Reply 30560 of 58781, by Munx
Found this little guy in a box of circuit boards for just 50 cents. I think many of you can spot why it wouldn't be working:
The attachment P_20191004_205752.jpg is no longer available
So after a little bit of soldering:
The attachment P_20191004_211610.jpg is no longer available
And it works! This card will live to play Unreal in Glide mode for yet another day 😎
My builds!
The Underdog - The budget K6
Reply 30561 of 58781, by VioletGiraffe
Nice! Did you just add the missing capacitor (C101), or replaced them all?
Reply 30562 of 58781, by Artex
NVIDIA Geforce256 SDR - Leadtek Winfast Geforce 256 32MB (SDR) AGP (NV10) (Sealed) (1999)
Reply 30563 of 58781, by DNSDies
Looks like he also righted C24, which was flapping in the breeze.
Reply 30564 of 58781, by xjas
Another thrift score. I spotted this "combo" CD/DVD/HDD media player thing for $19.99. Doesn't look too interesting from the front:
The attachment CameraZOOM-20191004155724823.jpg is no longer available
But around back, there's a suspicious looking arrangement of ports...
The attachment CameraZOOM-20191004155835834.jpg is no longer available
Sure enough, it's a mini-ITX PC on the inside:
The attachment CameraZOOM-20191004160220052.jpg is no longer available
Specifically a VIA EPIA with a C3/533, an 80GB HDD, and a really neat little Meanwell ATX-ish power supply. I tried it out in the store (specifically violating the printed instructions not to plug anything into the VGA or USB ports), and it tried to boot some kind of Gentoo install off the HDD, but stopped before it got to a login screen. Not sure if that was what was originally installed on there or if someone had been messing around with it already. The "factory seal" sticker was long gone.
A little digging online shows that these are (or were) the standard media player used in Starbucks franchises, in order to stream their corporate smooth jazz over the internet. Shockingly, this implies a Starbucks might have closed at some point in the pacific northwest. Or maybe not.
I got it to boot from a CD-ROM, but it's finnicky. USB keyboards are disabled in the BIOS so I had to pull the board out to use the blocked-off PS/2 ports. There's a BIOS password set that I haven't been able to crack yet, but that should be doable. For some reason it absolutely wouldn't boot my usual go-to boot disc, Hiren's, but it will boot other CD media just fine so I'm using the Ultimate Boot CD for now. Fun times.
I also grabbed this Dell E176FPb with a really long VGA cable for $5. Yes, I have a reason I needed this.
The attachment CameraZOOM-20191004193815061.jpg is no longer available
Reply 30565 of 58781, by FAMICOMASTER
The VGA port seemed kinda normal, and I know some media players do have RS-232 ports...
It's the Centronix port that gave it away.
I think it might be neat to build a decent media center out of that case. Stick a more modern board in it with a bigger hard disk, get a wireless USB keyboard / mouse and plug it into your bedroom television.
Wonder if you could make those media buttons and the screen work with Windows?
Reply 30566 of 58781, by cyclone3d
Got a BOCARAM AT for a 286 build I plan to do:
The card with 2MB:
The attachment BOCARAM_AT_front.jpg is no longer available
What's this? It's the 2MB expansion board!!! 😲
The attachment BOCARAM_AT_2MB_EXP.jpg is no longer available
And here is what it looks like assembled:
The attachment BOCARAM_AT_with_exp.jpg is no longer available
Yamaha XG repository
YMF7x4 Guide
Aopen AW744L II SB-LINK
Reply 30567 of 58781, by cyclone3d
And here is the box and other stuff that was in the box:
The attachment BocaRam_box_front.jpg is no longer available
The attachment BocaRam_box_back.jpg is no longer available
The attachment BocaRam_AT_EXP0.jpg is no longer available
The attachment BOCARAM_AT_acc.jpg is no longer available
YMF7x4 Guide
Reply 30568 of 58781, by cyclone3d
Also got this little treat - A Leading Edge 386DX-33 system:
The attachment case.jpg is no longer available
And the reason I even bothered to buy it in the first place:
The attachment SCC-1_front.jpg is no longer available
See this thread for more info:
Identify the card in this picture?
YMF7x4 Guide
Reply 30569 of 58781, by FAMICOMASTER
OOO Another BocaRAM card!
