cyclone3d wrote on 2020-10-04, 01:14:Also pretty sure there is at least 1 OPL4 card that has working DOS midi.
I have an Analog Devices based ISA card with also the OPL4-ML chip, or YMF704C-S (datasheet available at) with 1MB GM sample set - on the card itself. This old thread shows how daughterboards based on that chip variation also exist(ed). See also this old thread.
The other (or perhaps more accurately, main) OPL4 chip variant was the YMF278B (PDF data 4.7MB) whose GM sample set was, at 2MB, twice the size of the 704C, and which I believe had potentially more flexibility in terms of bank configuration, accessing external RAM etc. More capable, basically - the "flagship" version of the OPL4 lineup. I believe (as per reasons below) you will only find this chip on soundcards themselves, and not on separate daughterboards.
A factor noted in the 704C docs is "contains an interface which is compatible with MPU-401 UART mode". I may be misconstruing this, but I believe it indicates how the 704C was used more extensively (if not exclusively*) when it came to "OPL4"-based daughterboards, because that inbuilt interface (and the omission of the 278B's more featureful ROMplering) enables a simple partnering with third-party cards via the standard waveblaster connection.
*To add further complication there is also the YMF721 aka the OPL4-ML2 (PDF data 461KB), which seems to essentially be an updated "V2" of the 704C. Again with 1MB sample set, and MPU-401 UART interface compatible, and designed to greater simplicity + lower cost than the 278B. So I suspect that these -ML chip variants - the 704C and the 721 - are what you will find on all "OPL4" daughterboards.
I hope this information aids your search.
