liqmat
The Serpent Rider wrote:
Once again - just use RivaTuner.
Ya, I know, didn't help in my case. There were some corners cut on the knock-off mobo such as some temp sensors are MIA so it could be just the board.
Reply 8 of 23, by egbertjan
I tried the Rivatuner.
In rivatuner I can set the agp speed, but unfortunately I can only choose from 1x and 2x agp there.
Reply 9 of 23, by The Serpent Rider
You need to unclock those features first to enable 4x mode and FastWrites.
Reply 10 of 23, by liqmat
Color me curious. I'll go back and see if I missed that. Time to reinstall 98. I will admit it's been about a decade since I used it so this would be great if I can get 4x working on this board.
1.77 MiB
I only bring out my best case for this kind of testing.
Reply 11 of 23, by Bige4u
The gainward 5900 videocard.... i've got one just like it, that was the brand to own back in the day, especially the Golden Sample models, quality binned core and memory chips made excellent overclockers, i have mine nvbios flashed to ultra speeds, stable as a top.
Reply 12 of 23, by liqmat
Yeah, think I'm SOL. Looks like that board is strictly an AGP 2x model even though the BIOS shows AGP 4x mode. Guessing they still manufacture them for industrial application, etc. for legacy systems.
Reply 13 of 23, by Bige4u
Thats unforunate... because the AGP slot is a universal 2x/4x varient, so it being stuck at 2x only is quit odd.
Reply 14 of 23, by The Serpent Rider
By default, Nvidia drivers will always limit early VIA chipsets to 2x without FastWrites. RivaTuner will unlock everything even on KX133.
Reply 16 of 23, by The Serpent Rider
Probably on some boards and with early VIA drivers. Never experienced any instability problems with my roster of boards.
Reply 17 of 23, by swaaye
Which boards and what is the suggested VIA driver? Also which OS have you had success with?
The ASUS K7V with KX133 that I have hasn't been friendly to 4x. It was interesting to see because their prior 2x-only K7M isn't very friendly to 2x. Heh.
Reply 18 of 23, by egbertjan
can you tell me how to unlock that in rivatuner?
Reply 19 of 23, by liqmat
Well, not surprising since they have cut other features from the board such as temp sensors, some dip switches and the game port from the original Gigabyte design. It is the VIA Apollo Pro 133 chipset which I now realize is strictly AGP 2x. According to Wikipedia the VIA Apollo Pro, Pro+ and Pro 133 were all limited to AGP 2x and it was only the Pro 133A & 133T that had 4x support in the Apollo line. Regardless, with the GeForce FX 5950 Ultra combined with that Chinesium board gets a score of 9056 in 3DMark01SE. So not too bad at 2x and the board is stable as a rock which surprised me. Plus the driver CD identifies the manufacturer as "Banana Digital". Who could hate a board with a name like that? 😎 Thanks for the help and sorry if I hijacked this thread a bit.
467.01 KiB
