First post, by bmwsvsu
I have some motherboards with a bunch of faulty caps....and they're all the same culprit:
Evercon
125 degrees C
E67A
Now I'm not a capacitor expert. Nowhere printed is the capacitance rating. Google searching was mostly fruitless EXCEPT one lone forum post suggesting this might be a 1000uF 25v capacitor. Even so, most that I find on ebay with that capacitance rating are rated at 105 degrees C and this one is 125. What exactly should I be replacing this one with?
Reply 1 of 4, by ShovelKnight
Are you sure there's no rating? Is it also absent on the other side of the cap?
Reply 2 of 4, by bmwsvsu
Ok so now I feel like an idiot.....🤣 yes, its on the other side....6.3v 1500uf
Reply 4 of 4, by RoyBatty
Replace with panasonic or rubycon 1500uf @ 6.3v 105 C, probably it's 3.5mm lead spacing. Get the low ESR ones.
If you live in USA you can get them from mouser for around $10 for 15.
