First post, by Intel486dx33
What Jumper settings should I use on a Intel 486dx4-100 motherboard setup ?
Jumper settings:
1) P24D ( enable / others )
2) Write-thru or Write-back ?
Jumper settings:
Have you googled it?
Well, the posts reads the “P24D” is only for the “Intel-486dx2 CPU”
Is it also available on the 486dx4 ?
I will have to inspect my CPU for write-thru or write-back markings.
The "&E" on the chip means it's Write Thru. (I was assuming that was a picture of your actual chip).
Not sure what P24D means to your motherboard, if it's simply telling it that it's a DX2 or better, or something else.
Also, My 486dx4-100 CPU only works with jumpers set for 5v.
But the CPU is a 3.3 volt I think.
What is better write-thru or write back ?
I both types of CPU’s
Write Back is better.
From what I have read write-back is more complex where write-through is a simpler and faster way.
Which is better for performance and reliability ?
Write Back is slightly faster.
Write-back is faster. There should be no difference in reliability but some motherboards doesn’t properly support WB thus it can be disabled.
If you have a WT model (like the one above) no special jumper settings are necessary as CPU pins these jumpers connect won’t do anything and yhe CPU will work in WT mode.
All DX4 use 3.45V or 3.3V. Some boards sense the voltage automatically when a DX4 is inserted.
You want settings for P24C.
I am testing with a 486dx-100 ( &E ) write-through CPU right now.
I have it setup correctly except for the voltage. I know it’s a 3.3v CPU
But when I set the motherboard for 3.3v it will not boot.
I need to set the jumpers for 5v for it to boot.
At least that is what the manual reads that I have the jumpers set to.
Do you think there maybe something blown on the motherboard like a diode or resistor ?
Your CPU is soon cooked with 5V...
I am going to check the voltage with a multimeter.
Intel486dx33 wrote on 2020-01-13, 08:39:I am testing with a 486dx-100 ( &E ) write-through CPU right now. I have it setup correctly except for the voltage. I know it’s […]
I need to set the jumpers for 5v for it to boot.At least that is what the manual reads that I have the jumpers set to.
If it's you CPU (SX900) pictured, then according to http://www.cpu-world.com/sspec/SX/SX900.html is runs on 3.45 Volt. All though I would expect it to at least POST with 3.3 ..
Intel486dx33 wrote on 2020-01-13, 03:39:Also, My 486dx4-100 CPU only works with jumpers set for 5v. But the CPU is a 3.3 volt I think. […]
But the CPU is a 3.3 volt I think.What is better write-thru or write back ?
Bolded makes no sense you will probably kill the chip.
Unless the board is actually sensing VOLDET pin and supplying correct voltage (no matter how you set the jumper) as per reference design by Intel.
download/file.php?mode=view&id=74445
In that case you'll measure 5V on the socket until you insert a compatible Intel 3.3V CPU.
This wouldn't explain why it doesn't work when set to 3.3V. What model of board we are talking about?
You should be able to test the voldet capability with this guide:
http://web.inter.nl.net/hcc/J.Steunebrink/amd5x86.htm
CPU Voltage The Am5x86 needs a supply voltage of 3.45V + 0.15V. Setting the voltage jumpers as for the 3.3V 486DX4 will normally […]
CPU Voltage
The Am5x86 needs a supply voltage of 3.45V + 0.15V. Setting the voltage jumpers as for the 3.3V 486DX4 will normally take care of this. Note that most motherboards actually supply 3.38V when set for 3.3V so that both 3.3V and 3.45V CPUs can be supported.
If you can't find voltage jumpers, it is possible that your motherboard can autodetect the required CPU voltage. New CPUs like the 486DX4 and the Am5x86 have a VOLDET (Voltage Detect) pin that causes compatible motherboards to switch to 3.3V automatically. The motherboard manual should be clear on this. If you're not absolutely sure and if you have a multimeter, you can use the following procedure to check this out.Unplug and then open the system.
Lift the ZIF socket handle and take the CPU out. Store it in an anti-static bag or box or place it with it pins on a piece of conductive foam.
The VOLDET pin is pin S-4. It is tied to ground (Vss) internally in the CPU. Simulate this by inserting a wire from pin S-4 to Vss pin R-4.
Now insert two wires for the multimeter. The ground wire goes in Vss pin S-10 and the live wire in Vcc pin R-10.
Close the ZIF socket handle to connect the wires.
Switch the system on and check for 3.45V + 0.15V DC on the multimeter. If you see 5V, then your motherboard is not autodetecting.
Restore everything as it was.Caution: Anytime before you touch any component inside your system, place one hand on the chassis, such as the power supply case, to prevent electrostatic discharge damage.
McBierle wrote on 2020-01-13, 16:52:You should be able to test the voldet capability with this guide:
CPU Voltage
Thanks for the link. I’ll try it.
Hi, I know I am (maybe too) late in this thread, but here are my late 2 cents.
Did you say what mainboard you are actually using? Maybe I missed it.
All mainboards which I did own that supported 3Volts CPUs (so had the voltage converter), had voltage auto-detection.
There was no jumper for selecting 3.x volt and 5 volt.
The jumpers on the mainboard existed to switch between - for example - 3.3v, 3.45v, 3.6v and 4.0v, or only to select 3.45v or 3.6v. 3.6volts and 4.0volts are only needed for some cyrix cpus by the way.
So the jumpers were only for fine-tuning the voltage, when you have a 3volts cpu.
EDIT: bad typos hopefully corrected now
Hmm, so you are talking about the gigabyte mainboard ga-486vs
So I see the problem.
So that suggests that there is really no autodetection.
But why they needed 2 jumpers for 1 bit of information?
That's no "information". These jumpers directly change the voltage routes coming from the voltage regulator(s) and going to the CPU.
