Reply 13520 of 31247, by liqmat
Vegge wrote:
Since I finally got the RAM I just had to boot it. […]
So yeah, dual P3 733 with 8GB of RAM. Now what? Windows 7? 🤣
Man, you have some serious dual Slot 1 action at your place. IIRC you also grabbed a NOS dual Slot 1 Supermicro board awhile back. Speaking of which, did you ever repair both of those FIC PN-6210 dual Socket 8 boards? Don't recall if you did or not.
Reply 13521 of 31247, by Standard Def Steve
I thought Coppermine could only cache up to 4GB of RAM (or was that just Katmai)?
Tualatin for sure can cache up to 64GB, but it was designed for servers.
"A little sign-in here, a touch of WiFi there..."
Reply 13522 of 31247, by Bruninho
More like XP. I don't believe 7 can handle this...
JOBS, Steve.
Reply 13523 of 31247, by luckybob
Man, I really want to get one of those dual Tyan boards.
Reply 13524 of 31247, by xjas
ShovelKnight wrote:
Was testing my new (to me) VIA EPIA 800 Mini-ITX motherboard.
It's amazingly DOS friendly and even the built-in Ethernet has a packet driver for DOS.
The built-in VGA is pretty horrible (the picture is a bit blurry and it's not fast) but there is a PCI slot. Curiously, the board didn't want to POST with a GeForce 2MX PCI. It posted with an S3 Trio.
That's interesting, I had the same issue on mine with a GF4 MX4000. I thought it was due to an iffy BIOS flash on my part, but I haven't investigated further.
That's pretty damn cool. DDR1?
There's an unofficial PAE patch for 32-bit WIn7 to allow it to access more than 4GB RAM if you want to go that route. Otherwise AFAIK Win2K Advance Server should support it, or almost any version of Linux.
Reply 13525 of 31247, by Vegge
One of them is working. TBH I haven't even looked at the other one yet. The one with the overheating issue. I've been really busy with my other hobbies. 😀
IKR, I have another older Tyan Dual slot 1 board with 72-pin memory and 66MHz bus. IIRC you have that one to, with suspected broken BIOS?
No, good ol 168p SDRAM. Getting 1GB sticks for a reasonable price was just pure luck. Yeah I was thinking WIN7 just for the heck of it. Didn't early XP support PAE? But WIN2KAS seems more fitting.
Reply 13526 of 31247, by ShovelKnight
By the way, I should probably flash the latest BIOS and try again.
Reply 13527 of 31247, by Mister Xiado
derSammler wrote:
But if it's broken, someone must be able to repair it. So even a service partner or Microsoft itself would have to crack-open it for a repair. How stupid is this? It's like having a car with a hood that can not be opened by the owner, because the manufacturer welded it.
Indeed.
https://www.youtube.com/watch?v=9YVTXG5-8h0
Reply 13528 of 31247, by Tiido
It doesn't actually give UMBs yet (but all the preps for it are done, MSD for example sees the upper memory as RAM now according to how I have confed things) but that will be done tomorrow. And then I'll do more chipsets too when all the bugs get fixed.
Reply 13530 of 31247, by UpNorth
Trying to troubleshoot a beautiful 486 Soyo VLB motherboard which USED to work. I tried literally everything short of throwing it in the oven. I won't do that, but I am quite sad. It used to work so nicely, and buying an equivalent PCB now would cost a pretty penny (including shipping). I may produce a post somewhere around here, to pool the collective wisdom. Retro computing seems quite saddening to me, at the moment. This is already the 2nd item that used to work, which is now inoperable - the other is a nice 8-bit ISA VGA card. Also quite precious.
Reply 13532 of 31247, by PTherapist
Today was time for a little upgrade:
And now in my 486 Dell Optiplex 425s/L:
No issues, all working fine. "Compatible speed" mode in the BIOS still brings down performance to that of a 25MHz 386DX - so at least that hasn't changed. I think this is about the last upgrade I'll do for this PC, unless by some miracle I ever come across the VLB riser and/or L2 cache board.
Reply 13533 of 31247, by luckybob
@PTherapist
What system is that? it looks VERY familiar.
Reply 13534 of 31247, by PTherapist
luckybob wrote:
@PTherapist
A pic of it I grabbed off the net:
It's a Dell Optiplex 425s/L (originally equipped with an Intel 486 SX 25MHz CPU, which I initially upgraded to an AMD DX40 running at 33MHz). LPX form factor, with a riser containing 3x ISA slots.
Reply 13535 of 31247, by luckybob
ok, I have a Compaq and its EERILY similar.
Reply 13536 of 31247, by UpNorth
bjwil1991 wrote:
Which issue is your board facing?
It's not working at all. I tried it with a Trident ISA card and two different VLB graphics cards. All three graphics cards work, as I tested them on another VLB motherboard. I also tried two different CPUs (Intel DX2 66MHz and AMD Am486 80MHz), both CPUs were also tested as working with the other motherboard. I tried swapping the RAMs, I tried disabling part of the cache, all to no avail. And as I said, the motherboard was stored after I have successfully used it for a while in the very same configuration that now is not working.
Reply 13537 of 31247, by RetroLizard
Old hardware can be weird, in my experience. Either it works fine after giving you problems for a while, or it stops working despite being just fine a few minutes ago.
Reply 13538 of 31247, by Windows9566
my Macintosh Performa 6200CD was working when i bought it from ebay, but after a couple weeks, it just suddenly stopped working, no chime, nothing. same with a MSI KT4A-V Socket 462 board, it just stopped posting out of the blue one day when i was going to use it.
Toshiba Satellite 200CDS
Toshiba Satellite Pro 430CDT
Toshiba Satellite Pro 480CDT
Toshiba Tecra 740CDT
IBM Thinkpad 760LD
Nan Tan(Clev0) FMA86T
Reply 13539 of 31247, by Bruninho
I faced a similar issue with a MacBook Pro 2010 - but to be honest, someone (not me, thanks God) spilled water on it... I assume the logic board fried.
JOBS, Steve.
