HWiNFO for DOS resurrected !
Reply 140 of 884, by Cyrix200+
Mumak wrote on 2020-04-01, 19:33:
Cyrix200+ wrote on 2020-04-01, 19:16:
Yay, I managed to crash it :P […]
Yay, I managed to crash it 😜
System: Toshiba Libretto 30 CTK
http://www3.toshiba.co.jp/pc/catalog/oldpc/li … /lib30/spec.htm
EDIT: it's the 29/3/20 build
Thanks for the feedback. Can you please try to disable the "Check Keyboard Controller and Super IO" option in Setup menu if that will help?
Yes, that helps. Still can't generate a report, I don't think it saves the config?
Let me know if I can try more.
1982 to 2001
Reply 141 of 884, by Mumak
Cyrix200+ wrote on 2020-04-01, 19:49:
You will need to also hit the "Save setting to disk" item, that should save them into INI file.
Let me know if that will finally allow to create full report.
Reply 142 of 884, by Cyrix200+
Mumak wrote on 2020-04-01, 20:36:
Yeah, got it now. Don't know what I did wrong before, it just wouldn't work.
1982 to 2001
Reply 143 of 884, by Mumak
Cyrix200+ wrote on 2020-04-01, 20:47:
Thanks for the report!
Reply 144 of 884, by Boohyaka
Hey, glad you got back to this! I was frustrated as I never managed to run the old latest build, it would always crash. The latest one from this thread runs fine, so that's already a huge improvement 😀
It first complained about EMM386 as I had it loaded, but it worked fine nonetheless.
Couple issues I see:
- My DX33 is detected as 23.8 MHz..during POST it is definitely showing 33MHz.
- My Aztech Labs NX Pro is detected as a "MediaVision Jazz-8"
Report attached. Let me know if there's anything I could do to help.
Cheers
    HWINFO.LOG
    23.82 KiB
    59 downloads
Reply 145 of 884, by Mumak
Boohyaka wrote on 2020-04-01, 21:05:
Hey, glad you got back to this! I was frustrated as I never managed to run the old latest build, it would always crash. The late […]
Cheers
Can you please try to open the main window a few times to see if the clock is always reported as 23.8 or it does perhaps change between runs ?
I will check how to detect that sound card, but it's not easy without having the required programmer documentation.
Reply 146 of 884, by Boohyaka
Mumak wrote on 2020-04-01, 21:47:
I did, it very steadily reports 23.8, never seen anything else!
Reply 147 of 884, by Mumak
Boohyaka wrote on 2020-04-02, 09:54:
Please try this build what clock will be shown now. It might also identify the Aztech card properly.
[removed as newer build available]
Reply 148 of 884, by Boohyaka
Mumak wrote on 2020-04-02, 11:30:
Please try this build what clock will be show now.
Progress! 23.9 now 😁
It does now, great!
New log attached.
    HWINFO.LOG
    22.1 KiB
    53 downloads
Reply 150 of 884, by Mumak
Boohyaka wrote on 2020-04-02, 14:46:
Is the CPU really running at 33 MHz? Perhaps the Turbo button off? 😉
Or maybe something messing with the system timers (some drivers used) ?
It does now, great!
New log attached.
Perfect 😀 thanks!
Reply 151 of 884, by Mumak
Boohyaka wrote on 2020-04-02, 14:56:
Btw Mumak is there any interest for me to try and run it on my other computer in Win98 real-mode DOS or not really?
Sure, I'm interested in any reports.. The DOS version won't run from Win98 DOS box, you'd have to start it from DOS upon boot. From Win98 I'd recommend to use native HWiNFO32.
Reply 152 of 884, by Boohyaka
Mumak wrote on 2020-04-02, 14:58:
Doh...silly me. The computer is currently on my testbench and the turbo connector wasn't plugged. So indeed, looks like my non-turbo speed is 23.8. Is that expected? I kinda expected to be slower than that...
Mumak wrote on 2020-04-02, 15:00:
Yep figured as much, I'm already using HWiNFO32 under Win98 and loving it 😀
Here's the real-dos mode report attached.
    HWINFO.LOG
    151.56 KiB
    63 downloads
Reply 153 of 884, by Mumak
Boohyaka wrote on 2020-04-02, 15:35:
Doh...silly me. The computer is currently on my testbench and the turbo connector wasn't plugged. So indeed, looks like my non-t […]
Thanks 😀 That's a quite new machine for a DOS tool, yet HWiNFO managed everything right 😀
Reply 156 of 884, by Boohyaka
Hey, just thought about something. In my 486 build I have two cards that went undetected. Not sure you want, or even can detect them but just thought I'd mention it:
- ISA 3 voice tandy card from matze79
- ISA MPU 401 card from Keropi (basically a MusicQuest PC MIDI clone)
Let me know if I can help!
Reply 157 of 884, by Mumak
Boohyaka wrote on 2020-04-03, 11:29:
Hey, just thought about something. In my 486 build I have two cards that went undetected. Not sure you want, or even can detect […]
Thanks for your offer. Unfortunately such cards (like any other non-PnP ISA card) require dedicated code for access/detection. This is not possible to implement without programming documentation, some sample code or reverse-engineering binary tools that are able to detect the device. If anyone is aware of such resources, please let me know and I will have a look at that...
Reply 159 of 884, by aha2940
Hi
I just tested HWinfo on my PC, and it worked fine. All I noticed was:
- Did not detect the NIC card at all (3Com 3C509B ISA)
- Detected the soundcard as an ESS688. It is an ESS1688F.
Would that log be interesting?
