Baoran wrote on 2020-01-22, 07:33:
I am kind of curious about this as well. Like how large hard drives work using them and what are transfer speeds like. There are many larger sata hard drives than there ever was when it comes to ide hard drives. I just recently got this PCI IDE card and based on info online it says it supports ide hard drives larger than 127Gb, but no idea how large that would be. What would happen if I would connect a 1Tb sata hard drive to it using such adapter?
These adapters just adapt the protocol, they don't in any way change HDD detection/size limits. So you're dependent on the capabilities of BIOS for that. If you use them with motherboard I/O, it's the motherboard BIOS that determines capabilities, if it's a card with BIOS, that BIOS determines them.
The 137GB limit comes from the original 28-bit addressing of IDE/LBA. To go beyond that limit, a new 48-bit LBA addressing was used. 48b allows 144PB. That should be enough for the next few years...
So 1TB > 137GB so you need 48b LBA, and 1TB <<144PB, so no problem there.
