First post, by lazaj30
Hello,
First of all sorry for my bad english.
I want to install an Adaptec AHA-1542B on an Asus P2B motherboard. I've set the jumper on default settings on the 1542B isa card.
I have disabled the motherboard floppy controller in the motherboard bios.
Now the motherboard hang on boot at something like init pnp something ... before detecting ide drives.
I have tried the same thing without de AHA-1542B and same problem !
I want to use the adaptec card for the fdc controller.
Maybe somebody can help me here ?
Reply 1 of 11, by majestyk
It might be worth trying to remove the Adaptec ontroller, then reset BIOS to defaults completely (clear CMOS jumper), then turn on, enter BIOS and just disable onboard Floppy controller, power down, insert the Adaptec controller and restart.
If there´s no solution, why not live with the onboard FDC? There should be no big difference.
Reply 2 of 11, by dionb
Also don't see the added value of using the AHA-1542B FDC...
However I do see what the problem might be: the AHA-1542B is non-PnP. You've set default jumpers on the card, but the BIOS has no way of knowing what they are. That will only work if you reserve the resources (particularly IRQ) in BIOS for "Legacy/non-PnP", otherwise the IRQ is listed free for allocation to (PCI) devices. As you don't mention that, I'm assuming you haven't done so. Try reserving the configured resources in BIOS and see what happens. Might just work. Btw default IRQ for FDC is IRQ 6, so if everything is default, that's the one to reserve. You might also need to reserve memory range.
Reply 3 of 11, by lazaj30
majestyk wrote on 2021-01-28, 09:18:
I've tried that still no luck. Asus P2B rev.1.12 doesn't have clr CMOS jumper so I unplug it and remove the coin cell for 1 hour.
Reply 4 of 11, by lazaj30
dionb wrote on 2021-01-28, 11:08:
I don't mention that but I checked that all the settings (IRQ, DMA, ...) are ok.
I think that is a motherboard problem, when I remove the Adaptec ISA controller and disable fdc in bios the pc doesn't boot.
Reply 6 of 11, by dionb
lazaj30 wrote on 2021-01-28, 12:06:
Eh, that's weird, but clear enough: if it still fails to boot with AHA-1542B removed, then it's definitely in the motherboard.
On thing to try: ESCD reset - ESCD is where PnP stuff is stored. You do that reset by physically unplugging power from the PSU, then pressing the power button for >=5 sec (10 sec is recommended to be sure).
Reply 7 of 11, by PARKE
lazaj30 wrote on 2021-01-28, 12:03:
Some ASUS boards of that generation do not have a jumper but they do have two solder pads marked [CLRTC] wich stands for 'clear real time clock'.
According to the manual of my P2B-S you should:
-turn off the computer and unplug the AC power
-short the two solder points labeled CLRTC
94.97 KiB
Reply 8 of 11, by lazaj30
dionb wrote on 2021-01-28, 12:17:
Still no luck with ESCD reset 😭.
Reply 9 of 11, by lazaj30
PARKE wrote on 2021-01-28, 12:53:
Some ASUS boards of that generation do not have a jumper but they do have two solder pads marked [CLRTC] wich stands for 'clear […]
You're right, I have missed it !
Reply 10 of 11, by lazaj30
I've made some progress, I've got an Adaptec aha-2940 UW in this PC, if I remove this PCI card and disable fdc in bios the motherboard boot correctly.
With the aha-2940 UW and fdc disable in bios, the motherboard hang on PNP init ...
So maybe something with the aha-2940 UW ?
PS : aha-2940 UW bios version 2.20 (latest)
Reply 11 of 11, by lazaj30
An another update ...
I have found this article : https://storage.microsemi.com/en-us/support/s … mpatibility.htm
The aha-2940 UW was plugged in PCI port 3. I plug it in PCI port 4 and tada ! Problem solved !
Now it's time to try to use the aha-1542b fdc controller.
