Reply 35320 of 53191, by Joseph_Joestar
Ordered an S3 Virge DX 4MB and an LC Power 550W PSU today.
The Virge will be mainly used for 2D DOS gaming, but I'm also a bit curious how S3D games like Terminal Velocity and Tomb Raider will work on it.
The PSU will hopefully allow my AthlonXP rig to run at higher clock speeds. It seems to have 40A on the 5V rail, so I should be all set.
Reply 35321 of 53191, by NyLan
Today I received a Geforce FX5500 I bought on Ebay... So happy to plug it in... and see that I actually received a FX5200 ...
    1.61 MiB
My Intel SE440BX-2 Intel's website Mirror : Modified to include docs, refs and BIOSes.
Proud owner of a TL866 II
Personal GitHub
Reply 35323 of 53191, by cyclone3d
chrismeyer6 wrote on 2020-08-04, 17:20:
Is it at least 128bit 5200? If it is you can usually clock it to the 5500 speeds
No... see the empty RAM pads?
Yamaha XG repository
YMF7x4 Guide
Aopen AW744L II SB-LINK
Reply 35326 of 53191, by chrismeyer6
cyclone3d wrote on 2020-08-04, 17:26:
Good point not sure how I missed the empty ram pads. It still can be over locked to 5500 speeds
Reply 35327 of 53191, by cyclone3d
A boxed CMS-401. I was hesitant to post seller pics because of how little I paid for it. It arrived today and I haven't had a chance to test it yet.
Seller's pic:
325.24 KiB
It actually came with more than what was in the pictures.
1. The warranty cards with the serial number for Cakewalk 3 written on one of them.
2. A post card from Cakewalk having to do with some licensing litigation between them and CMS.... which verifies that the seller was the original owner of this card.
YMF7x4 Guide
Reply 35328 of 53191, by Artex
cyclone3d wrote on 2020-08-04, 18:32:
WHOA! Absolutely awesome!
Reply 35329 of 53191, by kolderman
A boxed CMS-401. I was hesitant to post seller pics because of how little I paid for it. It arrived today and I haven't had a ch […]
Seller's pic:
What is it? Is the box a break-out box or a midi module? If the latter can you post some recordings?
Reply 35330 of 53191, by rikukos
Unbelievable price for an awesome find !!
4.97 KiB
Reply 35331 of 53191, by imi
so I found this hiding on ebay...
Intel InBoard XT to 386DX upgrade card :3c ...I wonder if this works fine in XT clones too, needs a good clean though ^^
286.1 KiB
Reply 35332 of 53191, by cyclone3d
kolderman wrote on 2020-08-04, 19:26:
Seller's pic:
The box is a box.
YMF7x4 Guide
Reply 35333 of 53191, by kolderman
cyclone3d wrote on 2020-08-04, 19:50:
Seller's pic:
The box is a box.
Haha ok.
Reply 35334 of 53191, by Predator99
imi wrote on 2020-08-04, 19:28:
Ah, happy you got it. I was the 2nd high bidder, sorry for that...
Reply 35335 of 53191, by Predator99
Quite surprised my price proposal was accepted, but I think it was fair.
- CT1350B
- MACH32 ISA
- several SBCs
- MFM controller
- 2x ET4000 ISA
- ET4000 VLB
- 386/387
    522.39 KiB
    507.71 KiB
    495.47 KiB
Reply 35336 of 53191, by imi
Predator99 wrote on 2020-08-04, 21:44:
🤣... ofc it was you again! x3
how'd you find it even, the title was so nondescript
also nice stuff D: I didn't see that one.
Reply 35337 of 53191, by BetaC
I managed to find one of those old, now kinda-rare Sonnet PATA cards.
1.39 MiB
Thanks to this, my SSD Equipped G3 will now be appreciably faster, even if OS9 doesn't actually need to be faster in my setup.
Reply 35338 of 53191, by cyclone3d
Artex wrote on 2020-08-04, 18:37:
Thanks Artex! We are usually being wowed by your purchases.
YMF7x4 Guide
Reply 35339 of 53191, by foil_fresh
Joseph_Joestar wrote on 2020-08-03, 18:04:
i managed to get S3D terminal velocity running last night. beware. it is a nightmare. I'm running a diamond stealth pro 2000 4mb (virge DX).
the s3d versions of these games expect the 325 core (original virge, not gx/dx/gx2 etc) so you need to run a TSR and special launcher to run the games. I must have spent about 2 hours trying to get it working in Win95, but only just managed to get Terminal Velocity running in DOS. to complicate things, i found 2 different sets of TSRs/launcher fix exes. One was a zip called "s3dtool" and another "s3dpatch". both have similar files but one has extra win9x vxd drivers.
under DOS - in theory, run the TSR, then run the game's exe via the fix.
ie, "C:\Games\TV3D\S3DSRVR.exe
C:\Games\TV3d\S3DRUN.EXE TV.EXE"
this is what the readme says... but I'm almost certain that I loaded the exe via the TSR - C:\games\TV3d\s3dsrvr tv.exe
It was 2am so i was pretty flat by that stage. I'll double check it tonight; gonna try to run Descent 2 and Actua Soccer.
i was blown away with how well terminal velocity ran in svga 640x480, maybe 5-10fps less than what i'd get at 320x200 res in my 166mmx. it did screw up with z-fighting a few times but it can be fixed by entering a 2d menu and back again.
