Reply 16140 of 30893, by luckybob
Haven't made a video for quite a while, and when I do, it's almost 2 hours long.
https://youtu.be/fJEsRZQ9FFU
Reply 16141 of 30893, by Thermalwrong
Wow, nice job getting that working - it looks like you cleaned under the solder mask so it should be good for a long time. I have a 386sx board with fairly similar damage but it doesn't even post, still can't figure out why.
Today I've finally had a chance to enjoy my PCB of ab0tj's HardMPU, it works so nicely on my little 486 test PC and works great with my MT-100 😀
The attachment IMG_0488 (Custom).jpeg is no longer available
There are about 7 faults in the design and I've got the next board ready in EAGLE, but for now I've got 4 more PCBs that just need a few wires soldered to work right 😁 MPU-401s for everyone*!
*everyone being my stack of retro PCs ranging from 386 to pentium MMX
Reply 16142 of 30893, by Deksor
CMB75 wrote on 2020-07-09, 18:08:
Spend most of my “retro” time today grinding a 286 board out of a case with a Dremel. The board had the Varta disease. […]
After neutralizing the damage with ethanoic acid I put the board into the dishwasher and gave it a good scrub with isopropyl alcohol afterwards. I replaced a few traces with bodge wire and reseated the chips … lo and behold, it does post.
Time to put it into temporary storage - without a battery of course.
Very good !
According to the POST string, it's an Aquarius System Inc (maybe that's what "ASI" on the case stands for ?)
Here's the manual from TH99 once again (in case someone else finds this board) https://arvutimuuseum.ee/th99/m/U-Z/30524.htm
Do you have equipment to dump that BIOS ? 😁
Reply 16143 of 30893, by CMB75
Deksor wrote on 2020-07-09, 20:54:
Very good ! According to the POST string, it's an Aquarius System Inc (maybe that's what "ASI" on the case stands for ?) Here's […]
Very good !
Shouldn't be a problem to dump that BIOS. Do you want me to upload it here or somewhere else?
Reply 16144 of 30893, by Bancho
Been working on my Via C3 1.2ghz Nehemiah Machine the past week and its making good progress. Windows 98 Installed. I'm playing about with Setmul/CPUSPD and Rayers SMB. Hoping to write some batch files for certain CPU speeds. Running a Awe32 with a Dreamblaster X16/SW60XG/TB Maui in the sound. GF2 GTS for Gfx. Really enjoying this machine so far.
Reply 16145 of 30893, by Deksor
CMB75 wrote on 2020-07-09, 22:16:
Very good !
Predator99's topic should be perfect for that purpose 😀 80286 BIOS image collection
Reply 16146 of 30893, by liqmat
Bancho wrote on 2020-07-09, 23:01:
https://i.imgur.com/hPaWVeul.jpg […]
Nice case. Clean.
Reply 16147 of 30893, by RetroLizard
Installed Baldur's Gate 1 yesterday, tried it out. Pretty cool game, and one that I think I'll enjoy a lot. If only I could find someone to play it with...
Same thing with Baldur's Gate 2 today.
In addition, also planning on my next retro build. The specs will be similar to the following:
CPU: Pentium III @ 1 GHz
GPU: Voodoo 3 PCI + Nvidia AGP Card for mid-2000's games
RAM: 512 MB
Sound: Aureal Vortex 2 card
Motherboard doesn't matter too much, so long as it works with all the above specs. Any suggestions?
Reply 16148 of 30893, by babtras
I MacGyver'ed a temporary power supply for an automotive computer. I wish the Data911 MDS2000 automotive computer I have was so simple.
Reply 16149 of 30893, by Bruninho
babtras wrote on 2020-07-10, 05:03:
I love MacGyverisms 👍🏼 Good job
JOBS, Steve.
