Reply 36140 of 53040, by mpe
Williwinner wrote on 2020-09-24, 12:41:
Very cool guy. Gave me the pin-layout for it.
Got one a few weeks back. Can you share the pinout please?
Blog|NexGen 586|S4
Reply 36141 of 53040, by Hanamichi
mpe wrote on 2020-09-24, 13:43:
Count me in too if you don't mind. I had the Hiscore a while from a German seller who seemed to have a MIRO collection. Sadly it always freezes launching a 3DFX game.
Recently got the PURE3D and no issues
@mpe some of the legs on your bottom 3DFX chip are in need of alignment, mine was similar.
Recommend a fan in a faster system.
1.57 MiB
Reply 36142 of 53040, by Williwinner
Here you go.
    Miro-Mini-DIN-9-PIN.pdf
    22.95 KiB
    89 downloads
Reply 36144 of 53040, by Aublak
Williwinner wrote on 2020-09-24, 11:18:
20200924_131114.jpg […]
Took me some time to find one at a reasonable price. Finally have a Voodoo Card with 6mb (Miro Hiscore 3D).
Sadly came without the VGA to Mini Din 9-Pin cable. So if sb knows how to get one of these, that would be very much appreciated!
That's a really beautiful looking Voodoo1. 6mb too.
Reply 36145 of 53040, by Hanamichi
Williwinner wrote on 2020-09-24, 14:49:
Here you go.
Thanks very handy 😀 I use a kramer vga switcher atm does the job if you don't mind another box.
Williwinner wrote on 2020-09-24, 14:52:
Hanamichi wrote on 2020-09-24, 14:29:
Just a bit of dust. Thank you!
Don't worry, yours looks good. I was just worried about @mpe's card
You actually made me take a closer look at my Hiscore. Found two smds that have cracked solder on the back so i'll try and fix it, thanks again!
Reply 36146 of 53040, by Williwinner
dionb wrote on 2020-09-24, 13:35:
It's Miro day today it seems. Here's what I just received: IMG_20200924_151911.jpg […]
Great serendipity. Was lamenting not having an OPL4-based wavetable card while discussing somebody's Miro PCM20. What turned up on a local site literally minutes later for a very reasonable price? Yep, this beauty.
Amusingly the topic also referenced a Terratec Maestro 32/96, and sure enough this seller also had one of those too 😜
(and no, I'm sure it's not the same person)
Unfortunately that one was priced closer to the going rate, more than I'm currently able to justify to myself, so let that one pass.
Awesome card that Miro PCM1 Pro!
Reply 36147 of 53040, by hejluxom
Got myself a winXP gaming laptop, just because I like myself so much. 😁
Dell XPS M1710. This is the basic model with Core2Duo 2Ghz and Geforce 7900GS. Highest you can go is T7600 + 7950 GTX + 4gb ram + blue ray drive.
Luckily it came with 2Gb RAM and SSD drive.
Though I think they should have added more LEDs to it, to make it a bit more blingy...
Reply 36149 of 53040, by Warlord
Artex Engaged
Reply 36150 of 53040, by Warlord
Artex Disengaged
Reply 36156 of 53040, by Horun
Warlord wrote on 2020-09-24, 19:59:
Artex Engaged
Nice bunch of stuff ! All I found was a IDE CD/DVD burner from 2002, works just fine (can never have enough cheap PATA/IDE drives 😀 )
Reply 36157 of 53040, by devius
hejluxom wrote on 2020-09-24, 19:05:
Definitely needs more LEDs!
Reply 36158 of 53040, by Hanamichi
A fellow Quad DAMAGE SLI fan! If only it was possible with so many voodoos to hand.
Nice Quadro II pro, looking for one of those for a while.
I fear Artex's comeback may break the internet and/or be hazardous to other collectors state of mind 🤣
Reply 36159 of 53040, by EvieSigma
Got myself a winXP gaming laptop, just because I like myself so much. :D Dell XPS M1710. This is the basic model with Core2Duo 2 […]
I have one of these too! 2.33GHz C2D, 4GB of RAM, GeForce 7900GS, and I installed a 240GB SSD. It runs XP...quite quickly!
