Reply 17700 of 27689, by Ozzuneoj
- l33t
Assuming the newer PSU you have already is of decent quality, you should be fine to just use a splitter. I believe molex connectors are rated for more amperage than SATA power connectors, but I don't think anything you've got there will be an issue unless you try to run all of them split off the same SATA connector. Someone correct me if I'm wrong.
Edit: By the way, I just saw the post where someone recommended the Ultra PSU to you. Their experience is perfectly legitimate, but there's a ton of reports of the complete opposite experience with these units. Whenever I research power supplies I always search for it with "badcaps", "jonnyguru"or "forum" at the end so that I'll find real community feedback, hopefully from experts, and I'll be able to see if there's a trend toward reliability or problems. Sadly, because these were seemingly marketed well (sold by Tigerdirect and microcenter, among others I believe), a lot of the feedback about them comes from users who likely never opened them up or tested voltages. They just used them and assumed all was good if they didn't explode. For reviews they only had to work right while the reviewer used them.
Also, with so many different manufacturers for the internals, a good batch of them may make them seem great, but you never know what you're getting when you buy one. I'm sure there are ones out there that work fine, but the trend is that they never used good components and had cooling issues. A bad combination.
