External floppy drive
Reply 20 of 58, by Planet-Dune
Errius wrote on 2020-02-09, 22:16:
Right, so it has two 5.25" floppy drives and you want to add an external 3.5" drive. Does it have a hard disk?
If you have another DOS machine with a 3.5" drive you can connect them via parallel cable and transfer files that way.
Well I wanted to add the external drive to a modern pc that does have usb support (my 98 pc or something) and then transfer the written floppy to the commodore.. my pipe dream was that there would be USB models just as there are for 1.44" diskettes but that seems a big no go. I do have a 386 with a diskette drive but not a floppy 🙁
Reply 21 of 58, by Errius
No, as others have said, USB 5.25" floppy drives were never made. (I think there are specialist devices for archiving of old disks, but they are very expensive.)
Disk drive density is also an issue. I see the PC10 has 360 KB (double density) drives. Most 5.25" drives on sale on places like eBay are 1.2 MB (high density). DD disks written on HD drives won't read properly on DD drives.
You have 3 options that I see:
1) Install an external 3.5" parallel port drive in your XT, and a regular USB floppy drive on your main rig, and transfer files that way.
2) Copy the files to your 386 and then transfer them to your XT with a parallel cable
3) Install a DD (not HD) 5.25" drive in your 386 and use it to create disks readable in the XT
Is this too much voodoo?
Reply 22 of 58, by Planet-Dune
Errius wrote on 2020-02-09, 22:35:
No, as others have said, USB 5.25" floppy drives were never made. (I think there are specialist devices for archiving of old dis […]
I'll research a bit on the second option, which seems the easiest to achieve. Never done this however, it is as simple as connect the two machines and.. ?
Reply 23 of 58, by Errius
Does your PC10 have a hard drive? If it doesn't, and you don't intend to install one, option 3 is probably the best. 360 KB doesn't leave you with much elbow room.
The issue of transferring files between computers via cables came up in this topic: Interlink for DOS
Reply 24 of 58, by Planet-Dune
Errius wrote on 2020-02-09, 23:31:
It does have a hard drive, 10 full mb!
Reply 25 of 58, by Errius
Good, that simplifies things. Before you do anything else, get a null modem serial cable with 9-pin to 25-pin adapter. Once you have the serial connection working you can also get a parallel cable for greater speed. There are detailed instructions in that link I posted.
You don't have to use the 386 for this. Any DOS/Windows 9x computer with serial and parallel ports will work.
Reply 26 of 58, by cyclone3d
What about an easier solution such as a XT IDE card and then use an IDE to CF card adapter that has easy access through a slot on the back of the XT?
Then you could just use a CF usb adapter on the newer computer.
Then you just copy stuff to the CF card on the newer computer and access that directly with the XT?
No need to deal with floppy drives or floppy disks at all.
Yamaha XG repository
YMF7x4 Guide
Aopen AW744L II SB-LINK
Reply 28 of 58, by Errius
Another thing the OP can do is simply transplant the XT hard drive and controller card into another computer, taking care to jumper it for drive D: so it doesn't conflict with the host drive.
Reply 29 of 58, by 1ST1
OMG... no comment on some comments here...
So it's about a Commodore PC of the XT class and data exchange with a modern PC... Easy...
You need:
1. Parallel Port ZIP drive
2. USB ZIP drive
3. A few 100 MB ZIP medias
4. MS-DOS 5 or better on that XT
5a) A NEC V20 CPU if your Commdore PC has an 8088 at same clock frequency
5b) A NEC V30 CPU if your Commdore PC has an 8086 at same clock frequency (don't think so)
6) IOMEGA's GUEST.EXE driver (which ueses some 80186/286 instructions which are not available on 8088/86, but on V20&30.
1+2+3+4+5b+6 is the way I do it with my Olivetti M21/24/24SP,240. It works quite nice.
103.23 KiB
How to print a portrait on a typewriter?
81.97 KiB
My exibition at Heinz Nixdorf Forum, Paderborn, 3/2019
80.87 KiB
The M21&24&24SP&240 armada...
Reply 30 of 58, by Doornkaat
1ST1 wrote on 2020-02-10, 21:42:
OMG... no comment on some comments here... […]
You need:
2. USB ZIP drive
But how do you get GUEST.exe on the Commodore without using an intermediary machine with 360k floppy drive?
Reply 31 of 58, by Horun
Doornkaat wrote on 2020-02-11, 03:30:
Good question !
You need: 1. Parallel Port ZIP drive 2. USB ZIP drive 3. A few 100 MB ZIP medias 4. MS-DOS 5 or better on that XT 5a) A NEC V20 […]
You need:
2. USB ZIP drive
🤣 that is a whole lot of hardware that can be easiliy simplified by other methods....
Reply 32 of 58, by 1ST1
Horun wrote on 2020-02-11, 04:01:
Yes, but other methods are not RETRO. And don't forget, ZIP drive is hotswap. XT-IDE with a CF card is not. You always have to switch off for a swap. Serial connection is quite slow. And the fast modes of laplink, fastlynx, norton commander parallel port transfer don't work on many XT class machines as their parallel port is not bidrectional.
And, yes, guest.exe must be initially transfered to the XT, so you need a 360 kb diskette once, or serial cable.
Reply 33 of 58, by cyclone3d
What about installing a NIC in the XT and then spin up a local ftp server on the more modern machine.
https://www.brutman.com/mTCP/mTCP_FTP.html
YMF7x4 Guide
Reply 35 of 58, by cyclone3d
Errius wrote on 2020-02-12, 19:52:
Is it possible to send an arbitrary file across a serial connection using only stock DOS commands?
Just looked it up and it looks like you can by:
1. initialize the COM ports on both machines.
2. use the copy command.
Example:
Receiving computer:
MODE COMx:2400,n,8,1,p
CTTY COM1
copy /b COM1: mygame.exe
Sending computer:
MODE COM1:2400,n,8,1,p
CTTY COM1
copy /b mygame.exe COM1:
See here for a more in-depth discussion:
https://groups.google.com/forum/#!topic ... j6VserwN8
You will of course need a null modem cable or straight through cable and a null model adapter.
YMF7x4 Guide
Reply 36 of 58, by CrossBow777
On the USB 3.5" part of this, I did find a guy on ebay last year that was selling NOS Dell external 3.5" USB external drives. I got one of them as they were like $15 shipped and can confirm that it was able to reach 720kb diskettes fine. Something that 2 other USB floppy drives I've bought over the years refused to do.
But even in my XT/286 days in the late 80s I don't ever recall seeing an external 5.25" or even an external 3.5" drive. All the XTs I worked with had 2 drives in them and my 286 had one of each installed internally both HD variants.
Midi Modules: MT-32 (OLD), MT-200, MT-300, MT-90S, MT-90U, SD-20
Reply 37 of 58, by Errius
OT, but this reminds me of one of my machines, which is dual boot Windows XP and Windows ME. It has a DD (not HD) 5.25" drive installed which works fine in WME but which does not work in WXP. (I get an I/O device error when accessing the drive.)
Was support for these drives dropped in Windows XP?
Reply 38 of 58, by Horun
Errius wrote on 2020-02-12, 21:08:
Yes general support for the old 360k and 720k drives was dropped in XP. Somewhere I saw a patch that put it back in but that was years ago and was a Explorer + system hack of some type.
Reply 39 of 58, by Errius
I don't own any 720 KB 3.5" drives. Do these have the same compatibility problems with 1.44 MB 3.5" drives that 360 KB 5.25" drives have with 1.2 MB 5.25" drives?
Can you write 720 KB disks in 1.44 MB drives and read them without errors in 720 KB drives?
