Reply 13721 of 31256, by CarlHopkinsUK
Thermalwrong wrote:
CarlHopkinsUK wrote:
Discovered the ide controller is kaput on the IBM Aptiva I picked up, given the CD drive was blown too I expect something has happened here...
Well at least I have a nice mATX case for a future project. 😐
Currently spinning up a custom WinXP installer to get XP on my HP 4320s Probook daily driver alongside Linux. Always find it useful to have a working machine with XP on it.
I thought the same with a similar system, a SIS-chipset based Socket 7 computer. The IDE controller just wouldn't pick anything up - it turned out one of the IDE cables, the one to the CD drive specifically, was in backwards and that stopped both IDE channels from working, hopefully yours might be a similar issue? 😁
Alas i wish it was...
No unfortunately it picks drives up fine, and posts as normal. However in about 8 out of 10 boot attempts it will just hang post boot (no matter what drive or device i use).
When it does boot, it will usually hang once you start doing any amount of I/O. Best i have managed is about 50% of the way through a MS-DOS 6.22 install before it just hung.
Odd thing is, system is still responsive (i.e doesnt hang/lockup), its just as if the IDE controller gives up on sending any I/O...
Tried multiple drives, HDDS, CF's, different RAM, different CPU, different PSU changed all the cables, reseated the BIOS, reflashed the BIOS... only thing i haven't changed is the board itself. Symptons are the same regardless.
I even under clocked the K6-2 to 200mhz and dropped the bus the 66mhz and even that made no difference!
Reply 13722 of 31256, by Bruninho
liqmat wrote:
I counter that with... […]
bandicoot67 wrote:
bfcastello wrote:
Atari is a great console and a big part of my childhood. However, this advert was incredibly stupid...
https://kotaku.com/sorry-that-crazy-stevie-wo … fake-1570104210
Excellent counter strike! I almost believed it was for real... sorry, but in today's world I see some bizarre things... Thanks god the poster is fake hahahaha
JOBS, Steve.
Reply 13723 of 31256, by Bruninho
I'm now reworking my Win 2000 VM from scratch. This time I will not install the USP 5.1 as it appears to have broken how Windows sees the iPod Nano. So far, after each update, I plug the iPod, and when it gets recognized I save a snapshot before proceeding to the next update. This way I can find which one broke it, in case it wasn't the USP 5.1... but so far most probably it was.
Edit 1: I'm 100% sure now that the USP 5.1 has USB drivers that screwed up the iPod/iTunes "conversation". I decided to make a backup of the existing USB drivers before USP 5.1 install. After installing it, I replaced it with the backup USB drivers. Reboot. Reinstall iTunes. And voila, iTunes is now seeing the iPod Nano, with USP 5.1 installed. Next step is to test install of BWC kernel extender to allow me to use newer browsers. I am really close to what I wanted to build since months ago when I tried to make a replica of what was like my old PC back in late 90's/early 2000's using Windows 98SE before I moved to Windows 2000 for these new attempts. I will eventually try again with Windows 98SE later, but Windows 2000 is definitely rock solid so far.
I actually never owned an iPod Nano back in that day, but my dad did, since it is his iPod Nano - He was probably using Windows XP instead. I don't like the XP cartoony look, hence why I am trying to use older versions.
JOBS, Steve.
Reply 13724 of 31256, by brostenen
By today's standards, then yes.... However that is taking the add out of the context. The add is in fact quite genious.
You must remember, that Stevie Wonder, was highly successful in the 1970's. The add is from 1981, so it it clearly playing off his immense, huge and grand status as a pop song writer and performer. He was so big back then, that even the fact that he is blind, was kind of his big trade mark. Looking at all this, the add makes perfect sense, to play off the blindness factor.
And yes. Atari 2600 is the king of 2'nd generation consoles.
Reply 13725 of 31256, by derSammler
No, it's not. That ad is a fake and never existed... And it would have been quite insulting even back then, had it been real.
Reply 13726 of 31256, by ODwilly
Alas i wish it was... […]
Does your board have a free pci slot? You can always add a Promise or some such IDE card and boot from that.
Reply 13727 of 31256, by bandicoot67
Ok, well...while we are on the funny old school ads...here is some more until i can find my "couldn't have got away with that Neo Geo ad in 2019" folder. 😀
Reply 13728 of 31256, by Vincebus
is that Don Francisco!?
lo-fi fingers...
Reply 13729 of 31256, by oeuvre
brostenen wrote:
By today's standards, then yes.... However that is taking the add out of the context. The add is in fact quite genious. […]
unrelated but 2 years ago in my family's fantasy football (NFL) league... I chose Amari Cooper, WR for the Oakland Raiders at the time. Named my team Amari 2600. Won the league.
