Definitive list of all socket 5/7/SS7 cpus
First post, by Sphere478
Help me add to this list till it’s completed guys!
Anything that physically will fit in socket 5/7/SS7 counts! All the variants, all the rare ones, all unreleased engineering samples. If it fits it goes in the list! Let me know if there are any errors
Intel: Mhz fsb/core Notes
Pentium 75mhz 50/75
Pentium 90mhz 60/90
Pentium 100mhz 66/100
Pentium 120mhz 60/100 p54c
Pentium 120mhz 60/100 p54cqs
Pentium 133mhz 66/133 p54c
Pentium 166mhz 66/166 p54c
Pentium mmx overdrive 180mhz 60/180 p55c
Pentium 200mhz 66/200 p54c
Pentium mmx 166mhz 66/166 p55c
Pentium mmx 200mhz 66/200 p55c
Pentium mmx 233mhz 66/233 p55c
Pentium mmx tillamook 233mhz 66/233
Pentium mmx tillamook 266mhz 66/266
Pentium mmx tillamook 300mhz 66/300*
*(300 model is a chinese made socket 7 pcb package, with real intel silicon soldered in, but not a official intel chip release)
Cyrix: Mhz Fsb/core notes
M?? 550gp 400mhz 100/400 joshua core*
MII 433gp 300mhz 100/300 last official release
*rumor, unreleased chip before the cyrix team was disbanded
Rise: core. Model number
MP6 150 MHz MP6440DPF-ES
MP6 166 MHz MP6440DPF-ES
MP6 166 MHz MP6441RPFE4-ES
MP6 166 MHz MP6441RPFE4-Q
MP6 PR 233 MHz MP6440DPF-ES
MP6 PR 266 MHz MP6440DPF-ES
MP6 PR 266 MHz MP6441DPFH4-Q
MP6 PR 266 MHz MP6441RPFH4-Q
MP6 PR 333 MHz MP65PPAPG5-ES
MP6 PR 366 MHz MP65RPAPH5-DS
Amd: Mhz Fsb/core Notes
AMD-SSA/5-75ABR
AMD-K5-PR75ABR
AMD-K5-PR75ABR (With heatspreader)
AMD-SSA/5-90ABQ
AMD-K5-PR90ABQ
AMD-K5-PR90ABS
AMD-K5-PR100ABQ
AMD-K5-PR100ABR
AMD-K5-PR120ABQ
AMD-K5-PR120ABR
AMD-K5-PR133ABQ
AMD-K5-PR133ABR
AMD-K5-PR150ABR
AMD-K5-PR166ABQ
AMD-K5-PR166ABR
AMD-K5-PR166ABX
AMD-K5-PR200ABX
K6/PR2-166ALR
K6-166ALR
K6-166ALYD
K6/200AFR
K6/PR2-200ALR
K6-200ALR
K6/200ALR
K6-200ALYD
K6/233AFR
K6-233ANR
K6/233ANR
K6/233ANR (Big Logo)
K6/233APR
K6/233ACZ
K6/233ADZ
K6/266AFR
K6/266AFR (engraved)
K6/266ACZ
K6/266ADZ
K6/266ADZ (engraved)
K6/300AFR
K6/300AFR (engraved)
K6/300ADZ
K6-2/200AFR
K6-2 3D/233AFR
K6-2/233AFR
K6-2/233AMZ
K6-2 3D/250AFR
K6-2/266AFR
K6-2/266AMZ
K6-2/266ANZ
K6-2 3D/300AFR
K6-2/300AFR
K6-2/300AFR Black print
K6-2/300AFR-66
K6-2/300AMZ
K6-2/300ANZ
K6-2/300ANZ-66
K6-2/333AFR
K6-2/333AFR-66
K6-2/333AMZ
K6-2/333ANZ
K6-2/333ANZ-66
K6-2/337AFR
K6-2/337 38L3054
K6-2/350AFQ
K6-2/350AFR
K6-2/350AMZ
K6-2/350AFK
K6-2+/350AUZ
K6-2/366AFR
K6-2/366AFK
K6-2/380AFR
K6-2/380AFK
K6-2/400AFQ
K6-2/400AFR
K6-2/400AHX
K6-2/400ACK
K6-2/400AFK
K6-2+/400ACR
K6-2+/400ATZ
K6-2/433ADK
K6-2/450AFX
K6-2/450AGX
K6-2/450AHX
K6-2/450ADK
K6-2+/450ACZ
K6-2+/450ACZM
K6-2+/450ADZM
K6-2+/450ACR
K6-2+/450APZ
K6-2/475AFX
K6-2/475AHX
K6-2/475ACK
K6-2+/475ACZ
K6-2+/475ACZM
K6-2/500AFX
K6-2/500AHX
K6-2/500ADK
K6-2+/500ACZ
K6-2+/500ACZM
K6-2+/500ACR
K6-2/533AFX
K6-2+/533ACZ
K6-2+/533ACZM
K6-2/550AFX
K6-2/550AGR
K6-III/333AFR
K6-III/333AFK
K6-III/350AFK
K6-III/366AFK
K6-III/380AFK
K6-III/433ACK
K6-III+/475ACZ
K6-2 500mhz 100/500
K6-2+ 550mhz 100/550 128kl2 acz
K6-2+ 570mhz 95/570 128kl2 acz
K6-3+ 400mhz 100/400 256kl2 atz acr ack ahx afr
K6-3+ 450mhz 100/450 256kl2 acz apz acr ack ahx afc
K6-3+ 500mhz 100/500 256kl2 acz anz acr
K6-3+ 550mhz 100/550 256kl2 acr
IDT:
C6-DS180GAEM
C6-PS180GAFM
C6-PSME180GA
C6-PSMF180GA
C6-DS200GAEM
C6-PSME200GA
C6-PSMF200GA
C6-PSME225GA
C6-PSME240GA
W2-3DEE200GSA
W2-3DFF200GSA
W2-3DEE225GDA
W2-3DEE225GSA
W2-3DEE240GSA
W2A-3DEE200GSA
W2A-3DEE200GTA
W2A-3DFF200GSA
W2A-3DFF200GTA
W2A-3DEE233GSA
W2A-3DEE233GTA
W2A-3DFF233GSA
W2A-3DFF233GTA
W2A-3DEE266GSA
W2A-3DEE266GTA
W2A-3DFF266GTA
W2A-3DEE300GSA
W2A-3DEE30AGSA
W2B-3DFK200BTA
Sphere's PCB projects.
