First post, by Intel486dx33
Does anyone have any info on this CPU.
PNY Am5x86-P75 AMD AM486DX5-133W16BHC Chip
Who manufactured it ?
It's an AMD 5x86-P75-133 right ?
it works on 25mhz bus and 33mhz bus with 5v.
Any info on the dip switches on bottom of CPU ?
I want to put it in my IBM PS/1 486sx-25 with 169-pin overdrive socket.
Reply 1 of 34, by Brickpad
Trinity Works Power Stacker 5x86. Bought a couple of those myself a few months back. These were designed to handle 5v systems.
PowerStacker 5x86
https://web.archive.org/web/19980703085652fw_ … 6data_body.html
DIP switch settings:
https://web.archive.org/web/19980703090253/ht … switchreve.html
Reply 2 of 34, by Intel486dx33
Yes, I am confused about the DIP switch settings.
What setting should I use to get the full usage of the AMD 5x86-P75-133 @ 133mhz ?
Reply 3 of 34, by derSammler
It's unlikely that you even need to change any of the dip switches. These should be set correctly from factory depending on the CPU used.
Reply 4 of 34, by Intel486dx33
Installation guide:
PNY QC-133.pdf
Here is the installation guide and box.
Should I use 3x or 4x in DIP switch settings ?
Link to software that comes with this CPU
SysChk
http://www.syschk.com/
Reply 5 of 34, by GigAHerZ
If your bus is at 33MHz, then to have CPU speed at 133MHz, you need multiplier to be ...?
The answer is even written on the box! 4th point.
Reply 6 of 34, by derSammler
Since the CPU was factory-installed, leave the dip switches as they are. They are correct already!
Reply 7 of 34, by Intel486dx33
Okay, I see.
So I want to use 4x for a total speed of 133mhz on 33mhz bus.
and 3x for a total speed of 75mhz on a 25mhz bus.
Now,
Should I use "Pass through" or "Write through? ( this setting is for my motherboard cache right ? ).
Reply 8 of 34, by Intel486dx33
It's a used CPU from ebay and I don't know if the jumpers were tampered with.
Reply 9 of 34, by CuPid
Intel486dx33 wrote:
Okay, I see.
No, I think this refers to the L1.
As most upgrade devices, it sets the L1 in WT mode for compatibility.
However, in this case this is also possible to force the WB mode, in case the BIOS would support it.
I need a vacation.
Reply 10 of 34, by Intel486dx33
CuPid wrote:
No, I think this refers to the L1. As most upgrade devices, it sets the L1 in WT mode for compatibility. However, in this case t […]
Intel486dx33 wrote:
Okay, I see.
Well, In the install instructions they refer to it as "Pass through" or "Write through?
See PDF file above.
Reply 12 of 34, by derSammler
The L1 cache is inside the CPU. The rest of the system won't care or even notice whether it's WT or WB.
This is a combination of an adapter and a CPU. The dip switches are there to configure the CPU used. This has been done by the manufacturer already. So for the third time: don't mess with the dip switches, there's no need to.
Reply 13 of 34, by Intel486dx33
This CPU should work with most 486 motherboards right?
Even though it is a 169-pin CPU it will still fit in most 168-pin sockets and pin #169 should not matter if it is connected or not. The CPU should still operate right ?
Wether in an Overdrive socket to standard 168-pin 486 socket.
Almost all 486 CPU sockets have an opening for the pin #169 ( extra pin in middle of CPU ).
Reply 14 of 34, by Intel486dx33
More photos:
Reply 15 of 34, by croton64
Motherboard L2 caches were Write-Through and Write-Back, maybe you should check a little more before actual testing... don't know what it means PassThrough.
Reply 16 of 34, by Intel486dx33
Can anyone clarify what is meant in this user install instructions when it reads "Pass through" or "Write through?
See PDF file above.
Reply 17 of 34, by Warlord
pass through could mean read through unless he read it wrong.
If read through and write through are the only options id guess read through is faster but idk.
Reply 18 of 34, by GigAHerZ
Read through would effectively mean no cache at all. 😁 I don't think it's the worst 486 ever, having similar performance per MHz as 386. 😁 (Even 486SLC and 486DLC would be faster having 1kB of cache on chip)
Reply 19 of 34, by mwenek
Hey all. I have one of these versions of the Am5x86-P75 (refer to photo!)
Any idea what the cut wires lead to?
My guess is an old fan that was cut off as it is an Evergreen Overdrive model.
I appreciate any insight before I fire it up.
Edit: Does the WB/WT cache option on this chip itself refer to its internal cache or the MB cache?
Win98SE Box: PIII 850, 128MB, 8 GB HDD, CL Live!, ATI 9600XT, 2x Diamond Voodoo 2 8MB
DOS Box: Intel 80 Mhz P24T Socket 3 OD, 16MB, 128MB CF Drive, Number 9 VLB, SiiG VLB IDE, SoundBlaster 16 ISA/WaveBlaster
