Hello, I have the same motherboard and it has a socket for a battery, like CR2032. My question is: how many batteries it need, one or two? With only one battery the upper contact (+) does not touch the battery.
The motherboard does not run. it stops in C2C3 codes in the test card. Maybe it needs the battery to star to work.
I have remove the SIMMs modules and the graphic card and it stops in the same point.
It looks like the processor starts but something stops it.
Thank you very much.
Added: I have checked the +5V and 33Mhz in the socket and both are present.
The 32khz oscillator is working
Added: I have checked with another processor 80486DX2-66, instead of 80846DX-33, and the it stops in D3D2.
Added: Two broken tracks. After difficult repair (36 awg wire) without a microscope, motherboard is working but mi question remains, one or two batteries. Thank you.
