First post, by fool
- Member
After installing OS, Intel 82371AB/EB PCI to USB bridge is giving me exclamation mark with error code 35:
“Your computer’s system firmware does not include enough information to properly configure and use this device. To use this device, contact your computer manufacturer to obtain a firmware or BIOS update. Code 35”
Not much helpful info can be found with google. Somewhere was a comment that MPS version should be dropped 1.4->1.1 but cannot remember is there even this configuration available. BIOS update could be one solution, but Epox BIOS updates are not easy to find. This is with 1Mbit BIOS chip. I found one firmware file but it seems to be with the same date (05/99) that is currently in the system. Any suggestions? I don't care much about USB, but it would help a lot installing all drivers and stuff...
Toshiba T8500 desktop
SAM/CS9233 Wavetable Synthesizer daughterboard
Coming: 40-pin 8MB SIMM kit, CS4232 ISA wavetable sound card
