Reply 13540 of 31247, by bjwil1991
- l33t
I have 1 board that never wants to POST at all and might be either the CPU is bad or the caps are bad. I'd flash another BIOS on there, but, my EEPROM programming tool broke on me (cheap crap).
I also had a PowerMac G3 that never booted at all. Kept the ATI Rage 128 PCI card, RAM, CD-ROM drive, HDD, ZIP drive, IDE cables, and the SCSI card. Also, my Socket 370 build was having issues starting with 3 sticks of RAM installed and worked with only 1 stick, but after carefully cleaning the contacts and reflowing the solder on some of the pins (felt cold in a couple of spots), I can officially boot Windows 98SE with 768MB RAM.
All I need is a Socket 370 Tualatin adapter for my PIII-S 1.4/512/133/1.45V SL5XL so that I can use it in the system or find a Slotket adapter that supports the CPU for my P2B-F motherboard or for a future Slot 1 build (possibly an AT board).
Forgot to add something retro-y activity: I attempted to run Chimp after installing the files from Rocky5's extras DVD, however, it won't boot at all and I believe it's because it requires the 1.6-1.6b systems to get it to run, and this is on my 1.0 system, so when I get home, I'm going to FTP the files to the E partition from my laptop and run it from there and see what happens.
