Reply 18400 of 31256, by wiretap
Yea it is dirt cheap to build. Like $15.. people on Ebay are selling them for $50+.. 🤣
My Github
Circuit Board Repair Manuals
Reply 18401 of 31256, by brostenen
wiretap wrote on 2021-03-11, 15:27:
Work woke me up at 4:50am this morning, so I soldered up a RGB2HDMI Amiga 2000 adapter. Still need to design and 3D print a brac […]
Work woke me up at 4:50am this morning, so I soldered up a RGB2HDMI Amiga 2000 adapter. Still need to design and 3D print a bracket. I have a nice HDMI adapter and button I'll put on the bracket.
Gerbers/Project: https://github.com/hoglet67/RGBtoHDMI/tree/ma … er/VideoSlot/V1
Mouser Cart: https://www.mouser.com/ProjectManager/Project … ssID=5747b1b210
Wow!!!!
You'r project? Or someone else is the author? I must say that the original project, aimed at the BBC Micro is really taking off.
I love the solder work that you have done. Good work. (and then a bunch of thumbs up smiley's)
Reply 18402 of 31256, by PTherapist
Today I finally got a CF card installed & working in my 4.77MHz IBM XT build with the XTIDE Universal BIOS (installed on a 3Com 3C509B Ethernet Card):
I tried first last week with a 64MB card and it wouldn't work at all on 3 different generic 16-Bit ISA I/O controllers.
Ordered a couple of CF cards to test further - a 128MB CF card worked perfectly, but a 256MB card did not - until I realised I'd altered the XTIDE drive config settings when trying to get the 64MB card to work. Once I fixed that and re-programmed the EEPROM, both the 128MB & 256MB cards worked great.
So I've decided to stick with the 128MB card, as it should be more than sufficient storage for an XT and could probably fit the entire 4.77MHz playable games library 🤣.
Partitioned the card into 4 partitions with IBM PC DOS 3.30 - 3x 32MB partitions & 1x 27MB partition. I'm using the CF card as an additional storage drive for now, leaving the installed 20MB MFM HDD as Drive C. However I did back up all of the HDD's contents onto the 1st partition of the CF card, just in case the HDD ever decides to pack up.
During testing, 1 of the 3 I/O controllers simply refused to work in the XT with any CF cards. This setup sure is picky! Weird that it didn't like the 64MB CF card at all, yet did like the larger capacity cards. I guess the 64MB card must be slightly non-standard.
Just need to try and figure out the jumper settings on the I/O card now, to enable the Serial Port and hopefully enable me to free up 2 ISA slots previously occuped by separate Serial, Parallel & Game I/O cards.
Reply 18403 of 31256, by wiretap
brostenen wrote on 2021-03-11, 15:53:
Wow!!!! You'r project? Or someone else is the author? I must say that the original project, aimed at the BBC Micro is really tak […]
Wow!!!!
It isn't my project, I just built it from the original creator's files on Github.
My Github
Reply 18404 of 31256, by brostenen
Yet another update on my SixtyClone.... The modern modulator replacement came in the mail today, and I am freaking ready to test with chips installed in the sockets. This have been a loooong way to this point. Not that it takes that long to solder and build. It is quite easy and simple to do. Yet I had to buy parts in small quanteties, and build a little by little, in order to be able to afford it. Except for the GND wire that are soldered directly to the modulator, then I have installed sockets and pins, to be able to take it off if testing is in need. 😉
So.... Pic's or it didn't happen' (so they say) It looks soooo good.
The attachment Board-01.jpg is no longer available
The attachment Board-02.jpg is no longer available
The attachment Board-03.jpg is no longer available
The attachment Board-04.jpg is no longer available
The attachment Board-05.jpg is no longer available
What do people think so far?
Reply 18405 of 31256, by brostenen
wiretap wrote on 2021-03-11, 16:03:
Wow!!!!
Ahhh...
Well. Good work on the soldering. Looks great, and you will have great and flawless video output. Just make sure that the monitor can do at least 1080P.
I am using a Dell 2001fp with a HDMI/DVI cable. Works perfect and every single pixel are inside a border. I think all 19 to 24 inch Dell FP monitors form the 00's can do it.
Reply 18406 of 31256, by wiretap
Thanks. I was going to try it on a 1280x1024 Eizo LCD.. (HDMI to DVI adapter). From the project files, it appears it does support that resolution. (hdmi_group=2, hdmi_mode=35)
My Github
Reply 18407 of 31256, by brostenen
wiretap wrote on 2021-03-11, 16:44:
That is exactly the resolution my Dell monitor is running with the RGB-to-HDMI.
Reply 18408 of 31256, by CMB75
brostenen wrote on 2021-03-11, 16:10:
Yet another update on my SixtyClone.... The modern modulator replacement came in the mail today, and I am freaking ready to test […]
I think it looks fantastic...
I'm still waiting for Mouser to deliver all the parts missing for my A500++ (some on a backlog until Dec.21)
The attachment PCB-A500PP-68060.jpg is no longer available
Reply 18409 of 31256, by wiretap
That SixtyClone and A500++ look nice.
