First post, by ajacocks
I just acquired this UMC-based SBC 486 motherboard, from eBay:
1.66 MiB
And here is the back:
1.6 MiB
It came among with this attached VGA card:
1.68 MiB
The only label on the board is INS-UMB486DX/LAN/CACHE. I’m guessing that “INS” is either the manufacturer, or a shortened version of “industrial single board computer.” Neither the LAN nor the cache options seem to be populated, on the board. The board has jumper settings for CPU speeds between 20 and 80 MHz.
Any suggestions are welcome. I can figure out most of the headers, but some are mysterious.
- Alex
Reply 1 of 3, by Warlord
Sick, those headers are for modules, theres probably seperate lan and cache modules. I looked everywhere, I tried searching for the VGA part number and came up with nothing as well.
Searching for PTP MV-1 I get alot of results. So I guess PTP is the manufacturer of the PCB anyways.
Reply 2 of 3, by ajacocks
Here is the location (I think) for the unpopulated RJ45 port, and the onboard LAN IC:
315.02 KiB
The missing cache, I believe, would be here:
333.4 KiB
- Alex