Reply 13730 of 31256, by Cyrix200+
I had a 'MHz display' with one segment not working (the middle horizontal one in the left digit so a commonly used one). I finally had enough to order at Mouser with free shipping, so the first thing I did when that arrived was to solder in the new display:
Then I tried my new 386 motherboard:
aZrPLVzl.jpg?1
But the board would not power up at all. No spinning PSU fan and POST card voltage LED for 5V (or was it the 12V one? I don't remember) was the only thing to light up. The culprit was found very quickly. Desoldered it and now the board seems to work just fine. Need to find a replacement for it, and the > 20 other ones on the board. Are eBay/AliExpress tantalums reliable?
The board has a separate BIOS setup for some chipset setting and tweaks, will need to tinker with it to find the best results. The board has cache (64K I think).
1982 to 2001
Reply 13731 of 31256, by Thermalwrong
Exciting 😀 Surely some basic low ESR capacitors should be a suitable replacement? Also in my experience and what I've seen so far, it's only the ones around the PSU that appear to have trouble usually, so why not wait til the next one goes pop? At least they're easy to spot 😁
Back in March (which for some odd reason I had thought was March 2018, but no, thankfully it was March 2019) I got hold of this oddball SAA1099 clone card that a good PCB designer in Russia (pcbsale-ru) put together.
The attachment 20191223_224628(1).jpg is no longer available
I had been afraid to run it because there was so little info and I know little about electronics and could find little about putting this together.
A few weeks ago I found This Thread by "Tronix", the guy that originally put together the SAA1099 reproduction board. His most recent posts he bought the same board and worked out that fitting a small voltage regulator would clean up the output significantly.
I fitted that to my card this evening and finally had a go with it. It sounds great! 😁
Worked first time, although I did cheat a little bit because I also put together the Snark Barker, so I have already had some experience with the GameBlaster-esque soundcards, this sounds a bit better though.
The attachment 20191223_224709.jpg is no longer available
Reply 13732 of 31256, by Bruninho
Just finished recreating my Windows 2000 Professional Virtual Machine with all my whistles and bells. Two browsers (New Moon and SeaMonkey) skinned to look like Netscape (4 and 9). mIRC installed, iTunes with a library for my iPod Nano 1st gen. WinAmp works and gets the same library. Games? FIFA 98 RTWC, NFS 2, Flight Simulator 98, Grand Prix 4 with 3 mods (1994, 1997 and 1998), Full Throttle and Indiana Jones & The Fate Of Atlantis. I'm well served for my time travel to the late 90's/early 2000's. I just wish any ICQ version were still working (but we can use the web version anyway). MSN and Orkut are both defunct, so...
I think I might need to install some version of MS Office on it. Dunno which version... It's supposed to be a vanilla Windows 2k install, except it has BlackWingCat's files just for the two browsers.
EDIT: And oh, I posted it using SeaMonkey on my Win 2k VM.
JOBS, Steve.
Reply 13733 of 31256, by wiretap
Swapped out white drives for black in my 8088.. looks wayyy better, more period correct. I'm using the hot swap caddy for a CF card --> XT-IDE. Makes loading stuff on it far easier with front access to the case to swap in/out the card.
Old:
New:
My Github
Circuit Board Repair Manuals
Reply 13734 of 31256, by Bruninho
It definitely looks better, wiretap. Good job!
JOBS, Steve.
Reply 13736 of 31256, by Cyrix200+
Thermalwrong wrote:
Cyrix200+ wrote:
<snip> Are eBay/AliExpress tantalums reliable?
<snip>
I will at least replace the ones near the power connector, for the rest I will probably wait and see. If they short it's not always visible.
Not sure if they can be replaced by other types of capacitors. Googling it gives me many opinions on it but I lack the knowledge to judge those opinions.
The board runs quite well with a 33MHz Am386. SIMM placement is weird but managable, they are in between the ISA slots. Toggling the Turbo seems to slow it down to 8MHz (according to CheckIt). That's interestingly slow and might be useful.
1982 to 2001
Reply 13737 of 31256, by derSammler
Cleaned, fixed, and tested a couple of C64/Atari joysticks yesterday and today. Was quite interesting to see the differences in their construction and to choose the one that feels best while playing. May post more details in a separate thread later.
Reply 13738 of 31256, by bjwil1991
I have a QuickShot II for the C64/Atari 2600 that I got for $0.25 one day and got it all cleaned out. I used BASIC to test the joystick and the port along with an Atari 2600 controller connected to the other port to make sure they both work.
Reply 13739 of 31256, by derSammler
A QuickShot II was among them, too.