CMB75 -- for your backlogged parts, aren't they available anywhere else, or an equivalent part offered? I know sometimes when I order on Mouser/Digikey and they are sold out of something, I can usually find an in-stock alternative that has specs within tolerance of what is needed (i.e. higher/lower temperature rating, automotive grade, etc)
My Github
Reply 18410 of 31256, by brostenen
CMB75 wrote on 2021-03-11, 20:09:
I think it looks fantastic... […]
Thanks. And nice board that you will be making. 😀
Reply 18411 of 31256, by brostenen
wiretap wrote on 2021-03-11, 21:02:
Thanks. 😀
Reply 18412 of 31256, by creepingnet
Bit the bullet, bought another NL6448AC30-06 for the "Ford" Versa. I think the V/50 will find a home at my work once that one is done.
~The Creeping Network~
Reply 18413 of 31256, by EvieSigma
Trying to install the remaining drivers I needed on the Aptiva somehow broke Windows 98SE so now I'm working on reinstalling it between doing my job.
Reply 18414 of 31256, by Jed118
PTherapist wrote on 2021-03-11, 15:55:
Today I finally got a CF card installed & working in my 4.77MHz IBM XT build with the XTIDE Universal BIOS (installed on a 3Com […]
I am having good results with Transcend cards, as well as Cisco ones. I have a generic 2GB (no name) and it's not entirely compatible. I got my XTIDE set up yesterday with a 3COM Ethernet III ISA card. I bought the ROM from eBay, it works great.
I have placed that 386 in its place of honour, and hooked up the other two retro machines also:
Yes, I need to load a graphics driver for the new graphics card.
The KVM is on the floor and the wiring's a mess, so I will have to build a bracket for it. I had a great time labelling the KVM selectors - 8086, 386, 486, 586 😁
8086 (V30 actually) is still in the basement - Can't wait to get SCSI working on that 😁
What's for sale? my eBay!
Reply 18415 of 31256, by Horun
Jed118 wrote on 2021-03-12, 01:37:
I have placed that 386 in its place of honour, and hooked up the other two retro machines also: Yes, I need to load a graphics d […]
Nice looking setup !!
Finished the original Age Of Empires 2 HD (only included Age of Kings and Age of Conquerors campaigns) so got the African Kingdoms HD version which included those of the original HD plus Forgotten and Afican Kingdoms campaigns.
Just to keep playing because it is a fun single player game 😀
Under WIn XP and Win7 had to install Visual C++ Redistributable for Visual Studio 2012 or would get a missing DLL error. The original 2 campaign version did not require it.
For those interested: minimum requirements:
CPU SPEED: 1.2 GHZ CPU
RAM: 1 GB
OS: Windows XP, Vista, 7, 8 Pro+
VIDEO CARD: Direct X 9.0c Capable GPU, PIXEL SHADER: 3.0, VERTEX SHADER: 3.0
SOUND CARD: Yes
FREE DISK SPACE: 4.5 GB.
So it will run well on any good XP machine 😀
added: here is what it looks like in 1080p mode
Reply 18416 of 31256, by CMB75
I think it was my mistake, actually. I ordered all missing BOM parts from Mouser and followed the thought “Let’s be environment friendly” and hit that “deliver everything in one shipment” button. Over the next couple of days the status changed repeatedly, even for parts which were supposed to be in stock already. Yesterday I changed the delivery to “ship what you’ve got”. So the first parts should be here soon.
Furthermore I have to admit I was too lazy to check my own storage what’s left from all those Ben Eater projects.
Reply 18417 of 31256, by DundyTheCroc
I have two 32GB DOMs, but SATA to IDE boards are still in transit from China, so decided to test them with what parts I have.
DOMs are with female SATA, so is the SATA to IDE board I have, and no male to male SATA adapter.
I have a pile of failed HDDs, so cut two male SATA connectors and solder them to each other.
The attachment con2.jpg is no longer available
Here is how that thing fits in SATA to IDE board:
The attachment con1.jpg is no longer available
And yes, it works, tested on 440BX board, Win98SE runs like rocket 😀
Reply 18418 of 31256, by bjwil1991
Swapped Bank 1 (all 9 sockets) with new 4164-15NL chips on my AST SixPakPlus RAM RTC Serial card and installed a CR2025 as a temporary battery so I can get a CR2032 or 2325 (if they are available to purchase). It keeps the time and date (found a Y2K patched version of the ASTCLOCK program) and I'm getting close to getting the Compaq Portable 1 to be completed. Only thing left is to replace the plastic guides for the long cards.
Reply 18419 of 31256, by CBM
I finished building and installing this XP computer:
Dell Dimension 9200
Core2Duo ZE6700 at 2.6 GHz
2 GB DDR2 memory
Radeon x600 256 MB PCI-E
Firewire PCI
500 GB SATA HDD
250 GB SATA HDD
128 GB SATA SSD
DVD-RW SATA
DVD PATA USB
3.5" Floppy
Cardreader USB
Win XP Pro 32 bit
and it also has a audio cable going from the front of the PATA DVD to the line in on the back
(until I get a USB PCI card in to connect the USB adaptor internally and a PCI sound card to connect a CD audio cable internally, I have both..somewhere and XP shouldnt mind multiple soundcards... the onboard soundcard works well with XP and yes all cables are tucked to the side now, so the side panel wont interfere with them)
it might be considered somewhat new but as long as it will play older windows games then I will be very happy
Main PC SPECS:
CPU: AMD Ryzen 5 2600
GPU: Powercolor Red Devil Radeon RX 5700 XT
RAM: 8GB*4 Corsair Vengeance LPX DDR4 3200MHz
Motherboard: ASUS Prime B450M-A
PSU: Corsair RM850
