Reply 17360 of 31257, by Errius
I don't have any G3s with DVD drives, but I do have two G4 lampshades, and both have messed up drives that can no longer reliably read DVD-R disks. Only original disks work.
However, I understand Apple machines can boot from FireWire connected drives. So you can get a 5.25" external drive enclosure with FireWire connectivity, put a DVD drive in it, and it will function just like the internal one.
Is this too much voodoo?
Reply 17361 of 31257, by xcomcmdr
BetaC wrote on 2020-12-02, 03:04:
KCompRoom2000 wrote on 2020-12-02, 02:38:
Now the iMac G3 has a working optical drive again. While it's technically a downgrade from the semi-original broken DVD-ROM drive, I'm just glad to be able to read CDs on it again without them getting stuck in the drive. Besides, I never found a reason to use DVDs on this computer as I have plenty of other computers that are capable of this task and every piece of software that I have for it is on standard CDs.
Really, though, there's little point to having a DVD drive for G3s. If it was 1999 and DVD-Video was something to be proud of, sure, but nowadays it's really only useful for installing Tiger without burning four CDs.
Don't you touch my optical drives.
I have DVD Drives up to the roof and it makes my HAPPY.
Alright ?
Signed: "old" people like me.
Reply 17362 of 31257, by ragefury32
xcomcmdr wrote on 2020-12-02, 05:14:
Don't you touch my optical drives. I have DVD Drives up to the roof and it makes my HAPPY. Alright ? […]
Alright ?
Eeeeyeah. If someone perfects an optical drive Gotek that can work with JAE 50 pin (slimline laptop drives), IDE40/44 or SATA, you'll ditch the old optical drives in a millisecond, much like me. I only keep optical drives and media around because some vintage machines can't easily boot off commonly formatted USB drives, uses proprietary floppy drives and have hard drives that are a royal pain to get to (like, say, the Toshiba Portege M205 or the 15" Powerbook Aluminum).
Also, a G3 is perfectly cromulant for DVD playback, especially if you have a GPU with DVD motion compensation like a Rage128 - my Pismo Powerbook worked fine playing back DVD movies on its G3/400MHz card, and even better on its G4/550 MHz upgrade.
Reply 17363 of 31257, by ragefury32
Oh. Yeah. What did I do today -
Swapped out the busted motherboard on a Thinkpad 240 with a cheap, known good RMA replacement - done in 10 minutes, and the machine is now functional. Just have to fix a topcase fracture.
Popped in a 256MB PC66/100 144 pin module, an SD2IDE adapter, a 128GB MicroSD card and started some planning work on getting Windows 98SE onto it.
Reply 17364 of 31257, by xcomcmdr
Well no. I have a lot of old games to test/archive, which means a lot of optical discs lying around, and a lot of optical drives.
I also sometimes need to use an old optical drive in order to read/copy/run them (thanks DRMs). It also is part of the retro experience to me.
So I don't see it happenning anytime soon.
Reply 17365 of 31257, by ragefury32
xcomcmdr wrote on 2020-12-02, 05:40:
I am not sure what is the long term viability of original CDROM media as they age - my Unreal Tournament 2004 SE install CD (from the Atari Unreal collection) already exhibit bit-rot - the disk surface does not appear scratched but my my Lite-On, LG and Phillips DVD combo drives all seemingly have issues reading contents off the disk. I for one am glad that I didn't need to leave a disk in the drive to play certain games. That is my long term concern. The other concern is finding space to store the drives and the media.
Reply 17366 of 31257, by xcomcmdr
That's why I'm archiving them, too.
Reply 17367 of 31257, by BetaC
Alright ?
You don't need to tell me, I have both a CD and DVD drive in my 1.42 DP G4 for the sake of having both doors open. I was more making the point that G3 computers, in a modern setting, are rarely doing anything that would require more than a CD drive.
Reply 17368 of 31257, by bjwil1991
Did some work on the AMS laptop. Turns out the floppy drive isn't working at all (I took apart the broken Toshiba T4800CT and got the belt out of the floppy drive to replace the broken one in the AMS laptop) if I attempt to read diskettes. The floppy track spins, but the heads don't want to do anything, even though I greased the track and rails (it's possible the heads crashed). Another thing is the DSTN display is an eye sore, so the two items to fix or replace are going to be the floppy drive and the display from the dreaded DSTN to a TFT (found a parts laptop on eBay that I haven't bought yet that might share the same connections as the floppy drive and display).
Currently placing TSR and driver files onto my Packard Bell for the CMSLPT adapter, the video card drivers for Windows 95, and the monitor drivers as well since it never works past 800x600 resolution.
Reply 17369 of 31257, by xcomcmdr
To be fair I rarely use them.
But "rarely" here means 6 months apart between uses at most.
That may be too much optical drive usage for modern people.
Reply 17370 of 31257, by PTherapist
Not sure it counts as retro, probably stretching it a bit 🤣 -
but today I completely disassembled & cleaned out a fat PS3. This thing was literally full of dust in every nook and cranny you could find.
