First post, by eperezf
Hi!
I got an old Dell Inspiron 2500 a while ago but without a charger. I recently got one to test the computer but it wont start. Kinda.
I pressed the power button and fans, HDD and CD drive started spinning along with power and HDD LED turning on. After a couple of seconds it shut down completely.
Tried the same without HDD, without CD drive, without RAM and battery. Also with RAM and without battery. Still the same issue. I also hear a faint whine where the CPU (which is removable) is located
What could it be that makes it fail to boot? Does it have a hidden CMOS battery that I need to replace? Is the battery too dead (Battery LED lights up when I plug the battery but then it stays off)?
I don't have similar RAM (at least at hand right now, will check in my spare parts) so I can't test that out. I'll leave it plugged in (with battery) for a couple of hours to see if it's just being powered off for too long.
Any advice would be helpful. Thanks!
Reply 1 of 5, by darry
eperezf wrote on 2020-06-04, 21:07:
Hi! […]
Hi!
What are the specs on that charger ? This model needs 20V and at least 3.5A according to info I could find .
Reply 2 of 5, by eperezf
It's an original Dell PA-6 charger, model ADP-70EB. It says 20V 3.5A.
Reply 3 of 5, by EvieSigma
Sounds like CMOS battery to me. I fixed a seemingly dead Latitude C640 by yanking the CMOS battery.
Reply 4 of 5, by eperezf
EvieSigma wrote on 2020-06-05, 04:27:
I had to disassemble the whole laptop to access the CMOS battery. It was under the motherboard. It's a soldered 3V Panasonic V1220. Tester says 2.77V. Is it ok or does it need to be replaced?
Also inspected for blown caps and they all look fine.
Reply 5 of 5, by evasive
2.77 is too low.
