Reply 13940 of 31247, by Caluser2000
- l33t
bjwil1991 wrote on 2020-01-12, 04:30:I wonder if it's possible to do IRC from a terminal?
Yes. Just log into a host system an run what ever irc client is on there. You can also do this via serial port on an old system connected to newer system. Run terminal emulator program on the old system to log in to the host system. The link is old but gives you an idea of what can be done. http://www.sorgonet.com/8086/8088_linux_dumb_terminal/
