Reply 18420 of 31256, by wiretap
Soldered up 3 more DIP to PLCC sockets for Amiga Super Denise upgrades. I had the parts on hand, so I figured I would get them done since they only take less than 10 minutes to put together. The DIP pins get put on first, then where the PLCC socket sits, those have to be trimmed flush with the board and soldered as low as possible. Then the PLCC socket goes on and is soldered from the bottom. It's a little tricky.
My Github
Circuit Board Repair Manuals
Reply 18421 of 31256, by Jed118
DundyTheCroc wrote on 2021-03-12, 08:25:
I have two 32GB DOMs, but SATA to IDE boards are still in transit from China, so decided to test them with what parts I have. DO […]
DOMs are with female SATA, so is the SATA to IDE board I have, and no male to male SATA adapter.
I have a pile of failed HDDs, so cut two male SATA connectors and solder them to each other.
Here is how that thing fits in SATA to IDE board:
And yes, it works, tested on 440BX board, Win98SE runs like rocket 😀
I've done this to build a male connector on the back of a multi/IO card using a cut part of a failed IDE hard disk. 40 pins (and a hour of soldering) later, I had my connector. Worked first try 😉
What's for sale? my eBay!
Reply 18422 of 31256, by appiah4
Ordered PCBs and ICs to make 5 Amiga 500 plipboxes. Three will be sold off, two will remain mine. My dream of operating a real hardware Amiga BBS is going to come true, almost 30 years later.
Reply 18423 of 31256, by pan069
wiretap wrote on 2021-03-12, 12:46:
Soldered up 3 more DIP to PLCC sockets for Amiga Super Denise upgrades. I had the parts on hand, so I figured I would get them d […]
Nice. Is there a preferred way to get chips out of a PLCC socket? I'm asking because I have a 286 in a PLCC socket that I want to swap out but I neither want to damage the chip or socket in the process. I.e. is it OK the use a small screwdriver to gentle loosen the chip bit by bit (alternating sides) or only use plastic tools etc?
Sorry, I'm a noob and never used any of these sockets before and prefer not to make mistakes if I don't have to 😀
Reply 18424 of 31256, by debs3759
pan069 wrote on 2021-03-12, 22:33:
Best way I know is to gently prise on alternate corners, where there are no contacts to damage. The sockets have a small gap there where you can insert a small tool like a screwdriver and get it under the chip. Be careful not to put pressure where there are pins/contacts.
Reply 18425 of 31256, by megatron-uk
debs3759 wrote on 2021-03-12, 22:52:
Get an extractor tool: https://www.google.com/search?q=plcc+IC+extractor
Honestly, they cost peanuts and they work so much better for PLCC and DIP extraction than the flat bladed screwdriver technique. I used the latter for years before I had one show up as a freebie in some electronics set I bought. I can't believe I persisted with a screwdriver for so long.
One of the problems with the screwdriver technique on PLCC sockets is that you invariably end up lifting one side of the processor before the other, and on PLCC processors like the 286 it's incredibly easy to end up bending one side of pins (which on these processors are just folded under... making them really delicate to sideways movement).
https://www.target-earth.net
Reply 18426 of 31256, by wiretap
PLCC removal tool is what I use. Super easy, doesn't damage anything, and they are dirt cheap.
My Github
Reply 18427 of 31256, by Jed118
Optimized my memory in the 386SX - The SCSI drivers for the CDROM were so demanding, but between SHSUCDX, a bus-compatible mouse driver from 1987, some switches and memmaker runs, I got this:
I also fired up my ancients to cycle those 7.2v CMOS batteries:
Reply 18428 of 31256, by Cloudschatze
Effectively completed the satellite rack/desk setup, including all of the programming of the MTP units that I care to do for now. Hooray.
Reply 18429 of 31256, by CBM
trying to install win98se on this old beast...
elitegroup k7s7ag
amd duron cpu
2xddr2 256MB sticks
old intel cooler
some weird onboard sis xabre agp card
searching online gives me inconclusive proof that drivers exists for everything on this board for windows 98
even their own site seems to not have full support for any one os on this board
some xp drivers, some 98, some win 2000 etc
none seems to be a full set
anybody have experience with this board?
