Reply 60 of 151, by lowlytech
Have an intel 2meg 16 bit memory card. The closest thing I could find on stason.org was an aboveboard AT, however the DIP settings didn't seem to coincide with mine. After messing around and swapping out a bad ram chip I have the full 2MEG ontop of an IBM 128/640 that is fully loaded (128k+512k) for a grand total of 3200K on the 5170 memory count. No POST errors, all RAM passes. The following DIP switch settings were used..
SW1 off,off,on,off,on,on,off,off SW2 on,off,off,off,on,on,on,on
