Best old MP3 player for Win 9x/XP ?
First post, by Horun
What is your personal best MP3 software player for older OS ?
My fav is MusicMatch v8 (2003) which has MP3Pro with Fraunhofer II S decoding.
Reply 1 of 36, by leileilol
Everyone I knew used WinAMP then (note:NOT WinAMP V3)
FUCK "AI"
Reply 2 of 36, by shock__
Winamp to this day (albeit along AIMP by now).
Definitely not Sonique with its weirdass interface and slow decoding.
Current Project: new GUS PnP compatible soundcard
[Z?]
Reply 3 of 36, by Cyberdyne
I use WinAMP even now 2.95 for older Windowses and and version 5.8 in my main Windows 7 system. I have not find a better music player. WinAMP for music. Media Player Classic for Videos. Why upgrade a good working system. Winamp version 3.x is like Star Wars prequels.... 😁
Reply 4 of 36, by dr_st
I'm a happy Winamp 2.x user on legacy systems myself. There is an mp3PRO plugin for it as well (and many other plugins).
Reply 5 of 36, by chinny22
When I upgraded to Win7 about 10 years ago I moved to WMP and updated my library with album covers etc
It was that time WMP became the default player on XP rigs, in fact have my "XP Jukebox" playing right now as background music.
Before that point it was Winamp 2.x which is still what I use on the 9x machines.
Reply 6 of 36, by Zup
I'd recommend Winamp 2.x, too. In my Ryzen computer I use audacious, with the Winamp look (maybe some version of audacious can run on Win 9x as well).
I'm selling some stuff!
Reply 7 of 36, by zyga64
In my case it was Winamp for Windows98 and Foobar2000 for Windows XP.
8088@8 /640k /Genoa CGA /ALS100
286@20 /4M /CL-GD5422 /CMI8330
486DX33 /16M /TGUI9440 /GUS+ALS100+MT32PI
K6-2@400 /64M /MGA-2064W+3dfx /YMF718
P!!!750 /256M /MX440 /Vibra16s+SBLive!
Reply 9 of 36, by texterted
What's the last version that works in 98?
Anyone know, thanks?
Cheers
Ted
98se/W2K :- Asus A8v Dlx. A-64 3500+, 512 mb ddr, Radeon 9800 Pro, SB Live.
XP Pro:- Asus P5 Q SE Plus, C2D E8400, 4 Gig DDR2, Radeon HD4870, SB Audigy 2ZS.
Reply 10 of 36, by dr_st
As far as I can see, even some 5.x versions work, but you probably want to follow the recommendations here and use 2.95.
Reply 11 of 36, by darry
foobar2000
Yes, there is an old Windows 98 compatible version . I use it for flac playback, but mp3s should work well too .
Reply 12 of 36, by PTherapist
I agree with everybody else, use Winamp 2. Even some versions of 5 should work, but for a 98 machine you don't really need the extra bloat.
Avoid Winamp 3 like the plague, it truly was terrible!
Reply 13 of 36, by texterted
dr_st wrote on 2020-10-15, 12:28:
Thanks! That's just as I remember it and it works just fine.
Cheers
Ted
Reply 14 of 36, by Horun
Thanks ! S0 Winamp 2.95 for WIn9x and 5.8 for XP and Win7... and get the MP3pro plugin..
Reply 15 of 36, by Intel486dx33
VLC media player works with many different OS.
Reply 16 of 36, by Jorpho
There's really no reason not to use Winamp 5 instead of Winamp 2; reportedly they share much of the same code, and of course you would expect Winamp 5 to have fixed some of the bugs. You can just remove stuff like the Winamp Library and CD-ripping support during install (along with "modern skin support", if I'm not mistaken).
Eagerly awaiting https://getwacup.com/ to emerge from beta.
Reply 17 of 36, by leileilol
Intel486dx33 wrote on 2020-10-15, 23:55:
Hasn't worked on 9X for a long time and probably has regressed XP by now. It also has severe playback and UI issues.
FUCK "AI"
Reply 18 of 36, by debs3759
Does Media Player Classic work on Win 9x era hardware and OS? Comes with K-Lite Codec Pack, so plays anything.
Reply 19 of 36, by Jorpho
debs3759 wrote on 2020-10-16, 02:28:
The K-Lite Codec Pack more specifically comes with MPC-HC, which according to the FAQ requires at least XP SP3.
There are almost certainly older versions that will run in Win9x, but it most certainly will not "play anything" without suitable codecs, and installing codecs under Win9x was not an elegant process. But it ought to use the standard media player codecs for MP3s, at least.
