First post, by RiP
I have noticed that enabling the "486XX Internal Cache Status" for TI 486DLC 40MHz increases the 3DBench score but makes Speedsys to crash 😕
Reply 1 of 11, by GigAHerZ
I have exactly the same problem with one motherboard (M-321) while other MB is fine (MS-3131) when 486dlc is used. Both boards work 100% correctly with 386dx.
I didn't notice other problems, but speedsys was unusable... 🙁
Reply 2 of 11, by jesolo
There were some compatibility problems with some Cyrix 486DLC & motherboard combinations.
Alternatively, try enabling the Cyrix L1 cache via the Cyrix utility as opposed to using the motherboard BIOS - https://www.philscomputerlab.com/cyrix-486dlc.html
Reply 3 of 11, by RiP
Does MS-3131 work fine while running speedsys? are you sure that L1 is enabled?
Reply 4 of 11, by Anonymous Coward
The reason this is happening is because your cache is not configured correctly. You need to make sure your cache is coherent, either by using the FLUSH# method (hardware) or the BARB method (software). The FLUSH# method is more efficient, but sometimes the boards lack the circuitry to make it happen. However, you can modify boards to add it. The easier way is the BARB method, but you need to make sure your board supports hidden refresh.
I suggest using 3rd party cyrix.exe. In order for BARB to work, you need to specify a memory exclusion range for cacheable areas. Cyrix.exe is case sensitive and has odd syntax, so you have to use it with care.
Try this in your autoexec.bat: (exactly as written)
cyrix.exe -e -b -m- -xA000,128 -xC000,256
I had the same issues as you guys and this fixed it. I had much less success with the FLUSH# method, even on boards already wired for it.
Register settings for various CPUs
Reply 5 of 11, by GigAHerZ
Yes. All fine, everything enabled.
I did play around with cyrix utility on M-321, but i didn't exactly try to disable anything. On the contrary, i tried to enable various things to make it work, but couldn't make it this way.
Reply 6 of 11, by RiP
Did you enable the internal cache from BIOS or with the utility?
My motherboard is MB-4D50L
Reply 7 of 11, by GigAHerZ
@RiP, both. I kept it enabled in bios and i played around with utility enabling everything i could.
To be honest, i think i even had Windows 95 successfully working well on it even when the speedsys wasn't able to run. I concluded speedsys being not compatible with this cpu+mb combination. But maybe there's something that can be done? 😀
Reply 8 of 11, by RiP
I think you're right. It's speedsys that isn't fully compatible with 486DLC.
It doesn't detect the clock speed correctly or even the 1KB internal cache:
Reply 9 of 11, by Anonymous Coward
In my opinion, the graphics corruption you're seeing is the classic sign that the cache is not configured correctly. Things may appear to be working well until you try to do some kind of DMA related activity, and then it'll all come crashing down. I've spent countless numbers of hours trying to get the DLC working correctly in my SCSI based systems, and I've seen the exact same speedsys problems you're having. It only happens when the cache is not setup properly. Speedsys may not detect the DLC properly, but it should still work.
Also, I think it's better to leave the Cyrix cache setting disabled in the BIOS, and enable it with the utility. I've had a lot of boards with DLC support, and the BIOS cache enable never works properly for me.
Reply 10 of 11, by GigAHerZ
Sorry to bump this thread, but as i played around a bit, i found some information.
The MS-3131 board i have, that worked well with the Cx486DLC-40 CPU, just accidentally had it working well. When i used the command line utility to remove all disabled regions of caching, i got similar speedsys graphics error, as i did with my M-321 board. When i disabled the video ram area from caching, everything went back to normal.
I assume (Haven't tried on my M-321) that this video ram caching makes it incompatible with speedsys.
Right now, with MS-3131 board, i execute the cyrix.exe file like this:
cyrix.exe -f -m -xA000,64
No other regions needed exclusion for all phil's dos benchmarks to work properly.
NB: For fun, i also used AMISETUP to improve some mobo-cache timings and other things like that. I get 25,21MB/s memory bandwidth, 21,08 cpu score with speedsys.
Reply 11 of 11, by RiP
Thanks, it didn't work for me though.