I've got a BocaRAM XT with 512K installed, and I've got more RAM chips on the way in the form of other defective cards which happen to have chips installed.
Where did you ever find a BocaRAM AT with the 2MB expansion board??? Where would I find such a device for my AST Advantage??
Reply 30570 of 58781, by Predator99
Very nice cards cyclone3d! 😎
Thats my BocaRAM...
Re: Bocaram AT XMS/EMS memory card replica?
...no progress on that project however, dont understand the usage of these PCB design programs.
Reply 30571 of 58781, by cyclone3d
I found it on eBay for about the price that just the boards by themselves normally go for with 0 RAM.
I think I saw some AST boards on there as well. Does the AST you have need a special RAM board or is it just a standard ISA one?
YMF7x4 Guide
Reply 30572 of 58781, by Munx
Correct 😀
Only replaced C101 as these are a pain to work on without a heatgun. C24 was loose, but heating up the pads fixed it.
My builds!
Reply 30573 of 58781, by havli
I have a bunch of V3 with missing at least one of the C101/ C98 / C95 and they still work just fine. But can't hurt to replace the missing parts. Good job. 😀
Reply 30574 of 58781, by Robert B
Flea market day today! (again & again 'till the end of days ... 😁 )
1. Creative Sound Blaster 16 CT2830 - SB16IDE46 - my first long Creative SB. 😁
2. US Robotics - FCC ID: CJE-0286 - Internal FAX/Modem Card
3. Intergraph Intense 3D 100 / (Rendition Verite V1000-E)
4. DFI G586 VPS REV.C1 / G586VPS PRO - http://www.go-gddq.com/down/2011-04/11040300077148.pdf
5. PQI Turbo DDR400 dual channel 2x256MB - PQI3200-512DBH
PRW-FM19-51.jpg PRW-FM19-52.jpg PRW-FM19-53.jpg PRW-FM19-54.jpg PRW-FM19-55.jpg PRW-FM19-56.jpg PRW-FM19-57.jpg PRW-FM19-58.jpg PRW-FM19-59.jpg PRW-FM19-60.jpg
More later.
Reply 30575 of 58781, by GigAHerZ
Damn, where are those flea markets you guys can visit and get stuff from!?
I went through 5 different goodwill-like places in my home town, and they are only selling clothes and shoes...
Reply 30576 of 58781, by respect2759
Did yesterday a meeting with collector friends. We bought a lot with 6 old notebooks, i got a Canon BN 700 from the pack. Its a Pentium 100MHz 16Mb ram and German Win 95 on a 1gig HDD. Some plastic is missing (HDD cover, baterry cover - never seen a Duracell notebook baterry before) It fell on my leg the baterry itself is about 1kg 😵 The notebook has built in color printer i dint try it probably ink is dry... You can open the keyboard to set paper size it and the printed document comes out at the back side. From the notebook seller I bought a Pentium Pro full PC too, Matrox PCI graphics with a connector which looks like MIDI - i think its like on old Apple machines and on the bracket it says VIDEO so no joystick port. Also a Sound Blaster sound card, an USB PCI card and serial paralell headers. The HDD is dead 😵
We also exchanged a few things so I got a Compaq Armada M300 with PIII 500MHz 128Mb of ram and around 10gig HDD. Runs with XP now. It has the original charger and dock too. Nice little machine.
Also got an ATI PCI graphics. The PPro came in a case with AT keyboard and serial mouse too. It was a good day 😊
PS new to imgur IDK how to use it so please tell me if you cant see the photos I will upload here!
https://imgur.com/a/OnRR1gO
Soyo 019R1 AM386DX 40MHz, 8Mb ram, 512Kb Trident 9000 Graphics
S26361-D756-X Intel i486DX 33MHz, 4Mb ram, 512Kb - 1Mb graphics on board
Reply 30577 of 58781, by oeuvre
marry your friends
Reply 30578 of 58781, by Intel486dx33
You need to go to computer recycle centers.
Reply 30579 of 58781, by Horun
We have a few computer recyclers in my area but they seem to watch Ebay prices and charge a lot more than what I consider reasonable. Have had fair luck at the local Salv Army stores but the pickings are sparse...