Reply 16150 of 30893, by bjwil1991
Replaced the Socket 7 board from the capacitor plague Gainward motherboard to a TMC AI5VG+ Rev. 2.00 100MHz FSB support and got everything all sorted out. Had issues with the CD drive not getting recognized, so I connected the LS-120 drive to the same cable the CD drive is connected to and it works. Also got the AWE64 DOS utilities and drivers installed and got the card to work (missed one of the files in autoexec.bat to add C:\CTCM\CTCM) and the card does work, except the AWE32 music portion acts strange for some odd reason, so I need to get that all sorted out, but the card works regardless.
May someone please assist me with the AWE32 issues with the card itself? Is there anything I'm missing in the autoexec.bat file or would conflicts cause this issue?
Reply 16151 of 30893, by babtras
Another retro activity the last couple days. I helped someone fix and improve a clock in QBasic over a Facebook retro computing page. That got me on a roll with something I had been meaning to do with Turbo C in DOS, doing some graphics with direct memory access rather than using the BGI library. It is quite simple with 320x200x256. Not so simple with 640x480x16 - when I figured out how to do it finally, I realized I lack the ability to do it anything near fast enough to be practical.
But I had fun and learned things anyway.
Reply 16152 of 30893, by xcomcmdr
RetroLizard wrote on 2020-07-10, 05:03:
Installed Baldur's Gate 1 yesterday, tried it out. Pretty cool game, and one that I think I'll enjoy a lot. If only I could find […]
RAM: 512 MB
Anything based on the Intel 440BX chipset, I guess.
Reply 16153 of 30893, by CMB75
Deksor wrote on 2020-07-10, 01:48:
Very good !
Dumped the contents of the BIOS chips and posted them to the 286 BIOS thread. See: Re: 80286 BIOS image collection
Reply 16155 of 30893, by RetroLizard
xcomcmdr wrote on 2020-07-10, 06:59:
RAM: 512 MB
I did a little research, and apparently 440BX boards can support CPUs running in 133Mhz FSB? Or should I consider a Socket 370 board instead?
Reply 16156 of 30893, by xcomcmdr
I have a Slot 1 Pentium III running at 800 MHz with a FSB at 100 MHz on an ASUS P2B. It's close to what you want, but I had to use a beta version of the BIOS for it to work.
In other words, that's very high end for this chipset.
You'd be safer with a Socket 370. In my experience, I've never seen a 440BX -based motherboard that allowed more than 100 MHz for the FSB.
I tend to prefer this chipset as it is super stable, and it's the same as I experienced back in the day. Besides, the 200 MHz clock difference was not worth it for me.
Also, I needed an ISA slot, and it's next to impossible to find a motherboard with that, if you want to have a 1 GHz CPU on it too.
Reply 16157 of 30893, by darry
xcomcmdr wrote on 2020-07-10, 13:26:
I have a Slot 1 Pentium III running at 800 MHz with a FSB at 100 MHz on an ASUS P2B. It's close to what you want, but I had to […]
Some 440BX boards allowed setting 133MHz FSB . Asus P3B-F and Abit BX133 are two examples .
When running at 133MHz FSB, normal 33MHz PCI operation is possible, but AGP base clock will be 89MHz instead of the normal 66MHz . This 89MHz clock essentially limits AGP compatibility to some Nvidia cards, like the FX5900 family for example .
For more compatible examples, see 440BX 133Mhz FSB 89Mhz AGP Video Card Compatibility?
Also note that not all 440BX boards are capable of the divider required for 33MHz PCI operation when running FSB at 133MHz and . Those boards will PCI at 44MHz when using 133 MHz FSB. I suggest checking before buying as overclocking the PCI bus by a third breaks compatibility with lots of PCI devices and can lead to disk data corruption .
Reply 16158 of 30893, by imi
well anything above 100Mhz on 440BX is considered "overclocked" but they've been run on that far and wide, some boards more stable than others ^^
Reply 16159 of 30893, by xcomcmdr
Ah, I faintly recalled that it was done, but that was about it. Thanks ! 😀
