Reply 340 of 440, by Vynix
CuPid wrote on 2020-08-11, 15:00:
I've just released a new version of cpu-z vintage edition (1.02). The new features are : - AMD K5 model 0 (SSA/5). - Improved su […]
- Improved support of Cyrix Cx486DRx2/DRu2.
- Improved support of Ti486SXL/SXL2.
- Intel 430FX chipset.
- Opti 82C822 chipset.
- VIA VT82C505/VT82C486 chipset.
Official version : https://download.cpuid.com/cpu-z/cpu-z_1.02-win9x.zip
Beta version : http://download.cpuid.com/betas/cpuz_w95.zip
I'm currently working on adding the support of ISA/VLB video cards, if you have such a video card and are willing to help, you can use one the two versions listed above, save a Video BIOS dump from the tools button, and post it here. Thank you !
I could try this with a Cirrus Logic VLB card that I've got lying somewhere, though I won't immediately be able to pull the BIOS dump (it's currently inside a 80486DX4-100 system that I need to get from my uncle's house).
Give me maybe 2-3 weeks and I'll try to get this sorted out.
Reply 341 of 440, by Disruptor
CPUID 1.01.0.w9x hangs at 5 % on a VIA C3 - 1 Giga Pro (VIA Samuel 2 CPU). Mouse is stuck.
CPUID 1.02.0.w9x hangs at 5 % on a VIA C3 - 1 Giga Pro (VIA Samuel 2 CPU). Mouse is stuck. The beginning of the video memory is scrambled.
Windows 98 SE.
BIOS labels CPU as "VIA C3 - 1 Giga Pro".
CHKCPU identifies the CPU as
CPU-ID Vendor String: CentaurHauls
CPU-ID Name String: VIA Samuel 2
CPU-ID Signature: 0673
CPU is 6x86 class, but does not support CMOV instruction.
Reply 342 of 440, by CuPid
Disruptor wrote on 2020-09-19, 10:08:
CPUID 1.01.0.w9x hangs at 5 % on a VIA C3 - 1 Giga Pro (VIA Samuel 2 CPU). Mouse is stuck. CPUID 1.02.0.w9x hangs at 5 % on a VI […]
Windows 98 SE.
Thanks for the report.
Can you please copy that file cpuz.ini in the same folder as cpuz_w9x.exe, and try to run the application again ?
    cpuz.ini
    296 Bytes
    100 downloads
I need a vacation.
Reply 343 of 440, by Disruptor
CuPid wrote on 2020-09-20, 16:29:
Windows 98 SE.
Same result. Video memory is not scrambled anymore.
Also same result with this cpuz.ini
Video memory is also not scrambled.
[CPU-Z]
VERSION=1.0.2.0
TextFontName=
TextFontSize=14
TextFontColor=000080
LabelFontName=
LabelFontSize=14
ACPI=0
PCI=0
MaxPCIBus=256
DMI=0
Sensor=0
SMBus=0
Display=0
UseDisplayAPI=0
BusClock=0
Chipset=0
SPD=0
XOC=0
CheckUpdates=0
ValidUsername=
ValidEmail=
ValidPublish=1
Reply 344 of 440, by CuPid
Disruptor wrote on 2020-09-20, 18:04:
Same result. Video memory is not scrambled anymore. […]
Windows 98 SE.
[CPU-Z]
VERSION=1.0.2.0
TextFontName=
TextFontSize=14
LabelFontName=
LabelFontSize=14
ACPI=0
PCI=0
MaxPCIBus=256
DMI=0
Sensor=0
SMBus=0
Display=0
UseDisplayAPI=0
BusClock=0
Chipset=0
SPD=0
XOC=0
CheckUpdates=0
ValidUsername=
ValidEmail=
ValidPublish=1
OK thank you, I think I know what's wrong, can you please download and try that version ?
https://download.cpuid.com/betas/cpuz_w95.zip
I need a vacation.
Reply 345 of 440, by Disruptor
CuPid wrote on 2020-09-21, 17:33:
Sorry, you were wrong. Same result.
Reply 346 of 440, by CuPid
Disruptor wrote on 2020-09-21, 18:13:
OK thank you.
Here is a new test version, can you please use the ini included in the zip ?
Thanks.
https://download.cpuid.com/betas/cpuz_w9x_test_0.zip
I need a vacation.
Reply 350 of 440, by mkarcher
CuPid wrote on 2020-09-24, 18:14:
Hum this one is a struggle.
I joined the struggle. It turns out that there is no agreement between different environment on how to handle the x86 instruction bytes 0F 3F 07 0B. If you just enter these bytes into Google, you will quickly find out that this sequence is commonly disassembled as vpcext 7, 0Bh. This is not a processor instruction, and will fault as undefined opcode on most x86 processors. The Hypervisor in Microsoft VirtualPC uses 0F 3F as entry point, and this instruction is used to detect the presence of this Hypervisor.
