Reply 2640 of 5103, by imi
bearking wrote on 2020-01-21, 20:39:
RacoonRider wrote on 2020-01-21, 18:47:
A guy from Russia made a project with one of these industrial PCs where he mounted it inside a 5.25" bay of his main PC and used a KVM switch to actually have 2-in-1 computer. Times have changed though, I think it was back in the days when Core2 was hot and new, so it was a lot easier to build that kind of setup.
http://sannata.org/konkurs/2011/kt1111.shtml
Hey, that's a really nice idea! Have to save that link...
there's even specific SBC form factors for 3.5" and 5.25" ^^
Reply 2641 of 5103, by chinny22
Struck GOLD before Christmas
Saw a post on freecycle for "old computer bits used in art project so probably not working"
Looking at the pic saw a few things that made it worth the gamble.
Right away saw the AWE Gold
The Slocket adapter and slot 1 heatsinks would be nice even if not in the market for them really.
The card with RAM looked interesting and assumed the vga card would be boring.
Figured the CPU's is what was art project was all about so didn't really look at them.
In the end I got even more gold. Amongst the CPU's I'd missed the 2 gold top PPro 200's
The Slot 1 CPU's are P3 500 probably from a Prolient 800 going off the VRM part numbers.
Also a P133 non MMX
Lots of bent pins but doesn't look like any missing.
Out of the cards the AWE was the worst with chips off the board but at least included
The other cards were:
Abit SlotKET!!! AB-FC370 which is CU compatible 😀
Compaq branded Matrox Millennium with memory addon
DPT PM3224 RAID card with DPT SX4000 daughterboard that allows another 7 devices, although the latest drivers are for NT 3.51 (but works in NT4) It also has 8 MB Parity RAM installed and upgradable to 64MB
All the other chips were a mix of VGA, RAID, etc not all PC related. They are going to a mate that wants to make a mosaic out of them.
The RAID card I'll test at some point and probably sell
The Matrox and Slocket I'll test and keep if they work, Always handy to have
The PPro's I'll keep and try out in my PPro haul PC. The 133 and 500's I'll also test and may sell or just keep as aren't worth anything.
The AWE I'll try getting my mate back in Oz to have a look when I'm back later in the year as this is what he does for a living.
Reply 2642 of 5103, by imi
nice save :3
pity about that AWE, but that looks repairable with some time and effort, unfortunately it looks some of the traces got ripped off with the lower chip though.
Reply 2643 of 5103, by gdjacobs
Should be repairable with bridge wires.
Reply 2644 of 5103, by BetaC
So my work is throwing out a bunch of recent computers for whatever reason, and I managed to snag one of these boys for the price of free.
The attachment 09E332B3-27D5-476B-8275-B572FB427430.jpeg is no longer available
They have no hard drives or ram, but DDR3 isn’t so hard to find anyways. Now I just need to figure out what to do with a Sandybridge era system.
The attachment 61CFF5EC-A84A-46E5-96E3-56F56236267D.jpeg is no longer available
Reply 2645 of 5103, by Horun
BetaC wrote on 2020-02-02, 20:52:
Nice ! The manual is here: https://www.dell.com/downloads/global/product … -tech-guide.pdf
Most of the Dells of that era are quite good little towers. Sort of funny but almost exactly 2 years ago got a few Dell Optiplex 7010 MT and a Inspiron 3847 MT for next to nothing. Came from a school that had replaced theirs with new ones and was sorta auctioning them off for donations for some school function. They were only missing the HD's.
Reply 2646 of 5103, by BetaC
Horun wrote on 2020-02-02, 22:07:
Thank you for the documents. I’m thinking about constructing some sort of an offline Windows 7 box that has hardware from around that 2011 or so era, but that’s going to be kinda awkward for picking out parts, since it’s less cut and dry.
Reply 2647 of 5103, by bearking
Got these today... My colleagues at work are upgrading some of their equipment, replacing the old SBCs and industrial computers.
The attachment POS_486_ST486DX4-100.jpg is no longer available
It's a socket 3 motherboard, I think LPX form factor, with an ST 486DX4 @ 100 MHz + heatsink&cooler and 2*16Mb EDO RAM. I don't know the manufacturer, only the model it's printed on the board, POS-486 and on the back side only that is version B1. The board is working fine so far, but tested only with the basic benchmarking apps. Too bad I couldn't find the riser card for that slot on the board...
