Reply 2901 of 4639, by HanJammer
imi wrote on 2020-10-20, 19:09:
all those CRTs :0
I catched the SVGA Mono 9" monitor and some older 15" Shamrock SVGA. Obviously I have no idea if they work. I leaved some 17" Belinea and 17" Samsung 795DF there - I have another one of those in much nicer condition, but also I have personal grudge against those monitors because like 20 years ago in my first job I was ordered to move alot of them around frequently, they are very heavy and I had to use staircases... They didn't want to buy me a platform trolley I requested, so I had to move them around manually... And I have a back problems now because of that. Immediately after them we started buying 15" Belinea LCDs and wow, what a relief it was, but sadly it was too late for my back.
Reply 2902 of 4639, by HanJammer
Some more pics from today... for now that's all but I know there is more of this stuff there 😀
Reply 2903 of 4639, by HanJammer
some more..
Reply 2904 of 4639, by HanJammer
and more...
    886.4 KiB
    A supply of 5,25" floppies, some still in sealed boxes...
    1.49 MiB
    Soyo 430HX motherboard with some random Pentium
    1.68 MiB
    J-Bond PCI4000-C motherboard with blue laminate and 5x86-P75
    1.82 MiB
    This very nice full AT motherboard missing all the necessary stuff... it's NEAT mobo, I might have look into repopulating the sockets, also 286 BIOS Archive here on VOGONS has the BIOS
Reply 2905 of 4639, by HanJammer
...and more...
    1.43 MiB
    CT4520, 2 XT multi I/Os and some communications card
    1.41 MiB
    Old Gateway ethernet card, WDC MFM controller card, UMC MFM controller card, Hercules graphic adapter - probably no longer working
    1.4 MiB
    Odd graphic card (perhaps EGA), Ultrastor ESDI controller, WDC MFM controller
    1.18 MiB
    VLB controllers, AD1848 sound card, Trident graphic adapter
    1.3 MiB
    Another trident, some Ethernet adapters and Zoltrix modem
Reply 2906 of 4639, by HanJammer
...and last pics - other stuff isn't really worth showing, some random cables, peripherals, electronic boards from some devices (with some nice sockets and logic chips I will desolder)...
Anyway, can't wait to check if these things still work or not.
    1.47 MiB
    Some more Hercules compatible cards and broken data acquisition card, but I can still make use of the chips on it...
    1.76 MiB
    CGA graphics adapter and IBM memory extension card for 5170
    1.53 MiB
    Random I/O card
Reply 2907 of 4639, by Horun
HanJammer wrote on 2020-10-21, 23:28:
Nice ! I always get a laugh at the old Mono / Herc video cards with LPT ports. Nice Memory expansion card !
Reply 2908 of 4639, by HanJammer
Horun wrote on 2020-10-21, 23:52:
Well, while Hercules display adapter and it's clones had the LPT for the backwards compatibility with MDA, it actually made a lot of sense to integrate Line Print Terminal (LPT) and monochrome display connectors on the original IBM MDA card. Both the printer and monitor were viewed as equivalent output devices back then.
Reply 2910 of 4639, by Gabriel-LG
Technically I did not find it in a dumpster, but for free on Marktplaats (Dutch Craigslist) near me. I picked it up this morning 😀
969.29 KiB
It is a Samsung SyncMaster 753DFX, in great condition 😀 This is my first CRT monitor since I switched to TFT 15 years ago.
The image is just lovely, it does take up a lot of real estate though 😦
1.07 MiB
The sound of static on the glass when it turns on 😀 but best of all, the sound of degaussing 😁
Reply 2911 of 4639, by chrismeyer6
I do miss the sounds of a crt. Especially the degaussing sound and the way the picture would get all warped.
Reply 2912 of 4639, by pentiumspeed
Decent monitor there. .28 pitch I had one but wore the CRT out from long hours years ago.
Cheers,
Great Northern aka Canada.
Reply 2913 of 4639, by MMaximus
Gabriel-LG wrote on 2020-10-22, 14:37:
Technically I did not find it in a dumpster, but for free on Marktplaats (Dutch Craigslist) near me. I picked it up this morning […]
Nice CRT - I'm actually surprised the wooden stand can withstand the whole weight of the monitor! 🤯
Hard Disk Sounds
Reply 2915 of 4639, by HanJammer
appiah4 wrote on 2020-10-23, 07:36:
What's the story with the red vacuum cleaner? 🤣
Some people just brought some broken stuff from their homes too...
Reply 2916 of 4639, by Deksor
HanJammer wrote on 2020-10-21, 23:13:
Random 486 with vlb
http://www.win3x.org/uh19/motherboard/show/3109
Reply 2917 of 4639, by HanJammer
Deksor wrote on 2020-10-23, 16:19:
Yeah, looks like it. I will test some stuff tomorrow. I don't really expect anything to work anyway 😀
Reply 2918 of 4639, by Aublak
I got a similar one, the 753DF. Its a great monitor. I wonder what makes your DFX version different.
Reply 2919 of 4639, by Deksor
HanJammer wrote on 2020-10-23, 23:24:
I uploaded some of your images in their respective pages we have 😀
https://www.ultimateretro.net/motherboards/3687
https://www.ultimateretro.net/motherboards/3238
Now for your second suntac 286 I noticed something very strange.
It looks exactly like my 286 that I uploaded here https://www.ultimateretro.net/motherboards/456
However mine has "286H" mention, and yours doesn't ... But it doesn't end here !
Your ROM says "KP286HF" ... but this is actually a motherboard name !
https://www.ultimateretro.net/motherboards/3839
But the board has a different layout ... What the hell ?
As for the Microstar 286 board, I can already tell that it won't work ... Someone seems to have taken off the crystals from your board x) (maybe even more stuff is missing ? who knows). Crystals are cheap and easy to install tho, so it might be worth trying new crystals 😀
Will you dump the bioses ?