On the other hand, there is the "Alternate Instruction Set" of the VIA processors. As Wikipedia says
Wikipedia wrote:
The Alternate Instruction Set (AIS) is a second 32-bit instruction set architecture found in some x86 CPUs made by VIA Technologies. On these VIA C3 processors, the second hidden processor mode is accessed by executing the x86 instruction ALTINST (0F 3F). If AIS mode has been enabled, the processor will perform a JMP EAX[1] and begin executing AIS instructions at the address of the EAX register."
It seems the PC-Chips M787CLR mainboard boots into the operating system with the AIS enabled, which is known to be a very bad idea for system security, as the AIS (if enabled) can be used to fully bypass any kind of memory protection. CPU-Z calls the VirtualPC Hypervisor with EAX equal to 1, which is not at all a good address to jump to. I overwrote the offending instruction by 0F 0B 90 90, an opcode that is guaranteed by specification to raise an undefined opcode exception, followed by two NOPs. Now CPU-Z works on this machine (but it would fail to detect VirtualPC).
Reply 351 of 440, by ultra_code
Hello!
I noticed this little project of yours, so I decided I'd check out Vintage Edition v1.02 on my Pentium III-S 1.4Ghz rig to see how it stacks up against one of the last versions of CPU-Z supported by Win98SE that I know of (v1.57). I will say, I love the improvements to the readability of the text (I increased the size of the text in the .inf file for v1.57 for the text to be more readable) as well as some minor layout improvements. I also see that some more information is being displayed in the VE than in the older version. Keep up the great work!
To further help, I did notice one regression between v1.57 and VE v1.02 that I would like to report. It has to do with the VE not reporting my mainboard's "LCPIO", whatever that is. 😀
Here's the missing information from the VE report that's in the report from v1.57:
LPCIO Vendor		AsusTek
LPCIO Model AS99127F
LPCIO Vendor ID 0x5CA3
LPCIO Chip ID 0x59
LPCIO Revision ID 0x53
Config Mode I/O address 0x2E
Config Mode LDN 0xB
Config Mode registers
00 01 02 03 04 05 06 07 08 09 0A 0B 0C 0D 0E 0F
00 FF FF FF FF FF FF FF 0B FF FF FF FF FF FF FF FF
10 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
20 59 53 FF FE 80 00 00 FF 00 0C 7C F0 1F 00 00 FF
30 00 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
40 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
50 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
60 00 00 FF FF FF FF FF FF FF FF FF FF FF FF FF FF
70 00 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
I have included both reports as well as the above screenshot in the zip file attached for your assistance. If there's anything else you need from me, feel free to ask.
    CPU-Z Compare.zip
    51.06 KiB
    73 downloads
Builds
Reply 352 of 440, by red-ray
CPUZ fails to report tRFC, should it?
    RAV.txt
    246.31 KiB
    92 downloads
    tRFC is absent
Reply 353 of 440, by CuPid
the_ultra_code wrote on 2020-10-29, 21:42:
Hello! […]
Hello!
LPCIO Chip ID 0x59
Config Mode LDN 0xB
Thanks, I'll have a look. Amazingly the LPCIO as a device disappeared, but the hardware monitoring outputs of this LPCIO appeared. Most likely a bug somewhere.
I need a vacation.
Reply 356 of 440, by hasat
Hello, i tested CPU-Z Vintage edition 1.02.0 on my current PC for Win98 games (installed system is Windows ME) and almost all is detected, except graphics card. On this tab is only Revision field filled and that's all. And second thing: on SPD tab, first memory module don't have manufacturing week and year filled, but in txt report is reported correctly - interesting. Report attached
GPU is Nvidia GF2 MX400 with 64 MB
Driver version 45.23
    CPU-Z Duron.txt
    28.68 KiB
    91 downloads
Reply 357 of 440, by Schule04
https://valid.x86.fr/tmse16
It's actually an Embedded Pentium 266, not a mobile one. But I guess there's no way for CPU-Z to tell the difference as both apparently use the same exact die.
Reply 358 of 440, by Takedasun
STB Nitro DVD 4MB AGP.
9.21 KiB
61.25 KiB
    mpact2.zip
    2.53 KiB
    60 downloads
Reply 359 of 440, by SteveC
Here's a few. AST Bravo MS Motherboard (HX chipset) with an Intel P133 (@133MHz), a Cyrix 6x86L P200+ (@133MHz - I can't do 75MHz bus on this board!) and a Cyrix 6x86 P150+ (@120MHz, and a million bent pins, and this got HOT!).
The board has 16Mb (2x8MB FPM SIMMS), no L2 cache (no COAST module) and an ATI Mach64 graphics chipset.
Cheers,
Steve
    1.08 MiB
    299.9 KiB
    Eurgh!
    AST-PC P200+ at 133MHz.txt
    8.67 KiB
    83 downloads
    AST-PC P150+.txt
    8.67 KiB
    79 downloads
    AST-PC P133.txt
    8.74 KiB
    77 downloads
