First post, by nathanieltolbert
First off, I'm positive that the strangeness I am seeing is something to do with the configuration I have, but I have been unable to identify it and correct it. I am hoping asking about it here will get some suggestions that will fix what I am seeing. The specifications of the machine are as follows
AMD-K6-III+ at 450MHz (not overclocked)
Gigabyte GA-5AX Rev 5.2 on F4 BIOS
128MB of CAS2 PC-100 SDRAM
32GB SD Card with SD to IDE Adapter
Voodoo 3 3000 PCI card (I think the BIOS says LC, but it flashes by so fast)
Turtle Beach Montego II Quadzilla Soundcard
Windows 98 SE
Okay, I was having very strange issues where I would attempt to boot into DOS and the machine would immediately lock up when attempting to run anything. It seems to have something to do with the AU30DOS SB pro TSR. Disable that and things run okay. I had a Diamond Monster Sound MX400 back in the day with my K6-2 350 and the follow up the K6-III 400 and I don't recall running into that issue, so I am at a loss on that one. But this strangeness is specifically with the video card. Now I am using the DOS Benchmark from Phil's Computer Lab, which I think is an excellent tool to check things, and it's very strange. Now I expect there to be a falloff when switching from 320x240 to 640x480, but it's very pronounced and slower machines in my collection from *Packard Bell* are getting better FPS scores at 640x480, which just seems wrong? So in the Chris's 3D Benchmark in the standard resolution, option 3 on the menu I get 323.9 frames per second, and then the 640x480 run option 4 on the menu results in a 34.4 frames per second. When running PC Player from option 5 which is in 320x240 I think, I get 153.6 and then running option 6 which is labeled as PC Player 640x480 I get a result of 17.4? And lastly I run the quake benchmark 320x240 I get 87.6 FPS, 320x480 I get 51.1 fps, and at 640x480 I get 11.2 fps.
I know this is something I have set up and changing a setting should help with this because 11.2 fps just seems super low. I know the FPU in the AMD chips is weak, but I could have sworn it was stronger than a Pentium MMX because my Pentium 233MMX I think gets 15 or so fps at 640x480 with a S3Trio64V+ video card. I haven't run any of the DOS based AMD tools, and I haven't installed any of the K6 Windows patches either. I am really open to any thoughts about what might be causing the strangeness. My issues with the DOS sound TSR has gotten frustrated enough that I am contemplating moving back to the AWE 64 GOLD that was in there originally so I can use certain DOS games, so I need to figure that out as well. I am using the version of the DOS TSR from the Install media, so maybe it's old and needs to be updated? I don't know.
Thank you in advance for any suggestions or ideas, and if this is in the wrong place, please let me know so I can move it to where it needs to go. Thank you.
Regards,
Nate.
