First post, by Per
In hinsight, I should have removed that battery years ago. On the other hand after a vinegar wash, solder mask held up allright, damages doesn't seem too bad, and looks quite fixable if I can get hold of the resistance values of the missing resistors.
If anyone has a similar board, I would be really happy if you could check up the resistor-values of R40-R46 for me.
A bit more info on the board, it's from an AT&T first generation Pentium (60MHz) machine, and seems like the board is named "PB5500C". It has an OPTi "Premium" 82C596/597 chipset.