Also cleaned off the old crusty thermal paste from CPU & GPU and applied new thermal paste. Idle temperatures are now much lower and the fan is a LOT quieter, with fan speed controlled via webMAN MOD.
Reply 17371 of 31257, by BetaC
PTherapist wrote on 2020-12-02, 19:28:
You say it maybe isn't retro, and yet we are almost 15 years out from the launch of it. You might also want to look in to one of the japanese fans if you have the time and money, and assuming it isn't a ticking time-bomb Hardware Backwards Compatible model.
Reply 17372 of 31257, by Caluser2000
Fitted a 3Com Etherlink III network card in to my Redstone XT Turbo system, set it up to work in 8-bit mode and installed the packet driver for it.
Reply 17373 of 31257, by brostenen
Took my Amiga500 Revision 5 with internal HDMI for a spin, to test the stability of the adaptor.
Did not notice anything after testing some 15 games and watched 10 demos.
Reply 17374 of 31257, by aha2940
Went through another Dark Forces mission. I'm currently at mission 9: Nar Shaddaa. This game has been so far really funny, however I had to patch it to support mouselook, since I can't play with keyboard only anymore.
Reply 17375 of 31257, by ragefury32
ragefury32 wrote on 2020-12-02, 05:39:
Just finished up with the Win98 install. Had to enable fastvid and write combining to speed up the Neomagic 128XD. To be honest, this GPU received a lot of crap on Vogons for being slow. Yeah, but compared to what? It’s designed to be a power sipping 2D-only Mobile GPU. It does compare well with similar 2D only GPUs like the C&T 65550/Trident Providia. The S3 Aurora 64 (like the one on the Thinkpad Power 860) would have been ideal, but who knows what that’ll do to the design.
I tend to see smack talking and anecdotal evidence rather than actual benchmark numbers - from my own testing it seems to be just fine. D3D/OGL viable Mobile GPUs isn’t really a thing until the S3 SavageMX/IX or the Rage128 Mobility, and that's not available until you got to the Coppermine P3.
The attachment D3EA07E3-C72E-4A6F-B876-D29D8434E1B1.jpeg is no longer available
So how does it fare with the old stuff in DOS?
Pretty well.
Need for Speed...
The attachment A7F0D891-6935-4BA0-9EEC-FB99F77194E5.jpeg is no longer available
Stunts / 4D sports driving
The attachment 10D49655-9BB2-49F2-BCE0-B5D8FB647A7F.jpeg is no longer available
Oddly enough, Rowan games like Navy Strike or AirPowerhave no issues working in VESA mode for the Neomagic 128XD while running off the ATi Mach32 driver. It's fairly smooth.
The attachment 2A38B6CA-D4FD-4745-A889-2FE7DC0F9758.jpeg is no longer available
Prehistorik 2 only had some graphics glitches on the Hybrid banner intro. Gameplay is fine.
The attachment F62B3609-D290-425A-9192-0822577D25E8.jpeg is no longer available
Now if only CPUSPD supports Dixon128 / Mobile Mendocino machines for throttling, at least not on the base 300MHz model - cannot get Test Drive 3 or Wing commander 2 to work correctly in pure DOS mode since it’s way too fast.
Reply 17376 of 31257, by BetaC
aha2940 wrote on 2020-12-03, 02:54:
The game in it's base form supports mouse aiming, albeit horizontally only. I am still yet to try full mouse-look, but that's more down to me being too damn used to the normal mouse.
Reply 17377 of 31257, by pan069
I started playing a few months ago and got frustrated with the (seemingly) unnecessarily dark corners that are part of some levels. Even the first level has this dark cave part where you have jump across, I find that very frustrating. The levels don't seem to flow like they do e.g. in Doom.
Other than that, there is a lot to like about this game.
Reply 17378 of 31257, by TheAbandonwareGuy
So I pulled my XPS M1730 apart and re-pasted the CPU and GPU which solved the overheating problem. Unfortunately Murphys Law immediatly there after kicked in and the hard drive shat itself.
Tomorrow I'm going to put it in the hotswap bay and see if it will let me pull my KOTOR II saves off before failing entirely.
Reply 17379 of 31257, by stef80
PD2JK wrote on 2020-11-29, 21:16:
Wasn't happy with the noise from the sleeve bearing fan. So that's where two of my old friends come in, and keep the Palit GF3 T […]
Wasn't happy with the noise from the sleeve bearing fan. So that's where two of my old friends come in, and keep the Palit GF3 Ti200 cool.
yLABWo1Oyck8ry6Im5WAeRMS.jpg?f=user_large
Yes, it's a three slot cooler. 😉
Nice.
Back in the day I had Arctic Cooling VGA Silencer on my GF 3 Ti 200 (It covered all of ATI's R300 familiy and also GF3 Ti). Total overkill for the card, but looked powerful 😁.
