Reply 16900 of 31257, by kolderman
Wasted hours destroying a win98 build by trying many different drivers to get a SB Live! working.
Realized I had the wrong audio device selected as preferred in Multimedia 😒
Reply 16901 of 31257, by ultra_code
kolderman wrote on 2020-10-11, 07:23:
That oversight. Happens to the best of us. 😭
Builds
Reply 16902 of 31257, by TechieDude
Cloudschatze wrote on 2020-10-08, 04:00:
And... the full-color/resolution version of the active Windows wallpaper is now displayed in-place when launching an application that leverages the Tandy graphics chipset.
Why, I'm practically a shoo-in for the "Worlds Biggest Dork" award!
That's something to be proud of! 😁
Reply 16903 of 31257, by RetroLizard
How easy would it be to 3D-print an AT/486 style case? Are there any sites/services that offer such a thing?
Reply 16904 of 31257, by wiretap
RetroLizard wrote on 2020-10-11, 19:39:
Cost prohibitive. You'd need a very large format 3D printer or pay an insane amount of money from a print service. But of course, it could be done if you designed one to be printed.
What would be easier is just use an existing chassis, and 3D print a front panel in any design you want. Even a small 3D printer could be used since pieces could be bolted together in a modular format.
My Github
Circuit Board Repair Manuals
Reply 16905 of 31257, by kolderman
wiretap wrote on 2020-10-11, 21:39:
Pretty sure Retro Man Cave reviewed 3d printed Amiga case reproductions...it can be done.
Reply 16906 of 31257, by wiretap
kolderman wrote on 2020-10-11, 21:52:
I know, that's what I said.
My Github
Reply 16907 of 31257, by Dosboxxer
Transferred files from my modern computer to my old computer via USB 1.0 and waited ridiculous long times. xD
My RetroRig: IBM 300gl, Pentium II 400, 192mb Ram, S3 Trio64 2mb, SB16 Value
Win98 SE 4.10.22222 A
Reply 16908 of 31257, by ultra_code
Dosboxxer wrote on 2020-10-11, 22:52:
Transfer via Ethernet. Very fast.
Builds
Reply 16909 of 31257, by Dosboxxer
the_ultra_code wrote on 2020-10-11, 23:42:
Great Idea! Any specific PCI cards for Win98 you would recommend? 😀
Reply 16910 of 31257, by TechieDude
You could use a USB 2.0 card as well. Those with NEC chipsets work nicely.
Reply 16911 of 31257, by appiah4
TechieDude wrote on 2020-10-12, 00:34:
As do VIA ones in my experience.
Reply 16912 of 31257, by ultra_code
Dosboxxer wrote on 2020-10-12, 00:03:
This StarTech ethernet PCI card works great in my Pentium III-S machine.
https://www.amazon.com/gp/product/B0000TO0BQ/ … e?ie=UTF8&psc=1
Builds
Reply 16913 of 31257, by Shagittarius
the_ultra_code wrote on 2020-10-12, 07:46:
I got that same card to try and add Gigabit to my 98/XP machine but I didn't have any luck it didn't run any faster than the onboard 100 network port on the motherboard. Did you have to do anything special to reap the gigabit speeds of that card?
Reply 16914 of 31257, by Thermalwrong
It's do-able, just it'll need to be multiple parts that all fit together. Ideally with some steel or aluminium bar giving some rigidity to the object. I've been pondering it for a while but not getting very far with it yet. Having a surface large enough to work as a side panel is rather tough with the size limit of the Prusa i3, which is slightly smaller than a sheet of A4 paper in total print area.
I made this bezel a while back, it prints in two parts and slots / glues together - this should give you a good idea of the scale of a PC compared to a 3d printer's print bed. This is a small Micro ATX case (Yeong Yang A210) and it still had to be printed in two parts. Getting such a big and complex print to stick for all 8 hours of print time was tough as well.
I should really put some time into wiring up the 'turbo' display for this thing at some point 😀 It's got a 386DX40 in there
Reply 16915 of 31257, by ultra_code
Shagittarius wrote on 2020-10-12, 16:34:
Um, actually, I'm not sure if I have measured the speed of the card. I'll get back to you on that. But I've had no issues with it.
Builds
Reply 16916 of 31257, by TechieDude
appiah4 wrote on 2020-10-12, 07:28:
For some reason, my VIA card didn't quite work out. It always threw "File not Found" errors mid-transfer. Somehow, I got it to work reliably on my Socket 7 system now, and it still works there, but I have no idea how, or why 🤣
NEC cards, on the other hand, never gave me any issues.
Reply 16917 of 31257, by newtmonkey
Yesterday I ran into the first game that would not work with my MT-32 connected through PCMIDI card (The Magic Candle II). Nothing I did could stop the game from freezing on the initial "MINDSCAPE" screen, so I put it aside for a bit and then wondered if it might be one of those rare games hard coded for IRQ2 only. If so, that would mean I'd be completely out of luck, as my bios uses IRQ2 for ACPI.
Today after work I went through the manual for my motherboard to see if I could disable IRQ2/9 somehow, and I found some promising settings and went to work. I was able to free up IRQ9 in the BIOS, so I set the PCMIDI card to IRQ2 and ran MQDIAG, which showed the PCMIDI card on IRQ2. I then launched The Magic Candle II—success! It seems that the game does in fact require the MIDI interface to be set to IRQ2.
It was a bit of a pain, but I'm glad I have the PCMIDI card now set to the default IRQ2/Port330. This should eliminate any other possible incompatibilities I might run into later on!
Reply 16918 of 31257, by Gabriel-LG
Last week, I burned a Windows 98 SE CD-rom ISO.
In the process I (re)learned the following:
  • My stash of ~10 year old (Maxel) DVD-R is still good 😁 (event though it has been exposed to a wide range of temperatures, never to UV light though)
  • Burning a CD image onto a DVD works fine, but it will not be bootable. So I need an actual CD-R to get the job done.
  • CD-R's are still sold 😀 (are they still manufactured?)
Reply 16919 of 31257, by Bancho
Tested out the Iwill XA100 Plus SS7 motherboard today. Happy that it actually works.. and I think this looks to be a fantastic board! I had to update the BIOS to the latest version, as it would not correctly detect my K6-III+ CPU and the performance was dreadful. Downloaded the BIOS from Jan Steunebrink's site and flashed it with the programmer I have. Performance looks to be where it should, and this is the G Rev of the Ali-V so it looks like its not affected like the Asus P5A.
The awesome feature about this board though is the SoftFSB in the BIOS. Combined with Setmul could this be the best board for SS7 Slowdown machine?
Speedsys at 115 x 5 (not fully stable!)
Speedsys at 66 x 2 133mhz
Need to really sit down with it now and map out the speeds of the CPU with cache manipulation.
