First post, by Scythifuge
Greetings,
I am trying to use a Waveblaster with my AWE32 3990. Some games will play midi music (Ultima VIII,) whereas the following games that I tested will not: Wing Commander Privateer, Dark Sun - Shattered Lands, and Doom 1 & 2 so far...
Privateer lets me choose the IRQ for the Waveblaster, and none of the options work. Like Ultima VIII, Dark Sun doesn't give me the option to choose IRQ, but I get no music, same as both Dooms. If I choose AWE32 for Doom, the music plays.
I'm not sure why I can't get the Waveblaster to work with Ultima VIII, but nothing else, so far...
Any ideas?
Scythifuge
Reply 1 of 7, by kolderman
Does that require the aweutil tsr to be loaded? It doesn't work with protected mode games like doom. Are you in dos or windows?
Reply 2 of 7, by Scythifuge
kolderman wrote on 2020-04-04, 04:58:
I am in DOS. Choosing AWE32 in Doom does work for me with AWEUTIL. Though it is the Waveblaster I am testing; trying to determine why it works in Ulltima VIII and not in any other game that I test.
I forgot to mention that I have an MPU-IPC-T in the system and it is set to 330, and the Midi on the AWE32 is set to 300.
Reply 3 of 7, by kolderman
AWE32 is on a special port that never requires the tsr. The waveblaster is just a midi device and you typically need aweutil to be resident. The AWE is much better under Win98 where all of this becomes irrelevant.
Reply 5 of 7, by Scythifuge
kolderman wrote on 2020-04-04, 05:08:
AWEUTIL is for the AWE32 features (port 620.) I have the daughterboard header set to port 300. Privateer doesn't support the AWE32 , but it supports the Waveblaster. I had a 486 and a CT2760 that died, and I replaced them with a Pentium 133 and the 3990. The Waveblaster worked in the previous system with a similar setup, which was port 300 for utilizing the Waveblaster, and it isn't working in this system. The Waveblaster doesn't require AWEUTIL - I believe that is just for soundfonts. It is similar to the daughterboard connector on non-AWE32 cards.
For some reason, only some games are seeing the Waveblaster at port 300, and others are not.
Reply 6 of 7, by derSammler
Scythifuge wrote on 2020-04-04, 05:24:
No, it's always required. It's used to init anything MIDI-related.
