Reply 20 of 22, by Warlord
- l33t
NOTE: To check if your motherboard is compatable with Intel Coppermine CPUs, please check first if there is a blue sticker with the letter "C" located on the I / O chip. If it is present, that means your system will support Intel Coppermine CPUs.
The Winbond I / O chip is located near the Serial Port.
https://translate.google.com/translate?hl=en& … 163&prev=search
If it does than you should be able to upgrade to 600hmz PIII w/ 100 MHZ FSB with the right BIOS. This is a pretty impressive upgrade over your current CPU.