Reply 2 of 28, by Cyberdyne
Pentium 60 and 66 are all socket 4. First socket 5 cpus were 75 and 90.
PS. Never seen any info on a Pentium 50, if it existed, then only some internal Socket 4 engineering sample that nobody has in the wild.
Reply 3 of 28, by Sphere478
Cyberdyne wrote on 2021-01-28, 07:26:
I'll have to check. I swear my friend has a socket 7 60 I'll remove the 50
Reply 4 of 28, by dionb
Sphere478 wrote on 2021-01-28, 09:18:
Nope. What he might have is some other Pentium at a non-standard bus clock.
If you take a Pentium 75/90/100 (with 1.5x multiploer) and run it at 40MHz FSB (which was quite common on really early So5 boards), it runs at 60MHz. Doesn't make it a Pentium 60 though 😉
Reply 5 of 28, by Sphere478
dionb wrote on 2021-01-28, 11:11:
I must have remembered wrong 😀 removed from list 😀
Reply 6 of 28, by rmay635703
A80500-50 Q0399 engineering sample only
Reply 7 of 28, by Sphere478
rmay635703 wrote on 2021-01-28, 17:41:
How should it appear on list?
Reply 8 of 28, by Baoran
There are 400Mhz 450Mhz and 500Mhz version of K6-III+
There is no 550Mhz version. That is just overclocking if you run one at 550Mhz
Reply 9 of 28, by Sphere478
Baoran wrote on 2021-01-28, 18:51:
Lol. I own one. Yes there is haha
Adding those
Reply 10 of 28, by H3nrik V!
When is it a destinctive model? The Pentium 120 was available both with P54C (0.6u) and P54CQS core (0.35u) are they different models in your definition? As per my collection, they are 😀
And then, there's a million different Cyrix CPU's as well.
You might want to use feiopa's thread as a starting point: The Ultimate 686 Benchmark Comparison
Reply 11 of 28, by Sphere478
H3nrik V! wrote on 2021-01-29, 07:43:
can you edit OP in a quote and I will coppy and paste it to update? 😀
Reply 12 of 28, by majestyk
Sphere478 wrote on 2021-01-28, 18:59:
Adding those
Yep, I own two of them, running 100% stable @ 600 MHz
Reply 13 of 28, by Sphere478
majestyk wrote on 2021-01-29, 08:19:
Adding those
send them to me so I can" test" them in my Tyan Tomcat IV 😁 🤣
ps for those wondering: Dual AMD K6 computer
it most likely would not work in mine, but in a proprietary older board with upgrade adapters it just may.
Reply 14 of 28, by Baoran
Adding those
My 450Mhz one runs fine at 600Mhz too, but we are looking at official specs here because otherwise they could probably be considered to be the same cpu no matter what the official mhz rating is.
Reply 15 of 28, by majestyk
Baoran wrote on 2021-01-29, 18:22:
I´m quite sure all the chips came from the same production, the same wafers. They got tested for stability, graded and placed in groups afterwards. So at the end there were 450, 500, 550 MHz K6+ ready to be sold at different prices.
That´s what the economist calls "price discrimination".
A copy sold as 550 was in the most stable group, but a 450 would be as exactly as stable when overvolted 0,05V or 0,1V.
Reply 16 of 28, by Sphere478
Adding those
The k6+ cpus basically all report stability at or above 600 it’s like they all came from the same batch which makes sense as they weren’t produced long. The only real difference between them is the cache size the 2+ has 128k and the 3+ has 256k even the low voltage variants act the same, you can run them higher or the higher ones lower. My 550 3+ is running at 450 1.5v
Reply 17 of 28, by feipoa
If you are only interested in the CPU fitting, then all of the Cyrix MediaGX, GXm, and GX1 series. Better not power it on though!!!
Reply 19 of 28, by Sphere478
feipoa wrote on 2021-01-31, 00:28:
Yeah, basically if it fits it lists. Lol most if not all can be made to “work” with interposers or undocumented settings.