Reply 2648 of 5103, by appiah4
I love how the model appreviation is basically Piece Of Shit 486 😁 Nice freebie but of limited use without the riser 🙁
Reply 2649 of 5103, by yawetaG
Possibly Point of Sale, i.e. ex-industrial.
Reply 2650 of 5103, by dionb
yawetaG wrote on 2020-02-07, 06:57:
"Point of Sale" - that means cash register from a shop.
As for the riser, looking at the chipset this is a PCI design, so the riser is most likely one with EISA connector but PCI and ISA slots. They're quite common.
Reply 2651 of 5103, by bearking
As dionb said, probably I could find a riser, as it is a quite late 486 board. Probably is from the beginning of 1998, at least the latest date code on one of the chips (ALI M1487 B1)is 9802. Anyway, this board was used to control a machinery similar to the one in the picture below, used for electrical rotor assembly. It had a TFT + touchscreen attached to the pins nearby the video memory expansion sockets...
Reply 2652 of 5103, by derSammler
dionb wrote on 2020-02-07, 10:51:
"Point of Sale" does not mean cash register! PoS can refer to any system used in shops, which are in some way involved in customer interaction - interactive kiosk systems for example. What you possibly mean is a PoS Terminal, which is the term used for those things you stick your ec card in when paying.
Reply 2653 of 5103, by Horun
bearking wrote on 2020-02-06, 22:43:
Nice ! reminds me of the Unisys boards made by FIC. Yes a standard eisa to PCI/ISA riser should work fine. I would cut that battery off ASAP
Reply 2654 of 5103, by SpectriaForce
Almost got a chance to take home a nice undiscolorated midi tower ATX pc (possibly In-Win enclosure) from the e-waste container at the municipal waste facility today. Just when I was about to take it, I heard footsteps coming towards the container so I left the container with empty hands haha 😁 Such a shame though, I will never know what was inside that beautiful looking pc! Hopefully I have better luck next time.
Reply 2655 of 5103, by bearking
SpectriaForce wrote on 2020-02-08, 14:58:
Two months ago I made the same mistake, now I would go back for sure...
Reply 2656 of 5103, by Slashzero
Not sure if this qualifies as a “dumpster find,” since I didn’t find it in a dumpster, but I was going through old stuff at my parents house and found my old PowerBook 2400 LapTop sitting in a box in the basement. Adding this to my collection of old hardware, and need to figure out what to do with it. It even has a 3.5 inch external floppy, and I’m pretty sure I still have modem and network PCMCIA cards that are compatible with it. 😁
Actually, I used to have an external SCSI CD-ROM drive for this... must.. find...
Crap! I just tried powering it on, hard drive is spinning, the LCD lights up, but I’m not seeing a smiling Mac face staring at me. 🙁
So everything is powering up, but I’m not seeing video on the LCD panel. Guess I will have to do some trouble shooting. Maybe there is a loose connection?
Oh, I know! I will hook it up to an external monitor when I get home.
Update: Aha! Found a post on another forum which had the same issue. It’s likely a surface mounted fuse that has burned out. I know the laptop is functioning properly because I held down the power key, and it spoke to me:
“Alert! Are you sure you want to power down your computer?”
I pressed Y and then Enter and the laptop turned off.
So, looks like I will need to open it up and see which fuse was blown, and try to work around it.
Attached pics. LCD off vs. on.
Reply 2657 of 5103, by SpectriaForce
bearking wrote on 2020-02-08, 15:12:
Hmm, I would do that if it was easy, but over here the waste facility has quite a lot of personnel walking around and the containers get collected by truck once every 1-3 days.
Reply 2658 of 5103, by Slashzero
SpectriaForce wrote on 2020-02-08, 23:51:
At work, my cube is right next to the IT/SysEng/Ops guys. I’ve started inquiring about old hardware, and how they dispose of it. It turns out they will be dumping a crap ton of hardware in the coming weeks. Apparently we use a service that rolls up with a truck and loads all the old servers and hardware and disposes it as e-waste. It seems like such a waste, and makes me sad. 🙁
Reply 2659 of 5103, by Byrd
Slashzero wrote on 2020-02-08, 21:20:
Update: Aha! Found a post on another forum which had the same issue. It’s likely a surface mounted fuse that has burned out. I k […]
There are several fuses on the 2400c motherboard which usually results in a "green light of death" on startup. The fact yours boots sans display says it's not the fuse, but possibly failed backlighting (shine a torch at the LCD) or bad/loose cabling. Reseating the LCD cable isn't too bad - you need to pry up the panel above the keyboard, keyboard itself and wrist rest mount. Try to find a 2400c service manual for the steps.
