Reply 32360 of 58399, by badmojo
canthearu wrote on 2020-02-07, 00:36:
It is a perversely interesting board leave entirely as it is!
I like your thinking - it would be interesting to benchmark it as-is and see what sort of performance handicap the fake cache is, that might be a better project.
Reply 32361 of 58399, by HanJammer
I hope EGA Wonder 800 works fine...
I'm not sure what the Quadram board is... it has 8086-1 and three 2048x8 SRAM chips... it also has 40-pin connector... Is that memory expansion (Quadram was known for them) or some sort of drive controller?
Reply 32362 of 58399, by pentiumspeed
Last brown card photo is compaq's IDE and floppy, serial and parallel controller. Very well made. Had one and liked it and purchased another years later and is in my collection for old computer.
Cheers,
Great Northern aka Canada.
Reply 32363 of 58399, by RacoonRider
imi wrote on 2020-02-07, 00:10:
interesting Promise 3DWebSound with OPL4, the bridged pins are a bit weird?
That naming! Sounds like they were desperately trying to jump on too many bandwagons at once 😁
Reply 32364 of 58399, by Deksor
badmojo wrote on 2020-02-06, 23:40:
jheronimus wrote on 2020-02-06, 22:02:
First, a PC Chips M915 — a PCI/VLB/ISA board with probably fake cache chips, a DX2 and what looks like quite a bit of FPM RAM. I have lots of those, but nothing bigger than 4MB per stick, so that could be interesting.
I have one of these too and yep, fake cache like yours. From what I understand it's possible to solder in real cache and flash the BIOS to stop lying about it and use the real thing - so far the motivation to do the work hasn't materialised but it's an interesting board so maybe one day I'll do it.
I've done this on mine when it was working.
No need to touch the bios, it will find the cache.
Here's a speedsys benchmark with a 486DX2 66 after the mod : 2AqA1OFl.jpg
Reply 32365 of 58399, by canthearu
Deksor wrote on 2020-02-07, 05:34:
Did your board break sometime afterwards did it?
Reply 32366 of 58399, by appiah4
Those soldered on cache chips with WRITE BACK written on them are super duper fake 😁 Desolder and put some sockets on. 😀
Reply 32368 of 58399, by Deksor
canthearu wrote on 2020-02-07, 05:50:
It broke because it's a piece of crap that's way too thin. I had issues running 3.3v chips after putting a chip backwards by mistake and after mounting and unmounting it in several cases, it stopped working properly (now it boots ... Sometimes)
Reply 32369 of 58399, by appiah4
I believe Ancient Electronics on YouTube has a video about the PCChips M915, it's a quirky and flaky cheapass board but it gets the job done if you are short of other Socket 3 options..
Reply 32370 of 58399, by appiah4
some cards I got recently :) […]
some cards I got recently 😀
good old Matrox Millenium and Mystique 220
Headland HT209 VRAM 2
Genius YMF724 card
the only other picture I could find of that card was without the OPL4 and the pins were bridged anyways, that is underneath the chip.
also what's the difference between YMF704-S and YMF704C-S?
How do you tell the Mystique and Mystique 220 apart? I have one, but I don't know what it is (haven't tested it yet).
Also, my experience with Genius branded SB Pro clones (ESS and YMF) have been superb, nice catch with that card.
Reply 32371 of 58399, by mpe
appiah4 wrote on 2020-02-07, 09:01:
Look at the main chip if it is MGA1164SG it is Mystique 220, if MGA1064SG it is the original Mystique.
Blog|NexGen 586|S4
Reply 32372 of 58399, by appiah4
mpe wrote on 2020-02-07, 09:10:
Ah, ok mine is a regular Mystique (+RainbowRunner).
Reply 32373 of 58399, by imi
maybe the board number is also an indication 644-03 vs 644-00/01
Reply 32374 of 58399, by appiah4
imi wrote on 2020-02-07, 12:03:
Anectodally, mine is 644-00
Reply 32375 of 58399, by devius
It's far easier to look at the chips. If it has a big TI Video chip near the output port it's a Millennium. The point of Mystique was making it cheaper to produce, so they integrated the DAC into the main chip.
Reply 32376 of 58399, by derSammler
It's about distinguishing a Mystique from a Mystique 220, not a Mystique from a Millennium. 😉
Reply 32377 of 58399, by devius
derSammler wrote on 2020-02-07, 13:18:
Oopsie! 😅
Reply 32378 of 58399, by HanJammer
This semi-rare ATI Stereo F/X and nice Adaptec SCSI controller arrived in some poor 486 today...