Main PC SPECS:
CPU: AMD Ryzen 5 2600
GPU: Powercolor Red Devil Radeon RX 5700 XT
RAM: 8GB*4 Corsair Vengeance LPX DDR4 3200MHz
Motherboard: ASUS Prime B450M-A
PSU: Corsair RM850
Reply 18430 of 31256, by Joseph_Joestar
Cloudschatze wrote on 2021-03-13, 06:15:
That's some seriously impressive MIDI hardware!
My retro builds
Reply 18431 of 31256, by Munx
https://www.symphoniae.com/misc/vogons/wip4_s.jpg […]
Damn. LGR's midi mountain has nothing on your Midi Tectonic plate!
My builds!
The Underdog - The budget K6
Reply 18432 of 31256, by badmojo
Amazing and happy making, but where is the Midi General??
Reply 18433 of 31256, by janskjaer
Finished benchmarking these on my Chaintech 7VJL Apogee / AMD Athlon XP 2800+ setup.
Next step is to benchmark the same cards on my ASUS P3B-F boards with Slot 1 Intel Pentium IIIs.
DELL Dimension XPS M200s
:Intel P1 MMX 200MHz
:64MB EDO
:DOS 6.22/Win95b
:Matrox Millenium II + m3D (PowerVR PCX2)
:AMD AthlonXP 2700+
:512MB DDR
:Win98SE/2000 SP4
:3dfx Voodoo5 5500 AGP
Reply 18434 of 31256, by Klaatu
Just cleaned up and plasticoted an old chassis (feel free to flame away!)
Spent some time in the old 98 fdisk util - ah the nostalgia and excitement 😀 , installed 98/xp, and spent the rest of day rebooting and poking around in control panel/bios trying to get the thing working properly !#$@!
Reply 18435 of 31256, by PTherapist
I worked some more on my IBM XT build. Figured out some of the jumpers on the I/O card I recently installed and got the Serial, Parallel & Game ports all working. All done by trial and error, since I couldn't find any documentation for the I/O card. Thankfully the Turbo XT BIOS is very helpful, listing all the available devices and their addresses at POST.
I never managed to get the Floppy drive (or Gotek) working with the I/O card, no jumper settings seem to make a difference so I had to put the old Floppy Controller back in instead. I'll come back to that issue at a later date. The Floppy Drive is at least functional, using the original drive taken out of my Atari ST.
I temporarily removed the MFM controller card and set about trying to make the 128MB CF card bootable. Figured out XTIDE seems to not like IBM PC DOS 3.30, either from CF card or from the Gotek so I had to install IBM DOS 5.00 on it instead.
So now the setup is practically perfect - when booting from the MFM HDD, the Primary partition of the CF card is invisible (it's a backup/clone of the MFM HDD, so this is perfect) and the rest of the Extended partitions appear correctly with the correct drive letters, keeping my .BAT files all pointing to the correct places. I can access all drives & partitions if I tell XTIDE to boot from D at startup, which will be good for backup & maintenance purposes.
The only thing I might do in the future, is reorganise the partitions making the Primary partition smaller to match the MFM HDD and moving the free space to the end of the drive for an additional partition.
Reply 18436 of 31256, by CBM
just testet a bunch of games from my old pc game shelf ..some that had never been opened before
some games worked and some didnt despite it claims to work only on xp (hitman1-4) and others never completed an install (quale 4 and farcry)
the big surprise was how beautifull ut2003 still is on this old xp pro dell
Main PC SPECS:
PSU: Corsair RM850
Reply 18437 of 31256, by chrismeyer6
Klaatu wrote on 2021-03-13, 11:50:
That case came out great. You got a really nice and smooth finish with the plastidip.
Reply 18438 of 31256, by Jed118
How much power does all that draw?
That's a nice attic 😁
Reply 18439 of 31256, by fosterwj03
I did a bit more work on my Gateway 2000 sleeper build. I finished painting the 3.5” USB/Audio front panel yesterday, and I installed it into the case for a fit test today. The color isn’t perfect, but I think it will do. I did have a problem with securing it to the drive bay because the panel cannot get inserted from the rear of the case (the front bezel has tabs blocking the sides of the opening). The 5.25” bays block one side of the 3.5” bays when I insert something from the front. I managed to secure the new front panel fairly well, but it’s a little wobbly on one side.
I also drilled out and tapped two holes in the bottom of the case for standoffs. With the motherboard secured to the case, I mocked up the cable connections and performed some preliminary cable management.
It’s starting to look really good.
I still need RAM modules and the CPU. I’m starting to get a little impatient for Intel to release their Rocket Lake line.
