ThatRetroDude wrote on 2020-01-31, 13:02:
After spinning it for quite a while it still isn't spinning up, but it does spin sort of freely when I spin it by hand. It stops directly after I stop spinning though.
You can feel the platters spin? You sure about that? Because if it does spin at all, it's not stuck - this is caused by the heads "sticking" to the platters so neither can move. If the spindle is not in fact stuck then probably it's the motor driver chip that is toast - not much can be done about that other than replacing it. I'd argue the disk is gone and that's it.
If it is still stuck, and you only want it to spin one last time to make a backup copy, then open it up and free the spindle by GENTLY rotating it with your finger, placed on the edge of the platter(s). Direction is important too, the heads should be parked near the center (but might not be, and that's why it's stuck). Rotate it a bit so the heads are "dragged" along with the rotation direction and move on their own towards the center (or just stay if already there).
Once opened the dust that gets inside will kill it, eventually, and most likely it will get stuck again pretty soon anyway. So it's really the last resort and one-time operation.
